Clear the codes see what comes back.
#1
I am having a hard time believing all of these motors failed at the same time, i dont know if i am missing a bigger issue causing all these or not so i wanted to get some other opinions.the other errors are not as important but if you feel like including them feel free. heres the most recent auto-scan, 10 min ago.
edit: the car is a 2005.5 Jetta 2.5L, bought used @ 84,000 miles, but i'm pretty sure it is fully loaded, has memory leather seats and all the bells and whistles ive read about.
VCDS Version: Release 11.11.3
Data version: 20120401
Monday,28,May,2012,15:04:05:46741
Chassis Type: 1K0
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62 72
VIN: 3VWDF71K95M618024 Mileage: 162010km/100668miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 06A 906 032 QF HW: Hardware No
Component: 2.5l R5/4V G 6608
Revision: 00000000 Serial number: VWZ7Z0E1485154
Coding: 0000001
Shop #: WSC 00066 000 00000
VCID: 72C507146DB4009
No fault code found.
Readiness: 0010 1100
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A55EF347544B89
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CF9196C4F90D69
6 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - -
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
01272 - Positioning Motor for Central Flap (V70)
000 - -
00710 - Defroster Flap Positioning Motor (V107)
000 - -
00716 - Air recirculation Flap Positioning Motor (V113)
000 - -
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000035277
Coding: F4059A02400418000014000000140000002177035C
Shop #: WSC 12345 123 12345
VCID: 2F43CE60BE066D1
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00063445
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00479269
Shop #: WSC 12345
2 Faults Found:
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD00Z4TP
Coding: 0012627
VCID: 2E7DD364B90C649
Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Address 16: Steering wheel Labels: None
Part No SW: 1K0 953 549 J HW: 1K0 953 549 J
Component: Lenksäulenmodul 010 0040
Coding: 0002041
VCID: 3957F0387042B31
Part No: XXXXXXXXXXX
Component: Lenkradmodul 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 C
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023103
Shop #: WSC 20200 993 00998
VCID: 2B7BDA708A1E111
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C0609F7
Coding: 3D7F03620F1002
VCID: 2977207880E2031
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNMK903
VCID: F8D1B53C8BC8EA9
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 A HW: 3C0 959 760 A
Component: Sitzverstellung 0601
Revision: 00002000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2475
Coding: 0001399
Shop #: WSC 98765 666 30737
VCID: 3753F6004656A51
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 3041CD1CA338729
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 1B100F880106483F6D02050FA0088F0490A540
Shop #: WSC 00066 123 12345
VCID: 8225D7D4DD14B09
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000009948
VCID: E9F7E078C062431
2 Faults Found:
00876 - Treble Speaker Rear Left (R14)
012 - Electrical Fault in Circuit - Intermittent
00877 - Treble Speaker Rear Right (R16)
006 - Short to Plus
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Component: Tuer-SG 024 2339
Coding: 0001142
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 HW: 1K0 035 180
Component: Radio DE2 008 0011
Revision: 00008000 Serial number: VWZ4Z7E2013438
Coding: 0010010
VCID: DD9FC4A8042A2F1
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3147C818A8327B1
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245C714AD34409
End ---------------------------------------------------------------------
#2
Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
#3
i tried clearing them and all of those codes came back, the climatronic seems to be working okay. i ran through all the self tests and nothing "seemed" wrong from what i could tell, granted i have only owned the car since last august.
#4
Then try a reboot of the car.
Recode 0x08-07-same data do it, the climate control head with the same data to also default and perform 0x08-10-00.
#5
edit: posted to soon, still have the codes.
I got it fixed. I am very appreciative of your help. I am not sure if I did your exact directions but i just went to the basic settings and I guess I told it to relearn the positions, I could not find a place to recode anything in the 08-HVAC module, so I am not quite sure how to do what you told me to do. I've only been working with my VAG-COM for about a week now
