Results 1 to 7 of 7
Thread: Coolant leak, please help a noob!!
  1. 05-30-2012 06:26 PM #1
    Hey Guys,
    My wife's 2002 1.8t jetta is leaking coolant. I popped the hood and identified this part as the culprit. It was kinda "pumping" the coolant out of a leaky seal or something where the hose connects. it's located right between the radiator and the engine. Is this the water pump or something else entirely? I've worked on her car and I used to have a passat, so i'd like to try and fix it myself if possible, just need a little direction. Any and all advice will be greatly appreciated! Thanks in advance!
    here is where it is located:
    and a little close for clarity:
    sorry for the huge pics, I couldn't figure out how to use the image thing.
    thanks!
  2. Member EURidahO's Avatar
    Jul 10th, 2006
    Boise, ID
    03 1.8t GTI, 85 8v GTI
    05-30-2012 06:46 PM #2
    Not the water pump, that's located on the timing belt side of the block. I wanted to say Secondary Air Injector, but it looks too small...
    50 Trim BT
    Build Thread
    Jun 21st, 2010
    Darlington
    05-30-2012 07:49 PM #3
    Aux. water pump?
  4. 05-30-2012 10:55 PM #4
    Yeah I've ruled out water pump seeing as that is no where near this, nor is the mystery part connected to the timing belt. It seems to be pumping coolant, so maybe aux. water pump, i'll try to check that out. Does anyone know of a good site to look at parts diagrams? Thanks
  5. Junior Member Ryan 1.8T's Avatar
    Jan 30th, 2012
    Hedgesville, WV
    2004 jetta 1.8T 5 speed
    05-31-2012 06:30 AM #5
    aux water pump?!?!?!?
    99.5 jetta 2.0l 5 speed:gone, 91 jetta 1.6l n/a 5 speed:gone, 04 jetta 1.8T 5 speed
    instagram @ryan18t
    Jan 4th, 2007
    MA
    2004 Jetta GLS 1.8T
    06-05-2012 09:04 AM #6
    that's the auxiliary water pump or the electric powered water pump. it always runs when you shutdown the engine for around 10 minutes. i had that replaced on my car too since it was leaking coolant. very easy to replace.
    Quote Originally Posted by clamskittles View Post
  7. Member woteg's Avatar
    Apr 7th, 2009
    nubraska
    06 a3; 05 gli; 93 fox
    06-05-2012 09:10 AM #7
    yeah its the aux water pump, comes on automatics
    Quote Originally Posted by Hawaii5-0
    never let a woman touch your car, it should have never been in the kitchen for her to touch
