VWVortex.com - Feeler/FS mkiv GTI big turbo
    Results 1 to 7 of 7
    Thread: Feeler/FS mkiv GTI big turbo
    1. Member AzDubN's Avatar
      Nov 16th, 2007
      Tucson, AZ
      2008 .:R32 / 1996 GTI VR6 *new project* / 1995 GTI VR6 *Sold* / 2002 GTI big turbo *rest in pieces*
      05-28-2012 03:05 PM #1
      I don't have the patience for projects. I want something I can get in and go and a MK6 or A3 has been calling my name.
      THIS IS NOT A PART OUT AT THIS TIME
      Looking for $15,000 obo
      2002 reflex silver GTI 150K 5 speed
      Engine (current)
      Stock AWP/06A 150K
      ATP clone turbo manifold (cracked will need replaced)
      ATP downpipe (real ATP)
      ATP oil lines and hardware
      Turbonetics/AGP T3/T4 (has some shaft play but still boosts fine)
      AGP wastegate (I would replace with a Tial for new build)
      Force Fed catch can
      Kinetic front mount intercooler
      Unitronic 830cc software (mafless, emissions delete, cat delete, sai delete, hemi tb, intake mani)
      830 cc injectors
      Bosch 044 fuel pump
      14 LB flywheel
      Sachs VR6 clutch (15K)
      Bolt down coils
      new O2 sensor
      BFI stage 2 motor/trans/dog bone mounts
      Turbo XS DV
      Newish stock fuel pump
      Engine build
      99% of parts are BRAND NEW in box
      spare AWP/06A +- 130K (was very well maintained and looked brand new when torn down)
      AGP Zeta 3.0 journal bearing T3 / Vband .63 AR(same exact specs as Precision 5857)
      All gaskets for turbo install
      JE pistons (stock bore/stroke 9.25:1 CR)
      Integrated Engineering 144X20 rods
      Calico coated rod bearings
      Calico coated main bearings
      Cat Cams 3658 camshafts
      Integrated Engineering valve spring/titanium retainer set
      Supertech inconel single groove keeper exhaust valve set
      metal impeller water pump
      IE SAI block off plate
      Integrated Engineering manual tensioner kit
      Gates Racing reinforced timing belt (X2)
      NGK BKR6E spark plugs
      ARP main studs
      ARP head bolts
      ARP cam sproket bolt
      ARP crank gear bolt
      All delete resistors needed
      boost valve boost controller
      Billet coolant flange
      Billet heater core fittings
      Billet radiator fitting (1)
      All braided SS hose/fittings/hardware to do billet/ss AN coolant system (heater core to flange and hardline)
      Billet radiator filler neck
      Moroso radiator cap for filler neck
      Most hardware needed for full SS braided/AN catch can set up
      Real HKS V4 SSQV BOV w/ alum weld on adapter
      Integrated Engineering fuel rail
      Aeromotive FPR
      OEM 6AN fuel filter
      All SS braided hose/AN fittings/hardware to do full SS braided/AN fuel lines
      Integrated Engineering surge tank
      ALL gastets needed for rebuild
      IE turbo drain oil pan adapter
      Vibrant turbo oil fittings
      Hemi 80mm throttle body
      KR Motorwerks custom intake manifold
      Silicone for TB
      EXTERIOR
      Shaved hood notch
      Shaved bumper notch
      Badgeless grill
      Shaved hatch (emblem and handle)
      OEM 337/20th front lip
      OEM 25th TDI euro rear lip (no exhaust cut out/RARE)
      OEM 337 sideskirts
      Shaved antenna
      new side markers
      Smoked Ecode headlights
      5000K HID kit
      Paint is 1 year old (not a great paint job, not bad either)
      Rear wiper delete
      Wheels/brakes/tires
      OEM BBS RC's (1 bent all rashed. Repairable)
      Bridgestone Potensa S-04 225/40-18 (Bridgestones flagship tire) (5K)
      Drilled/slotted brake rotors
      ST coilovers (5K)
      Lower tie bar
      Frame notch already done if going back to air ride
      Interior
      Interior is pretty rough
      Newsouth boost gauge/pod
      Euro headlight switch
      Kenwood bluetooth stereo
      Monsoon speakers
      Hardwood floor for hatch
      Extra parts
      TONS of extra parts mostly stock parts
      The bad
      Interior
      Windshield
      ABS speed sensor
      Axles (have a pass side)
      Exhaust leaks (mostly from cracked mani)
      Control arm bushings
      stock motor has been abused a little (didnt do some maintance since new build was going in)
      paint isn't perfect
      Fuel pump install fail (gauge doesnt work) can prob be fixed
      Needs to finish
      New turbo mani (real ATP)
      Bigger intercooler (may be able to help)
      Everything assembled
      New wastegate
      Should be capable of 500+ whp
      Call/text/email
      520-370-0951 azdubin@hotmail.com
      Back when it had diff wheels and air
      My bucket by .:Rob, on Flickr
      Mine by .:Rob, on Flickr
      Flickr | AzH2O | Volkwear Clothing | EUROjunkies
      Vote Saxon
    2. Member gnatman's Avatar
      Jun 2nd, 2007
      BMP MKIV .:R32T, B8A4, LS3-86Z28(trkhor)
      05-30-2012 03:52 PM #2
      nope not allowed
      ALL PRICES REDUCED
      Click me for apparel
      HAVE YOU SEEN THE VIDEO?
      .:::Exklusiv:::.
    3. Member gangstagolf's Avatar
      Feb 25th, 2009
      Phoenix
      Mk4 golf 1.8t, mk3 R swap
      05-31-2012 01:43 AM #3
      piece o' junk. scrap it.
      Pure Motorworks
      Vr6 Skid plate pan master, Message me.
    4. Member AzDubN's Avatar
      Nov 16th, 2007
      Tucson, AZ
      06-04-2012 05:45 PM #4
      $11.5k
      Vote Saxon
    5. Member gnatman's Avatar
      Jun 2nd, 2007
      06-12-2012 06:05 PM #5
      Quote Originally Posted by AzDubN View Post
      $11.5k
      still a nope.. sucks you want to sell the car
      ALL PRICES REDUCED
      .:::Exklusiv:::.
    6. Member AzDubN's Avatar
      Nov 16th, 2007
      Tucson, AZ
      06-12-2012 07:26 PM #6
      Quote Originally Posted by gnatman View Post
      Yeah, oh well . Looks like im gonna start the part out soon.
      Vote Saxon
    7. Member gnatman's Avatar
      Jun 2nd, 2007
      06-13-2012 02:16 PM #7
      good luck on that.. you'll never make what you bought it for.. sucks to say but its the truth
      ALL PRICES REDUCED
      .:::Exklusiv:::.
