VWVortex.com - ET 35 Offset...is it possible?
    Results 1 to 10 of 10
    Thread: ET 35 Offset...is it possible?
    1. Member b-R-ad's Avatar
      Mar 17th, 2012
      2016 GW Audi S3
      05-28-2012 09:49 AM #1
      Anyone tried a 35 offset wheel? I sure do love the RS4 wheel, but so far have ony been able to find it in a 35 offset. I just think that is too aggressive of an offset for the R...
    2. Member psipassat's Avatar
      Sep 14th, 2001
      CL, IL
      2012 Golf R, 2004 Cayenne S, 1972 Austin Cooper
      05-28-2012 09:54 AM #2
      I have, they look great, but unless your tires are not in your wheel wells, they rub like crazy. I had to raise mine up a quarter inch and put my coils on the hardest setting, and it still rubbed in the back over rail road tracks.
      2012 Candy White Loaded Golf R UM Tune!!!!! GT Haus Meisterschaft Exhaust with 104/90mm downpipe, and 76mm rear section, Valve actuated Exhaust. EVOMS intake. HPA short shifter, HPA Stage 3+ Clutch Kit
      For Info On The Meisterschaft Exhaust email: info@gthaus.com
      http://forums.vwvortex.com/showthrea...4-door-R-Build
    3. Member batman25's Avatar
      Dec 18th, 2010
      GA
      2012 RB 4dr R
      05-28-2012 10:13 AM #3
      Pics?
      I would love some et35 miros.
    4. Member b-R-ad's Avatar
      Mar 17th, 2012
      2016 GW Audi S3
      05-28-2012 11:30 AM #4
      Quote Originally Posted by psipassat View Post
      Yes, any pics would be appreciated. I have 45 offset right now, and the wheels are flush with the outside of the wheel well. Im not sure I would be inside the well with 35...doesn't the lower offset move the outside of the wheel further out?
    5. Member V8Star's Avatar
      Jun 27th, 2007
      Mission Viejo, CA
      Bagged VW
      05-28-2012 11:49 AM #5
      My BBS CH's are 19x8.5 et 35. Any wider of a width and there will be too much poke.
      Would have to run a 225/35/19 to clear the fenders. Realize the tires will be stretched, there will still be a possible chance of rubbing depending on your suspension and ride height.
    6. Member psipassat's Avatar
      Sep 14th, 2001
      CL, IL
      05-28-2012 05:32 PM #6
      I took them off, they were not in the wheel well. Looked like a roller skate. These were 18x8.
    7. Member batman25's Avatar
      Dec 18th, 2010
      GA
      2012 RB 4dr R
      06-02-2012 12:28 AM #7
      Quote Originally Posted by V8Star View Post
      Do you have these on yet?
    8. Member V8Star's Avatar
      Jun 27th, 2007
      Mission Viejo, CA
      Bagged VW
      06-02-2012 03:19 AM #8
      Quote Originally Posted by batman25 View Post
      I do but no photos yet.
      Rears sit flush, fronts poke slightly..
      For what its worth, running Hankook Ventus 225/35/19. BBS CH 19x8.5 et35
      Some tire brands will have a stretched sidewall at this size on the 8.5, but the hankooks are square. I am pretty sure the goodyear eagle f1s would have a nice rub free stretch, but I got an absurd deal on the hankooks
      Rub very slightly on big bumps, PSS Bilsteins spun all the way down front, most way down rear. I am VERY low.
      For a non rub setup I might look into swapping tires to 215/35/19 but for now it works.
    9. Member V8Star's Avatar
      Jun 27th, 2007
      Mission Viejo, CA
      Bagged VW
      06-03-2012 10:34 PM #9
      Here are some pictures to show the offset.
      And this is stock ride height, 235/35/19 Continental tire on a et 35 8.5 wheel... Does not work, tire is too wide. Scroll up and down to see head on comparison.
    10. Member b-R-ad's Avatar
      Mar 17th, 2012
      2016 GW Audi S3
      06-03-2012 11:19 PM #10
      Damn that looks good!
