Try reading this post...
http://www.automotiveforums.com/t385...not_crank.html
Don't know if it fully applies, but may help.
#1
88 wagon wont start, the key gets turned and starter makes clicking noise? tryed taking the starter off and cleaning all the connections, still nothing. Battery is also fully charged. Has anyone had this problem and what did they do
cheers tom
#2
#3
thanks for the link! ill have to try those things when its light out tomorrow
cheers tom
#4
Check the ground straps, especially the one from the back of the cylinder head to the main ground lug on the firewall. Make sure those connections are clean and tight.
#5
If the starter just clicks and you have good battery voltage, it could be the starter itself.
Originally Posted by 90quattrocoupe
