VWVortex.com - New MKVI Jetta Hood Lift system - Redline Tuning
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 60
    Thread: New MKVI Jetta Hood Lift system - Redline Tuning
    1. Junior Member
      Mar 7th, 2012
      Michigan
      2011 Jetta 2.5 SEL w/ Cov.
      05-30-2012 11:37 AM #1
      Hey all,
      I just had some amazing new gas springs installed on the hood of my 2011 MKVI Jetta SEL. I thought you would like to get an exclusive peek at this new product!
      The company that designed them is Redline Tuning, based in Michigan. They used my MKVI Jetta as a test-install to design and calibrate them for sale to the public. Luckily I was able to drive away with a of QuickLift PLUS system for free as a thank you for donating my car. Awesome.
      I am really impressed with the final product - they are custom designed and definitely worth it. It makes my new Jetta look so much better without the prop rod! They are calibrated as a progressive, slow-release system and lifts the hood to the exact level that the OEM prop rod did.
      The owners, Brian and Andreas were very professional and took their time in finding the best mounting location for the hardware. They figured out that the bolts in the engine bay were not sufficient and decided that they needed to drill and rivet the hardware in a more secure location. All in all the system took about 2 hours to design and fit from scratch - not too bad.
      Here are some pictures of the final install. The only modification that I had to do was to cut down the foam dust barriers to accomodate the gas springs when closed. A sharp razor blade did the trick in about 5 minutes.
      Redline Tuning is working on getting the manual, installation video and hardware package ready. They said that it should be available for sale in about 2 weeks. If anyone has any questions or picture requests let me know - I'll do my best to help. Prices should range $70 - $120 depending on which set you choose. The system in the picture is their QuickLift PLUS model with black, powder-coated hardware and is valued at $84.95.
      A special thanks to Brian and Andreas for treating my car so well and welcoming me over to their research center - great guys.
      Washed, waxed and ready for install
      Final install - 2 hours later. Removed the prop rod (just pulls out from the rubber gasket)
      Closeup of gas spring
      Left side installed
      Mounting point for gas spring - quality hardware. It's not going anywhere!
      Modified foam dust shield - notice the notch I carved for the strut to lay in when closed.
      Nov 3rd, 2011
      RVA
      2011 Jetta SE, 1984 Rabbit diesel
      05-30-2012 12:39 PM #2
      That looks surprisingly good
      Feb 3rd, 2011
      Chesapeake, VA
      '12 GLI Platinum Gray
      05-30-2012 12:43 PM #3
      Looking good!
      '12 Jetta GLI Platinum Gray
    4. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      BT MK6 GLI, and other non VW stuff..
      05-30-2012 01:20 PM #4
      for 85 bucks, i'd hit it....as long as i don't have to have those redline stickers on there...
      Feb 3rd, 2011
      Chesapeake, VA
      05-30-2012 01:42 PM #5
      Quote Originally Posted by pattrick02 View Post
      they peel off.
    6. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      05-30-2012 01:50 PM #6
      Quote Originally Posted by adamkramerusn View Post
      they peel off.
      good stuff.
      so when does this kit come out? any group buy? that would be sweet.
    7. Member madrussian's Avatar
      Mar 29th, 2003
      Akron, OH
      15 JGC, 15 VW Tiguan, 93 LX Foxbody, 70 C10 5.3L LS
      05-30-2012 02:35 PM #7
      good stuff.
      x2.
      though i dunno how i feel about drilling.
      Apr 22nd, 2009
      NJ
      '12 Jetta GLI
      05-30-2012 02:48 PM #8
      Looks haggard.
      Good that another aftermarket company is paying attention to these junkboxes though
      Quote Originally Posted by Rigby
      Hamboning will save your life someday
    9. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      05-30-2012 03:04 PM #9
      Quote Originally Posted by madrussian View Post
      x2.
      true..would be nice if there was some way to use an oem mounting point or something like that...but i don't think there is..i don't think it should be too much trouble drilling though..
    10. 05-30-2012 05:23 PM #10
      Ill buy it, I hate having my hands full and trying to open my hood :p
      Current Project: Nogaro Blue B5 S4
      Previous Projects: | AirdOut Bagged A3 | Project Death Star | Project Boba Jett
    11. Member azthegame's Avatar
      Oct 27th, 2011
      Arlington, TX
      2012 Jetta SEL, 2012 4DR Golf TDi
      05-30-2012 05:32 PM #11
      Love it, will definitely get a set at some point.
      I also love the praise this is getting after all the ridicule that was given when the original thread asked if anyone wanted to be the test car
      Screw everyone with their ridicule
      Dec 22nd, 2010
      Tri-State
      2011 Jetta Sedan SEL w/ Sunroof
      05-30-2012 05:37 PM #12
      Where did u get the german badge? 85 bucks isn't bad at all! Looks good!
    13. Member
      Dec 11th, 2011
      Austria - Wörthersee
      Jetta MK4 + MK6
      05-30-2012 05:51 PM #13
      But every hole u´ve drilled can rust??
      This isn´t an good idea
    14. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      05-30-2012 05:53 PM #14
      Quote Originally Posted by azthegame View Post
      the hate was the fact that they had asked for a test car to like create a hood strut or whatever the hell it was..honestly, there isn't much to it..i'm sure any of us could piece this together...but yeah, whatever.
    15. Junior Member
      Mar 7th, 2012
      Michigan
      05-30-2012 07:08 PM #15
      Quote Originally Posted by suprstng00 View Post
      Got the badge from DetailHaus.
      I think I paid $12 for it - it is hard embossed ABS plastic with screen printed colors. MUCH better than most of the other "Eurobadgez" out there which are bendy printed stickers.
      Just popped some double-sided tape on the badge, lined it up with a level and stuck it on. Its NOT coming off without ripping out the chrome accents on the grill. Been through the carwash a few times with it on and it hasn't moved at all.
      Thanks for all the kind words everyone - I'm not too concerned about the rust issue around the rivets, they are pretty tight. If its a concern, you could always drop some paint or sealer around the drill holes before dropping the rivet in - should take care of it.
    16. Member
      May 20th, 2012
      North Carolina
      15 M3/16 Jetta Sport
      05-30-2012 07:22 PM #16
      Looks great, they make a wonderful product. I had these on a previous vehicle a few years back.
      Love the German badge. Wanted to do something similar, but I wasn't sure how it would look. Especially on the all black SE grill. After seeing it on yours I might have to give my idea a whirl...
      2015 BMW M3 - Sakhir Orange Metallic/6MT - slammed on KW V3s and a bunch of other mods
      2016 VW Jetta Sport - Black/5MT - stock AF
      Follow me on Instagram - @dangeroustacos
    17. Member
      Feb 3rd, 2011
      Chesapeake, VA
      05-30-2012 10:47 PM #17
      Quote Originally Posted by Sternat View Post
      When I've used these in the past, I used touch up primer (available at most stores with the touch up color brushes and pens) anywhere I drilled a hole, let it dry and then installed the brackets with the supplied rivets. Zero issues on 2 different car.
    18. Member jettsy's Avatar
      Mar 28th, 2011
      South Florida
      2007 Passat Wolfsburg (Sold) - 2011 Jetta SE (Sold) - 2014 Tiguan SEL (Current)
      05-31-2012 12:58 AM #18
      x2
    19. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      12' Jetta S, 95' Passat GLX, 93' Corrado SLC
      05-31-2012 07:50 AM #19
      Where can these be purchased?
      R.I.P. Allen A.K.A. vr6inside98. 89'-11' I LOVE YOU MAN
      Tri state area. VAG-COM (VCDS) Scans/Mods available (HEX+CAN)/Suspension install available/Fender rolling available. Send me a PM for pricing!
      Instagram- @mr_toffee
    20. Member
      May 20th, 2012
      North Carolina
      05-31-2012 08:50 AM #20
      Quote Originally Posted by EuRoGTI86 View Post
      Directly off their website once they're available.
      http://www.redlinetuning.com/
    21. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      05-31-2012 09:54 AM #21
      and that would be when?
    22. Member
      Feb 3rd, 2011
      Chesapeake, VA
      05-31-2012 01:02 PM #22
      "They said that it should be available for sale in about 2 weeks."
    23. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      05-31-2012 02:35 PM #23
      sweeet. sounds good.
    24. Member
      Feb 3rd, 2011
      Chesapeake, VA
      06-06-2012 10:33 PM #24
      http://www.redlinetuning.com/QL-VOLKS-JETTA-11+.html
      They're up and I just placed my order!
    25. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-06-2012 11:34 PM #25
      Nice, this will be on the to do list!
