Results 1 to 5 of 5
Thread: lower timing chain guide rail
  1. Junior Member
    May 13th, 2011
    2000 gti glx 12v
    05-30-2012 11:36 AM #1
    So today im going to try to replace the lower guide rail. I have replaced the top and put it back together now my question is do I have to take off the top parts intake mani valve cover upper cover again or will I be fine just dropping the tran and such thanks for reply!
    Quote Originally Posted by thedevilsequal View Post
    -your car is constantly called cute and it still doesn't get you laid
  2. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    05-30-2012 08:49 PM #2
    You wont be able to change the lower guide rail without removing the chain. You may be able to just remove it off the lower gear on the crank shaft and sneak it up but you'll want to make sure its at tdc cyl 1 regardless.
    Otherwise just take the covers off
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  3. Junior Member
    May 13th, 2011
    2000 gti glx 12v
    01-07-2013 01:53 AM #3
    The chain has to be removed before removing the lower guide rail? I thought it just slid right out
  4. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    01-07-2013 10:22 AM #4
    Lower guide rail chain needs to come out to remove. Lower tensioner doesn't need the chain to be removed. You'll see when you get into it
  5. Junior Member
    May 13th, 2011
    2000 gti glx 12v
    01-08-2013 04:24 PM #5
    Thank you for your reply/answer. One last question I have to remove the upper chain before removing the lower right?
