maybe it's your exhaust system? maybe a heat shield is coming loose or the exhaust rattled off the hangers?
#1
I've got a stumper for everyone.
I recently noticed that my 2006 A3 2.0t DSG (73k miles) is making a strange rattle like noise when applying specific amounts of light throttle. It's most noticeable when cruising at highway speeds (its pretty much continuous).
- It is not RPM dependent.
- It is not gear dependent. Although it doesn't really occur in 1st or 2nd gear. In 6th gear I did notice that at high speeds (90+) that it will still lightly make the noise even at full throttle.
- The sound is the same whenever it makes the noise. The only thing that seems to affect it is engine load/throttle. It does vary in frequency and pitch a bit at different loads
- I've pulled apart most of the top of the engine bay looking for potential rattles. It appears to be more internal related
- Oil change was performed to ensure it was not related
- No engine codes
- I recently had the fuel pump cam follower replaced and suspected that. I went back to the shop and they removed it and checked it again to ensure that was not making the noise.
- Same shop checked the PCV system for issues, none found
- I did the fuel line rattle fix to ensure that was not it. It did fix the idle fuel line rattle at least.
- I suspected a potential by-pass valve issue and pulled the n75 valve connector to see if it had any effect. None.
- I suspected a potential wastegate issue and pulled the n279 valve connector. It still made the noise, but it did seem to change the behavior a little bit. It seemed to take a bit more throttle input to make the noise happen. So this could be related in some way.
- I can't make it happen while the car is not in motion through revving in neutral or by brake torquing the motor.
That's about all I've got on this thing. It's driving me nuts. I'm going to try bringing it by the dealer this week. My usual independent shop had zero luck figuring it out.
HELP! I'd welcome any and all thoughts.
#2
2006 Audi A3 Sport Package - Neuspeed Intake | APR Stage K04 | Eurocustom 3'' DP | Dogbone Mount Insert | BSH 27mm RSB | 3000k HID Fogs | LED Tails (Inner) | Euro Tails (Outer)
#3
Unfortunately no. I crawled under today and checked the entire exhaust system. Rattle maybe isn't a great description. It's a noise, it sounds mechanical, but not metal on metal. More like rubber vibrating almost.
Little audio clip I tried to make, its not very good unfortunately.
http://thekitch.com/files/audio/rattle.mp3
#4
I had a noise like this. It was not rpm dependent nor speed. I could replicate it when the car was off by pushing it back and forth.
Turned out to be my downpipe mount on the bottom was cracked. Got it welded and it makes no noise.
So idk. You mentioned that you checked the exhaust. But this crack was maybe 5mm long. Just a tiny bit of metal rubbing can make a stupid loud noise. I missed it the first time I had my car on a lift looking for the noise. So maybe take a super close look at the exhaust
Edit: You said in the above post the sound isnt a metal on metal sound. Doh! Ignore this then, ha.
Photography: www.venezia-photography.com ------- AZ H2O Club Tucson ------- Cars: 06 Ibis White A3 2.0t 1986 BMW E28 535i
#5
Rebelxt. Interesting. Was your issue that the mount/hangar was cracked or an actual crack in the exhaust itself? I will definitely get the car up again and do some more searching. It's not a metallic sound so I'm not hopeful, but it can't hurt to look.
Edit: ha! Just saw your edit. The search continues
#6
It was on the hanger at the bottom of the downpipe. The part where it has the two things that stick out towards the front of the car. The downpipe was an aftermarket downpipe, but I assume it could happen on the stock one too.
Ha, yeah. Hope you can find it! Little noises are annoying.
