Results 1 to 20 of 20
Thread: Clicking clutch
  1. Junior Member
    Sep 13th, 2011
    2005 silverstone gti
    05-30-2012 12:52 PM #1
    Got my car a few months ago, and ive been having a problem with the clutch making a loud, repetitive clicking sound when the clutch pedal is both pushed in and when it is let out. The sound appears to come from the transmission area, not from the pedal itself. ONLY happens when the car is warm. Seems fine when i first drive it in the morning. Any ideas? It is a 2005 1.8t gti with 83,xxx miles.
  2. Member CULVER's Avatar
    Jun 1st, 2009
    845; NY
    Silverstone
    05-30-2012 01:03 PM #2
    any chance the clicking your hearing is an axle?
    KlutchRepublik / ORT / N.E.R.D. Castle GTG
    Quote Originally Posted by GaugeDoisher View Post
    Did you use a vibrator as a tripod?
  3. Junior Member
    Sep 13th, 2011
    05-30-2012 01:10 PM #3
    It will make this sound if i push the clutch in while the car is not moving at all, so I believe the axels can be ruled out.
  4. Member
    Aug 2nd, 2010
    Athens, Ohio
    99 Jetta TDI, 00 Golf 2.0, 81 Rabbit pickup vr6, 02 TDI jetta
    05-30-2012 01:12 PM #4
    broken/bent clutch fork
    Athens Euroworks, http://www.athenseuroworks.com/
    Owner, mechanic, diagnostician, parts specialist, receptionist, custodian, you get the point
  5. Junior Member
    Sep 13th, 2011
    05-30-2012 01:16 PM #5
    Would a bent or broken clutch fork have any other symptoms beside the clicking sound?
    -I also forgot to mention that i can feel the clicking in the pedal
  6. Junior Member dukeIV's Avatar
    Apr 27th, 2012
    Wichita, Ks
    2003 VW GTi
    05-30-2012 01:20 PM #6
    broken clutch fork is your best bet. I just had the same problem two weeks ago. made clicking sound and then my whole clutch went out. It's a weak clutch fork from the factory.
    duke
  7. Junior Member
    Sep 13th, 2011
    05-30-2012 01:30 PM #7
    Is it safe to assume this is going to be a difficult repair? From what i looked up it seems like a lot of labor to get to the clutch fork. I usually fix my own car, but i have never worked on a clutch assembly before
  8. Junior Member
    Sep 13th, 2011
    05-30-2012 03:08 PM #8
    anybody have any other inputs other than the clutch fork?
  9. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    05 gti , 01 cbr929rr, bicycle.
    05-30-2012 03:12 PM #9
    does it almost sound like a squeek and click? can you kind of feel it in the pedal
    Dubstatic
    REP860
    CornStatuS
  10. Junior Member
    Sep 13th, 2011
    05-30-2012 03:19 PM #10
    Not so much of a squeek, but a very distinct clicking sound. When i fully depress the clutch it clicks maybe 8 times? Definitely coming from the transmission area, and the car does not have to be moving for the sound to happen. I can keep it in neutral, or in any other gear and it will make the sound It is less noticible when the car is moving
    edit*---yes i can feel it in the pedal
  11. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    05-30-2012 03:57 PM #11
    its the shaft where the throw out bearing rides on. mine has been doing this for a long time. gets worse when its hot out.
    Dubstatic
    REP860
    CornStatuS
  12. Junior Member
    Sep 13th, 2011
    05-30-2012 04:03 PM #12
    Is there any way to fix this? Or do you just let it go
  13. Junior Member
    Sep 13th, 2011
    05-31-2012 11:03 AM #13
    anyone else experiencing this problem? any solutions out there?
  14. Member Fastvolks's Avatar
    Apr 30th, 2003
    Somewhere in MA
    MK4 & MK6 GTI • 1986 Audi 4000CS Quattro
    05-31-2012 11:20 AM #14
    Are you sure this isn't the Clutch master cylinder that you're hearing? It sits right under the clutch pedal, they have been known to make a squeak or clicking sound, I had to replace mine.
  15. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    05-31-2012 11:21 AM #15
    I currently have a similar problem..a couple people told me it could be possible flywheel chatter..I also have an 05 gti 1.8t and mine has exactly 90k
    my car is at a friends cuz he's fixing a couple other things and should be able to test it out when I get to his house today after work.
    Does the engine shake at all if the hood is popped and the cluth is pushed in?..
    I'll update once I see if it goes away with some of the other fixings he did. GL
    faceoff
    Quote Originally Posted by the mad conductor View Post
    So my new girlfriend doesn't give Dome?
    Quote Originally Posted by 1.8Tquattro View Post
    You spelled ex-girlfriend wrong.
  16. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    05-31-2012 11:23 AM #16
    you only get flywheel chatter when taking off or right after you shift and let the clutch out.
    Dubstatic
    REP860
    CornStatuS
  17. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    05-31-2012 11:25 AM #17
    ^^thanks. It definitely did that trying to accelerate from a stop..almost like it was lagging in first gear and hesitating until it caught on and went.
    faceoff
  18. Junior Member
    Sep 13th, 2011
    05-31-2012 11:35 AM #18
    -Ive thought about the slave or master cylinders. However, the sound comes from the transmission area, not near the pedal...possibly the slave cylinder then?
    -I dont believe the engine shakes with the clutch pushed in, but im at work right now so i cant check. I also cant imagine it is flywheel chatter because the sound is directly correlated to pushing the clutch in and out. The slower I push the clutch in, the slower it clicks. Same amount of clicks no matter how fast I push the clutch in though.
  19. Member
    Aug 2nd, 2010
    Athens, Ohio
    05-31-2012 12:11 PM #19
    Quote Originally Posted by Hustle-DubS View Post
    that's dmf failure though, right?
  20. Junior Member
    Sep 13th, 2011
    06-07-2012 10:38 AM #20
    Any more insight on this problem or possibly how to fix it? This sound will happen when the car is not even turned on. Anyone have input other than throw out bearing or clutch fork?
