Originally Posted by
Glegor
i imagine the non-a/c pullies are LONG NLA... thats why i told you to check foxes in the wrecking yards, because they are still very common.. i run across non-a/c pulleys every time im at the yards.. and yes, all 1.8L 8v engines are all basically identical. dont try and use 16v pulleys tho, they wont work, they are 5mm less offset than the 8v pulleys..
and if you loop your power rack, you will have pop-eye arms in no time, its HARD AS HELL to drive a power rack as manual.. just dont drive in parking lots, under 5mph, or get in traffic jams, and the power rack as manual will be FINE, but if you actually want to enjoy driving the car, either hook up the power steering, or install a manual rack setup. you will HATE the power rack ran as manual..
its a little over 4 turns, lock to lock, on the manual rack.
its a little over 3 turns, lock to lock, on the power rack.
so, it takes CONSIDERABLY more effort to work the power rack.
if you feel the need to be lazy, and try to just buy new pulleys, then call the stealership, thats the only place that would have them. parts stores DO NOT carry pulleys for VW cars.. and non-a/c pulleys were quite rare to begin with. i imagine IF THEY STILL MAKE THEM, that they are going to be close to $100 for the 2 pulleys. and you still need an alternator bracket to go with them.
dont be lazy. just go look in wrecking yards. look for foxes, rabbits, golfs, jettas.. basically, look under the hood of every 88-older VW you can find. you will come across a set of pulleys eventually. over half of all foxes ive seen, have no p/s or a/c.. they are a easy source for pulleys. early(ish) rabbits were also common to have neither.. but i like the pulley setup off the fox/mk2 jetta/golf better myself personally..
