VWVortex.com - misfiring vr6
    Results 1 to 14 of 14
    Thread: misfiring vr6
    1. Member hares1370's Avatar
      Sep 27th, 2009
      Greensboro North Carolina
      1997 jetta
      05-29-2012 12:22 AM #1
      My car seems to run fine but my check engine light is on for misfires. I have a ford coil pack conversion, with new ford wires from ecstuning, and spark plugs.I'm using the ngk v power copper core plugs. The only thing that isnt new is the coil pack. I have 3 used coil packs that i have swapped with same results which is a misfire. I also changed out the icm as well. The maf problem happend today because i just oil and cleaned my k&n filter so it will have to be clean tomorrow. Any help on this would help out alot thanks
      Monday,28,May,2012,23:05:43:49189
      VCDS Version: Release 11.11.3
      Data version: 20120401
      Chassis Type: 1H - VW Golf/Vento III
      Scan: 01 02 03 08 12 15 25 41 56
      Address 01: Engine Labels: 021-906-259-AAA.lbl
      Part No: 021 906 259 K
      Component: MOTRONIC M5.9 HS V04
      Coding: 00000
      Shop #: WSC 00066
      VCID: 1D2CCF9897AAEF1
      7 Faults Found:
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 35-10 - - Intermittent
      16685 - Cylinder 1
      P0301 - 35-10 - Misfire Detected - Intermittent
      16689 - Cylinder 5
      P0305 - 35-10 - Misfire Detected - Intermittent
      16687 - Cylinder 3
      P0303 - 35-10 - Misfire Detected - Intermittent
      16688 - Cylinder 4
      P0304 - 35-10 - Misfire Detected - Intermittent
      16690 - Cylinder 6
      P0306 - 35-10 - Misfire Detected - Intermittent
      16486 - Mass Air Flow Sensor (G70)
      P0102 - 35-10 - Signal too Low - Intermittent
      Readiness: 0000 0000
      Address 15: Airbags Labels: 6N0-909-60x-VW2.lbl
      Part No: 6N0 909 603 D
      Component: AIRBAG VW2 V00
      Coding: 00068
      Shop #: WSC 00066
      VCID: 33780920012E491
      2 Faults Found:
      00588 - Airbag Igniter; Driver Side (N95)
      32-00 - Resistance too High
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      End ---------------------------------------------------------------------
    2. 05-29-2012 10:58 AM #2
      THIS POST MOVED/VACATED BY JACK TO PROTECT CONTENT FALLING INTO THE GAPING HOLE OF THE VORTEX
      IT SEEMS NO GOOD DEED GOES UNPUNISHED!
      http://www.youtube.com/watch?v=HaoySOGlZ_U
    3. 05-29-2012 06:35 PM #3
      Have you checked the plug leads?
      You need to scope the afm and see what exactly it is doing,and check the wires going to it, make sure there is good continuity in each of them,no cracked or half broken circuits.
    4. 05-29-2012 07:06 PM #4
      Also very true Mike.
    5. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      05-29-2012 08:30 PM #5
      I cleaned the maf today and now it only misfires on 1,3,5 now...whats afm
    6. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      05-29-2012 08:35 PM #6
      I did check the plugs when I got them. The car while hit 6k without a skip
    7. 05-29-2012 10:28 PM #7
    8. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      05-31-2012 10:11 AM #8
      wouldn't i throw a code for that? what the code for the measuring block... i cleaned my maf yesterday and it only misfires on 1,3, and 5 now
    9. 05-31-2012 10:15 AM #9
      Read your balloons in VCDS.
    10. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      05-31-2012 10:56 PM #10
      I don't know what ballons are
    11. 06-01-2012 12:03 AM #11
      I'm so sorry, CAPTIONS!
      You know like in comics, the funny papers?
      Highlight with pointer of mouse on PC.
    12. Member Novo1.8T's Avatar
      Nov 28th, 2006
      Ballard, WA
      2001 Jetta 1.8T
      06-01-2012 09:36 PM #12
      Maybe check your fuel pressure and related components (Fuel Pressure Regulator, Plugged Fuel Filter, Weak Fuel Pump, Injectors, ETC...) cylinders 1,3,5 are on the back of the head so fuel has to travel farther through the head after leaving the injectors to reach the cylinders, if pressure is low or the injectors aren't spraying good enough, the mixture will be incorrect once it reaches those cylinders.
      Certified Volkswagen Master Technician!VAG-COM Equipped!
      My 4Motion 1.8T Jetta!
    13. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      06-03-2012 12:52 AM #13
      Ok thanks guys
    14. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      07-08-2012 04:01 PM #14
      u FINALLY GOT AROUND TO CLEANING THE MAF AND IT JUST NOW MISFIRES ON 1 3 5 SMH
