Results 1 to 6 of 6
Thread: please help look over my setup
  1. Member DibbleDUB's Avatar
    Sep 27th, 2011
    Indiana
    2003 jetta GLS POS
    05-28-2012 10:01 AM #1
    i have 2.0 MKIV jetta and i am in the starts of building the engine for a turbo set up tell me how this looks and if any changes should be made:
    forged rods and pistons with 9.5:1 compression
    custom fabricating the manifold
    42# injectors
    ECS stage 1 14lb clutch kit
    t3/t4 50 trim .48 A/R turbo
    FMIC
    either gonzo tuned or C2motorsports
    goals are about 250whp-275whp
    i will be using the stock 5spd transmission
    this is car might see track but mostly Daily driver in the city
    KLUTCH REPUBLIK 8V Society #4
    Quote Originally Posted by MarkedIVGTI View Post
    And if it makes you feel any better, my entire rear end got destroyed on my springbreak
  2. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
    05-30-2012 06:32 PM #2
    Go to 8.5 or 8.0 compression and up the boost. @ around 20 PSI you'll see well over 200whp.
    If you want to make your 2.0 8v faster, read the thread below!
    http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
    May 1st, 2009
    cincinnati,oh
    96 jetta ABAT holset hy35
    05-30-2012 11:04 PM #3
    Everything looks decent. Things I would consider: 9:1 would be a little more pump gas friendly, forged pistons are not neccesary at that horsepower but are def a good idea, that turbo might be a bit big for only 275whp. Consider a t3 super 60 from a 80s mustang. 48 ar is good for about 275whp and 63 ar is good for about 300whp. Both will spool between 3300-3800 rpm. Full spool before 4000rpms for sure
  4. Member DibbleDUB's Avatar
    Sep 27th, 2011
    Indiana
    2003 jetta GLS POS
    05-31-2012 04:25 PM #4
    Quote Originally Posted by mk2golf14s View Post
    im still considering 9:1 and from what ive read the 2.0 will only hold up to 250whp with out new rods. i figure ill upgrade them now cause someday ill want to go to 300whp+ as for the turbo im still throwing it around. as for fueling what other things should i look at
    May 1st, 2009
    cincinnati,oh
    05-31-2012 04:30 PM #5
    Prob ms or c2
  6. Member DibbleDUB's Avatar
    Sep 27th, 2011
    Indiana
    2003 jetta GLS POS
    05-31-2012 07:44 PM #6
    Prob ms or c2
    like C2 but havent heard a lot about megasquirt
