It currently looks buck-toothed![]()
#1
I just bought a 2011 Volkswagen Routan SEL Premium Calla Lily White, CPO.
I decided not to drill the front bumper when I found out there is no bracket and it literally just drills into the bumper.
The front fascia looks great without it there, so decided to come up with something.
At the moment, I just zip-tied the plate to the black plastic molding.
I just ordered this:
Therefore, I can zip-tie the bracket (= no drilling at all), then mount the plate to it (= no visible zip-ties, as in right now in the above picture, you can see the zip-ties).
Thought I'd share.
#2
95 Jetta GL 2.0L, chipped, intake, exhaust, compression, cam, close-ratio w/Peloquin, etc.
72 VW Squareback, rag top, 2.0L, parents original owners
76 VW Riviera Bus, the family camper-- '02 Passat 1.8t & '13 Touareg Executive
06 Ducati Sport Classic 1000...only motorcycles can feed the need for speed
#3
2011 Calla Lily White Volkswagen Routan SEL Premium
#4
Priceless.
I'm so glad I live in PA where there is no front plates. So far with our last two Passats and the Routan, all of which we had the dealers find what we wanted, I always put that stipulation on there. "If it shows up with the front bumper drilled for a plate or filled to fix it, that is a deal breaker." I like the way you put it on the lower grill![]()
1958 VW Ragtop Bug
2005 VW Passat Wagon
2010 VW Routan SEL
Be sure to check out the Original Routan Dead Pedal Click Here
#6
That's the installed pic, i just covered up the plate number.
#7
I like how you mounted that. Is the black bracket you show from VW? If not, where did you get it and how much? I just purchased a 2011 Routan and need to install the front plate and like your install. Thanks for the post.
#8
Go to any auto store and buy a black license plate front mount. Buy some black zip-ties if you don't have any.
It's as simple as zip tying the bracket to the front bumper, then installing the license plate.
Total cost was around $10.
I zip tied wherever i could on the back to make it feel solid.
