Results 1 to 3 of 3
Thread: 01-Engine -- Status: Malfunction 0010
  1. 05-30-2012 05:00 PM #1
    Hi Guys,
    I need someone who knows what is that mean...pls help!!!!!!
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 DH HW: 028 101 186 4
    Component: R4 1,9L EDC G000SG 6093
    Revision: 12345678 Serial number: SEZ7Z0D2618193
    Coding: 0050071
    Shop #: WSC 00221 464 06852
    VCID: 6CDDB5144F90E8E
    1 Fault Found:
    18104 - Powertrain Data Bus
    P1696 - 000 - Implausible Message from Steering Column Controller
    Freeze Frame:
    RPM: 882 /min
    Torque: 30.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.06 V
    Bin. Bits: 11001000
    Bin. Bits: 00000000
    (no units): 1.0
    Readiness: 0 0 1 1 1
  2. 06-12-2012 05:09 AM #2
    It’s hard to find sharp people on this topic, I have the same problem with you.
  3. n00b
    Jun 25th, 2012
    Curacao
    2002 Seat Leon Cupra 4
    06-25-2012 09:43 PM #3
    From what I found on the net it seems to be either u have a prob with your cruise-control (or in case u dont have 1) probs with the steering column position sensor.
    here is a tread that give more detail
    ( http://uk-mkivs.net/forums/p/470866/3232532.aspx )
    Hope this helps
