Results 1 to 5 of 5
Thread: 02j in mk3
    Sep 14th, 2007
    woodbridge va
    1997 golf 2.0,1968 beetle
    05-29-2012 03:17 PM #1
    hi folks,im going to eventually be swapping a 02j in my mk3 with aba engine.i know i need an 02a rear trans mount bracket.im kind of confused on what front engine mount bracket i need as i have read different answers.what exactly do i need?do i use a b4 passat tdi front motor mount bracket or a mk3 front tdi motor mount bracket?thanks,walt
    DO NOT BUY FROM 2.8DOHCVTACH (now is harryballzonya) HE IS A SCAMMER
  2. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    2001 allroad 6sp, 98 GTi TDi, Caddy TDi to be
    06-03-2012 12:19 AM #2
    Your stock front mount will work fine. The mk3/b4 tdi mount is heavier duty. I went through 2 ABA mounts on my 1.8t/02j swap.
    Malone tuning services available- Contact Ben at MaloneTuningVA@gmail.com
    http://malonetuning.com
    MK4, B5, B5.5 remote window control recoding available and VCDS MK5/6. SKC retrieval, Cluster matching, IMMO programming/delete.
    Sep 14th, 2007
    woodbridge va
    06-03-2012 08:12 AM #3
    oh ok so the b4 tdi one will work.i picked one up on here to use.for the reverse light do i just change the connector on the harness since the mk4 one is D shaped and mk3 is square?and what bout engine rear mount braket..stock auto or do i need a manual one?
  4. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    06-03-2012 10:16 AM #4
    Just unscrew and swap reverse switches.
    As long as the b4 mount is the same style "puck" as your mk3 you will be fine. Is this an auto to 02j swap? If so I am not sure of the minute differences between auto and manual mounts.
    Just use all ABA 5 speed mounts and you will be fine
    Sep 14th, 2007
    woodbridge va
    06-03-2012 04:30 PM #5
    yeah im going from autotragic to 5 speed.its not a immediate project.well im going to use the b4 tdi front mount bracket.so i can use a mk3 reverse switch?i know i can use the mk3 speed sensor to?
