VWVortex.com - lower timing chain guide rail
    Results 1 to 5 of 5
    Thread: lower timing chain guide rail
    1. Junior Member
      May 13th, 2011
      2000 gti glx 12v
      05-30-2012 12:36 PM #1
      So today im going to try to replace the lower guide rail. I have replaced the top and put it back together now my question is do I have to take off the top parts intake mani valve cover upper cover again or will I be fine just dropping the tran and such thanks for reply!
      Quote Originally Posted by thedevilsequal View Post
      -your car is constantly called cute and it still doesn't get you laid
    2. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      05-30-2012 09:49 PM #2
      You wont be able to change the lower guide rail without removing the chain. You may be able to just remove it off the lower gear on the crank shaft and sneak it up but you'll want to make sure its at tdc cyl 1 regardless.
      Otherwise just take the covers off
      diesel life cause cold feet are fun....
    3. Junior Member
      May 13th, 2011
      2000 gti glx 12v
      01-07-2013 02:53 AM #3
      The chain has to be removed before removing the lower guide rail? I thought it just slid right out
    4. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      01-07-2013 11:22 AM #4
      Lower guide rail chain needs to come out to remove. Lower tensioner doesn't need the chain to be removed. You'll see when you get into it
    5. Junior Member
      May 13th, 2011
      2000 gti glx 12v
      01-08-2013 05:24 PM #5
      Thank you for your reply/answer. One last question I have to remove the upper chain before removing the lower right?
