Results 1 to 11 of 11
Thread: Flickering mil
    Sep 5th, 2010
    Beech Creek Pa
    s/c'ed 03 gli
    05-29-2012 12:32 PM #1
    Was wondering if you guys can help me figure out what's going on with my girlfriends car. It's a 03 gli and it's flickering the mil and stumbling on hot days. The mil doesn't stay on long enough for my obd scanner to pick up any codes. I have tried coil packs and plugs and it didn't resolve the issue. Also the plunger on the intake manifold keeps actuating at idle... Any suggestions are welcome, unfortunately I don't have access to a vag-com at this time.
  2. Member bcgrrednek3006's Avatar
    Feb 21st, 2012
    beech creek
    2004.5 jetta bagged, 2011 fj cruiser
    06-04-2012 11:53 AM #2
    lower it
    #puffeurogarage : Freshhhhhhhhhhhhhhhhhhh : Ermahgerd
    instagram: Tacticalbacon13
    Sep 5th, 2010
    Beech Creek Pa
    s/c'ed 03 gli
    06-04-2012 12:04 PM #3
    Already tried that.
  4. Member bcgrrednek3006's Avatar
    Feb 21st, 2012
    beech creek
    06-04-2012 01:20 PM #4
    Quote Originally Posted by nyman View Post
    Already tried that.
    then get rid of girlfriend.
    gf+broken dub= problems
    problems- gf = single and parts car
    Sep 5th, 2010
    Beech Creek Pa
    s/c'ed 03 gli
    06-04-2012 03:17 PM #5
  6. Member bcgrrednek3006's Avatar
    Feb 21st, 2012
    beech creek
    06-04-2012 03:35 PM #6
    need to pay off enduro, then trade that and car for r32!
  7. Junior Member
    Oct 19th, 2011
    2003 VR6 24V
    06-05-2012 12:08 AM #7
    Sounds like a crank position sensor to me.. Get codes ran and if p0332, thats most likely your issue.. Does it run fine then fall on its face at 2 grand but will then run right once it cools? Thats what mine did..
    Sep 5th, 2010
    Beech Creek Pa
    s/c'ed 03 gli
    06-05-2012 08:26 PM #8
    Quote Originally Posted by 03VR624VBDF View Post
    No it misses all over the rpm band, hasnt done it since its been cooler out.
    Sep 5th, 2010
    Beech Creek Pa
    s/c'ed 03 gli
    07-13-2012 09:29 AM #9
    Bump for now doing it without the mil coming on
  10. Member bcgrrednek3006's Avatar
    Feb 21st, 2012
    beech creek
    07-13-2012 02:24 PM #10
    Poop on it?
  11. Member
    Sep 5th, 2010
    Beech Creek Pa
    s/c'ed 03 gli
    09-11-2012 11:56 AM #11
    Just picked up vag com and noticed that the voltage for cylinder 6 knock sensor is reading zero at all times while the others seem to be reading normal. Would this point to a bad knock sensor or something else? My general understanding was that cylinders 4-6 were all based off of the same sensor.
