Results 1 to 2 of 2
Thread: FS: 1990 Coupe Quattro $3900
  1. 05-30-2012 09:26 AM #1
    Black / Platinum
    135K miles
    This CQ is ready for driving!
    LOTS of new parts in the last few thousand miles:
    -Timing belt (conti)
    -Water pump (metal impeller)
    -Head gasket
    -valve cover gasket
    -cam chains
    -distributor
    -plugs
    -wires (not new, bought on MG in good condition)
    -plugs
    -02 Sensor
    -Magnaflow round catalytic convertor
    -Scorpion cat-back exhaust (sounds amazing!)
    -034 Snub mount
    -Energy Motor mounts
    -Meyle trans mounts
    -034 Sport Rear diff mounts
    -034 short shifter (best feeling linkage in any Audi I've owned)
    -034 injector kit (latest version)
    -H&R Springs, Bilstein shocks - Meyle strut mounts
    -B5 A4 sport steering wheel + column surround
    -B5 A4 shift knob
    -Wood trim sprayed with 2 coats of poly for faux carbon fiber trim - looks MUCH better than you would think, see pics, even better in person
    -New antenna from headunit to ariel
    -New starter
    -Metal radiator
    -New inner and outer tie-rods
    -Front rotors
    -New fuel lines + filter
    -Several new brake lines
    -New heater core
    -New ignition switch + new cores for front doors, PO also replaced carrier/cam that attaches at rear of core
    -Driver side window regulator replaced with a newer UK cabriolet
    -This car did NOT originally have the cold weather package, but is wired for it. PO purchased intact harness from Joe Marconi
    -Resealed tailights
    In the last 100 miles:
    -New Goodyear Eagle GTs mounted on Borbet rims. Vibration / shimmy free and road tested at 80MPH
    -Fresh alignment
    Audio system was updated:
    Alpine 103bt headunit + KTP-445
    4” co-axial upfront
    5 1/4” Diamond audio in rear quarters
    2 - 8” rockford Punch powered by a JL Audio e1200 (small box is pressure fit into rear hatch area, carpet is intact)
    Bluetooth module with microphone mounted in overhead sunroof switch area
    This car is not perfect. Here are the items that still need attention:
    - Rear wiper/defrost not working
    - Center stack needs some light bulbs replaced, PO did all of the bulbs in the cluster.
    - PO swapped out the tach for a working one and it hasn't read right beyond idle (about 1K RPM too low)...maybe the dip switches are set wrong?
    - A/C will need to be gone through..definitely needs a charge and seals
    - Central locking / alarm inoperative
    - Driver's door lock inoperative
    - Ignition switch is still flaky. Sometimes takes a few tries to engage the starter, but ALWAYS starts
    Have many extra parts that I will throw in as part of the sale.
    I also have an extra set of Speedline wheels available ($200) that would make a great set of winter wheels
    Cosmetically, the paint shines nicely for it's age and appears to be original with the exception of the passenger front fender. It presents nicely, but does have dings, scratches, and a few small dents, the worst of which is the hood. The driver's side front bumper cover is torn (as shown in the pics) and the front is scuffed by the license plate mount (also shown in the pics). If I was keeping this car, I would find a B4 hood, lights, and bumper cover and call it a day.
    I'll let the pictures speak for themselves on the interior.
    Overall, this car would make a GREAT DD RIGHT NOW. Power windows, seats, sunroof, gauges (except tach reading incorrectly), CC all function as they should. The car drives good and sounds even better with the Scorpion exhaust. The power delivery is smooth and linear right up to redline with no hesitation / steppedness that is sometimes common with the 7A.
    The car is located in Northern NJ 30 minutes from NYC.
    You can contact me:
    e28m5 at comcast dot net
    OR
    NINE ONE SEVEN 374-3291
    TONS more pictures available here:
    https://skydrive.live.com/redir?resi...463CC73C43!439
  2. Junior Member NoggyB5S4's Avatar
    Nov 5th, 2011
    06776 CT
    2000 Nogaro stg 2+ s4 (totalled), 2001.5 nog s4
    07-04-2012 01:59 PM #2
    Still around?
