Results 1 to 14 of 14
Thread: rear calipers question.
  1. Member jordan_337's Avatar
    Dec 7th, 2010
    grand haven ,MI
    02 337 (sold).84 rabbit (sold). B5 a4 1.8t (sold) b5 s4 2001.5
    05-28-2012 10:41 PM #1
    i ordered new calipers from rock auto and told them it was for the 337 fitment. they send the wrong ones anyways. the reason i needed new ones is cuz there both sticking. can i use my hangers with these calipers? or are they way differnt??
    i searched,,,, for the record.
  2. Member OddJobb's Avatar
    Nov 6th, 2004
    Greenville SC
    2004.5 Jetta GLI, 1995 Golf III City
    05-28-2012 10:58 PM #2
    It's impossible to know if they can be used because we don't know what they sent you.
    RockAuto. I'd buy from European/VW specialist sites like MJM or ECS. They will be better at determining what parts are right for your car.
  3. Member jordan_337's Avatar
    Dec 7th, 2010
    grand haven ,MI
    05-28-2012 11:05 PM #3
    they sent me oem one for a golf
  4. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    05-29-2012 12:15 AM #4
    No. you need the proper 3/2/G/R32 calipers.
    Not to rub salt in your wounds, but this is why we order from places that actually care about the end user.
    German autoparts gets my money every time first. If they don't have it then I check MJM Autohaus, then if still negative, I reluctantly go with ECS..
  5. Member A-Bugg's Avatar
    Oct 24th, 2000
    Ohio
    20AE GTI, 04Golf Wagon, MK2 golf
    05-29-2012 08:34 AM #5
    The caliper should fit and work just fine, if you use your hanger. The major difference is the paint.
  6. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    05-29-2012 05:11 PM #6
    Quote Originally Posted by A-Bugg View Post
    NO NO NO NO NO. Jesus, the calipers, carriers, and rotors are all different.
  7. Member jreed1337's Avatar
    Jun 30th, 2009
    Napa CA
    2004.5 Jetta GLI BL----- 1989 GTI 16v AW
    05-29-2012 05:14 PM #7
    germanautoparts.com.
    they don't offer free shipping, but they seriously have the absolute best customer service in the entire industry.
    prices are very competitive as well, usually offer oem and other options.
    1+3+3=7
  8. Member A-Bugg's Avatar
    Oct 24th, 2000
    Ohio
    06-04-2012 02:51 PM #8
    Quote Originally Posted by 87vr6 View Post
    Carriers..Yes.
    Rotors..Yes.
    Pads...No.
    Calipers...How?
  9. Member SweetRide's Avatar
    Jan 7th, 2004
    Indy
    97 Jetta GLX, 04.5 Jetta GLI
    06-04-2012 07:35 PM #9
    I am almost 100% sure that the Rotors are different if its not a 3/2/G its a solid rear rotor versus a vented which is wider which is why the caliper is different as well.
  10. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    06-04-2012 07:36 PM #10
    Carriers..Yes.
    Rotors..Yes.
    Pads...No.
    Calipers...How?
    Because of this, If the pads are the same (which they are) and the rotors are much thicker (which they are), then how on earth could the calipers possibly be the same?
    Quote Originally Posted by SweetRide View Post
  11. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    06-04-2012 08:01 PM #11
    Sorry, I was wrong about the pads, I can admit my mistakes, but everything else is about to be addressed:
    And to put this to a rest with all the misinformation being thrown around in here...
    3/2/G
    Calipers (rear)
    1J0615423E
    1J0615424E
    Rotors (256x22)
    8N0698601B
    Pads
    1J0698451R
    Regular MK4 cars
    Calipers (rear)
    1J0615423G
    1J0615424H
    Rotors (232x9)
    1J0698601C
    Pads
    1J0698451R
    As you can clearly see, the 3/2/G rotors are not only bigger in diameter, but substantially bigger in thickness, hence different calipers.
    Ironically enough, 3/2/G and regular 1.8t/VR6 cars share the same front calipers and pads, but different sized rotors and caliper carriers, but the 2.0 and TDI MK4 use completely different front braking stuff that isn't compatible with anything...
  12. Member 20thGTIMAN's Avatar
    Feb 2nd, 2012
    Puyallup, Wasington
    2003 BMP GTI 20th Anniversary Edition, 2006 Aspen White STI
    06-05-2012 12:25 AM #12
    3/2/G
    Calipers (rear)
    1J0615423E
    1J0615424E
    Rotors (256x22)
    8N0698601B
    Pads
    1J0698451R
    Regular MK4 cars
    Calipers (rear)
    1J0615423G
    1J0615424H
    Rotors (232x9)
    1J0698601C
    Pads
    1J0698451R
    Def gonna write this down.
  13. Member A-Bugg's Avatar
    Oct 24th, 2000
    Ohio
    06-05-2012 10:16 AM #13
    Nice. Good to see some numbers behind the words.
  14. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    06-05-2012 05:11 PM #14
    Is that all you wanted? You couldn't do it yourself, to back up what you thought was right...?
    It shouldn't take part numbers to see what you can physically see for yourself and is plainly obvious if you actually looked at these cars. But what do I know, I mean, I've only had a regular model jetta for 6 years that I put a full set of 20th brakes on, and then after that car I got my current 20th for the last three years...
