I wasn't able to find much info on these rims when I got them, but they are a German ATF brand, no centercaps.
All 4 have been sandblasted and two color powdercoated inside and out, black centers, silver edges. The line between the two colors is ok.
All 4 have mounted and balanced tires on them- Falken brand, Zilex ZE912, in 195/50 R15 size. 360 treadwear, AA traction, and A temp.
They have a 32mm positive offset. The rims are 8.5 inches lip to lip, and 7.5 bead to bead. The mounting surface is 5.5 inches from the edge of the back side lip.
3 of the tires are about 80% tread, and one is about 40-50%. The tires themselves all have a little fender rash on the outer edge, not bad though.
$350 dollars for the set, plus shipping. Local pickup is fine, I have no problem shipping also and will give you an accurate quote to mail them. Rims are located in Pawtucket RI, bolt them on and drive, nothing needs to be done to use these
