Results 1 to 32 of 32
Thread: 2013 Mercedes GL63 AMG Revealed, Arrives Early Next Year
  1. Member omoderncultureo's Avatar
    May 1st, 2011
    Galveston, TX/Ventura, CA
    05-30-2012 10:25 PM #1
    Quote Originally Posted by Press Release
    Montvale – Luxury and refinement, distinctive design, outstanding safety and classic Mercedes dynamics – the new GL63 AMG high-performance SUV combines the latest technology with an extensive array of standard equipment and perfect comfort for up to seven passengers. Exceptional refinement comes courtesy of the AMG 5.5-liter V8 biturbo engine with a peak output of 550 hp and maximum torque of 560 lb-ft. The AMG RIDE CONTROL sports suspension with ACTIVE CURVE SYSTEM delivers compelling dynamics and classic Mercedes handling.
    The MY 2013 GL350 BlueTEC, GL450 and GL550 arrive in U.S. dealerships in September 2012. The MY2013 GL63 AMG is expected arrive at U.S. Mercedes-Benz dealerships in the first quarter of 2013.
    Ola Källenius, CEO of Mercedes-AMG GmbH: "With the new GL63 AMG, our range of performance-oriented SUVs is now complete. Alongside the outstandingly versatile ML63 AMG and the recently launched G63 AMG (U.S. debut in August) and G65 AMG (n/a U.S.), the GL63 AMG sets clear accents in the fields of dynamics and style. The GL63 AMG combines the first-class comfort of the S-Class with the performance of an AMG sports sedan and is utterly unique in its segment."
    The AMG 5.5-liter V8 biturbo engine delivers the perfect prerequisites for a refined ride and performance that is typically AMG. One glance at the technical data delivers all the evidence you need. The peak output of 550 hp and maximum torque of 560 lb-ft delivers absolutely first-class performance. The GL63 AMG accelerates from 0 to 60 mph in 4.9* seconds, while the top speed stands at 155 mph (electronically limited).
    The AMG eight-cylinder with the acronym M157 is equipped with an innovative package of high-tech features that includes spray-guided gasoline direct injection, piezo injectors, bi-turbocharging, air-water intercooler, a fully aluminum crankcase, four-valve technology with variable camshafts and alternator management, plus the ECO stop/start system.
    An overview of the key data:
    Displacement: 5461 cm3
    Bore x stroke: 98.0 x 90.5 mm
    Compression ratio: 10.0 : 1
    Power: 550 hp @ 5250-5750 rpm
    Max. torque: 560 lb-ft @ 2000-5000 rpm
    Engine weight (dry): 450 lbs
    Acceleration 0-100 km/h: 4.9 s**
    Top speed: 155 mph*
    Power delivery to all four permanently driven wheels is handled by the AMG SPEEDSHIFT 7-Speed automatic transmission. Equipped with three modes and an automatic double declutching function for downshifting, the seven-speed automatic offers an impressive degree of versatility. The ECO stop/start function is active in the Controlled Efficiency mode (C) and switches off the eight-cylinder engine as soon as the vehicle comes to a standstill. "C" also comes with a milder throttle and transmission setup with early gearshift. Pulling away generally takes place in second gear. A green "ECO" symbol in the AMG instrument cluster advises the driver that the ECO start/stop function is active.
    In the Sport (S) and manual (M) modes, not only is the ECO stop/start function disabled, the engine/transmission combination also has more spontaneous reactions for a considerably more agile feel. In these modes, the brief and precisely defined retardation of ignition and injection during upshift under full load delivers faster shift times and a thrilling acoustic effect.
    Greater efficiency and performance
    For greater efficiency, the AMG SPEEDSHIFT 7-Speed automatic transmission is equipped with a highly efficient torque converter with centrifugal pendulum vibration absorber, friction-reduced bearings and transmission oil temperature management. Also contributing to reduced fuel consumption are friction-minimized axle drives, the electromechanical AMG speed-sensitive sports steering, optimized belt drive and on-demand control of all auxiliary units and pumps.
    Mercedes-AMG uses a standalone transfer box for the 4MATIC permanent all-wheel drive that enhances the dynamic characteristics by splitting the drive 40:60 between the front and rear axles. Furthermore, the AMG RIDE CONTROL sports suspension with AIRMATIC package, consisting of air suspension, special struts, automatic self-leveling function and Adaptive Damping System (ADS), is combined with the ACTIVE CURVE SYSTEM. This is standard equipment and has been specifically adapted by AMG. It incorporates active anti-roll bars on the front and rear axles that reduce bodyshell roll angle under cornering for enhanced agility and driving pleasure. At the same time, the ACTIVE CURVE SYSTEM raises stability and thus safety, especially at high speeds.
    Roll stabilization, springs and damping adapt automatically to the prevailing driving conditions and offer excellent ride characteristics, as well as exceptionally high stability. At the touch of a button, the GL63 AMG driver can choose between two suspension modes "Comfort" and "Sport". The full air suspension system is speed sensitive and lowers the bodyshell at higher speeds to minimize drag, while increasing stability.
    The AMG-specific elastokinematics on the front axle and the stiffer rear axle stabilizer deliver even greater steering precision. The reinforced driveline ensures the best possible transmission of power to the wheels and hallmark Mercedes reliability. The 4ETS electronic traction control system optimizes grip under varying surface conditions.
    AMG speed-sensitive sports steering, AMG high-performance brake system
    The electromechanical AMG speed-sensitive sports steering is equipped with variable power assistance that adapts in accordance with the selected suspension mode. This system also helps to save fuel, as the power assistance only consumes energy when the driver is actually turning the steering wheel. The GL63 AMG runs as standard on machine polished, twin five-spoke 10 x 21 AMG alloy wheels sporting 295/40 R 21 tires. For the shortest possible braking distances and excellent fade resistance, there is the AMG high-performance brake system with ventilated and perforated discs at all four corners – 15.4 x 1.4 inches (front) and 13.6 x 1.0 inches (rear).
    Masculine design with performance focus
    Distinctive, masculine, unmistakable – these are the characteristics that define the design of the GL63 AMG. The styling fundamentals of the new GL – powerful dynamics and sporty elegance – have been further enhanced by Mercedes-AMG with specific elements that emphasize the stunning performance of this V8 top model. The hallmark, upright GL radiator grille with its central Mercedes star is augmented by high-gloss black louvers. The AMG styling includes the front valance, which features large air intakes for effective airflow to the cooling modules. On the lower air intake, shaped in true AMG fashion in the shape of a stylized "A", is a narrow gap beneath a fine black fin, through which air flows directly to the cooling modules – a perfect combination of design and technology. The chrome trim element beneath this creates visual breadth and blends perfectly with the surrounds for the LED daytime running lamps incorporated into the outer air intakes.
    The AMG front valance transitions beautifully into the flared fenders. The large 21-inch AMG alloy wheels clad in wide 295 tires add almost one inch to either side of the vehicle. The side view is further enhanced by "V8 BITURBO" badges on the fenders and illuminated sills with an aluminum finish. The flared fenders at the rear connect into the AMG rear valance, which also sports a distinctive chrome trim strip, as well as a black diffuser-type panel. A visual and acoustic highlight is provided by the two chromed twin end pipes of the AMG sports exhaust system.
    Exclusivity and dynamics dominate the interior
    Enormous attention to detail, perfect ergonomics and a generous amount of space characterize the interior of the GL63 AMG, where the emphasis is on exclusivity and dynamics. All seven seats in the high-performance SUV are upholstered in premium leather. The electrically adjustable AMG sports seats feature double stitching in a contrasting color, as well as AMG badges in the backrests of the front seats and the outer rear seats. The dashboard, armrests and door trim are finished in MB-Tex with double stitching.
    The AMG performance steering wheel features a four-spoke design and offers optimum vehicle control with perforated leather grips, a flattened bottom and aluminum shift paddles. Four instrument dials in the AMG instrument cluster provide the driver with all necessary information. Positioned in the center is a color TFT monitor, which incorporates an AMG logo and the AMG main menu.
    Further standard equipment in the GL63 AMG includes:
    • AMG running boards in stainless steel
    • AMG floor mats
    • AMG sports pedals in stainless steel with rubber studs
    • Active Parking Assist
    • ATTENTION ASSIST
    • ACTIVE CURVE SYSTEM
    • Bi-xenon headlamps
    • COMAND System with Bluetooth® and USB interface
    • COLLISION PREVENTION ASSIST
    • Easy-entry system for the rear seat on both sides
    • Electrically operated tailgate
    • Electric tilt/sliding glass roof
    • Intelligent Light System (ILS)
    • KEYLESS-GO
    • Multi-contour seats with massage function for driver and front passenger
    • Memory package (incl. electrically adjustable driver and front passenger seats, steering column and exterior mirrors with memory function, plus 4-way lumbar support for driver and front passenger)
    • Crosswind stabilization
    • 3-zone automatic climate control
    • AMG performance steering wheel with DINAMICA microfiber grip
    • Red brake calipers
    Further special equipment (extract):
    • 360° camera
    • Active Lane Keeping Assist and Active Blind Spot Assist
    • Trailer hitch with electric release
    • Bang & Olufsen BeoSound AMG high-end surround sound system
    • BAS PLUS brake assist
    • DISTRONIC PLUS (including PRE-SAFE® Brake)
    • Panorama sliding roof, panorama roof over all three seating rows
    More Photos
  2. Member Phil Pugliese's Avatar
    May 18th, 2000
    Reno, NV
    2010 Jetta Sportwagen TDI
    05-30-2012 10:31 PM #2
    Inbefore...well..inbeforewhatever.
    CLICK * POINT * CHUTE
  3. Member Troike's Avatar
    Jul 21st, 2003
    poOregon
    saab 99 notchback
    05-31-2012 12:03 AM #3
    Quote Originally Posted by Phil Pugliese View Post
    I've never been one to post this, but I believe it belongs here
    << so it Hz >>
    Quote Originally Posted by A.Wilder View Post
    for every good post in this thread there are 10 illiterate people mashing buttons on their keyboard
  4. Banned HideYoKids's Avatar
    Jul 12th, 2011
    Under a lift.
    '73 Reg Beetle, '95 855, '97 Golf CL, '00 Forester S, '02 Jetta TDI
    05-31-2012 12:05 AM #4
    would rather have G63 or G65 AMG
  5. 05-31-2012 12:14 AM #5
    Interesting, but boy is that going to be pricey.
  6. 05-31-2012 12:21 AM #6
    Interesting...but make my AMG SUV a G-Class or the smaller ML. Heck, I'd even rather take an AMG R-Class over a GL. The GL just doesn't do much for me. Maybe it's all the soccer moms on their cell phones.
  7. Member TangoRed's Avatar
    Sep 7th, 2005
    Cincinnati, OH
    2010 BMW 528i
    05-31-2012 12:28 AM #7
    I love the GL for some reason, despite the fact they're almost always driven my moms and dads driving their families around.
    Quote Originally Posted by DamienR8 View Post
    in 2038 you will have the ability to think of a car, then your body will actually turn into a car, then you will die in an accident.
  8. Member Ross1013's Avatar
    May 25th, 2012
    NoVA
    2009 Si sedan and 2012 Crosstour 4WD
    05-31-2012 12:31 AM #8
    My first post here...the previous GL hid its size very well. I'd imagine this is going to be an astounding car.
  9. Member 1Point8TDan's Avatar
    Sep 4th, 2003
    Calgary, AB
    D40 Frontier CC 4X4, 3BG Passat .:RS Variant
    05-31-2012 01:19 AM #9
    Quote Originally Posted by TangoRed View Post
    Same here. Saw an BlueTec today and wanted it. The AMG version is silly in this car.
  10. Member IridiumB6's Avatar
    Nov 29th, 2010
    Toronto, Canada
    2006 Passat 2.0T, 2006 Jetta 2.5, 2008 Volvo XC90 3.2
    05-31-2012 01:44 AM #10
    As opposed to?
  11. Member VR6 NRG's Avatar
    Apr 23rd, 1999
    Anthem, AZ
    2013 Audi allroad / 1996 VR6 Cabrio on air
    05-31-2012 02:00 AM #11
    buy it now for $110k cause in a year it will be worth $60k and you'll hate yourself because you now own a pointless vehicle that will have horrid resale value but make the 2nd owner very happy because you took the depreciation in the butt like a champ.
    2013 Audi allroad Glacier White Metallic
    1996 Cabrio build thread http://forums.vwvortex.com/showthrea...6-build-thread
    2004 Reflex Silver R32 stock and super clean
    I Sell Audi's in AZ
  12. Member GLI Dan's Avatar
    Sep 28th, 2006
    Tallanasty
    04 GLI Sold, 2004 330ci SMG
    05-31-2012 02:25 AM #12
    Quote Originally Posted by VR6 NRG View Post
    because when I have the money to waste on this super soccer mom mobile I would care about resale
    will the TCL ever be able to comprehend having money and/or new car purchasing/leasing?...probably not. Lets all just buy used cars.
    Quote Originally Posted by tampaSi View Post
    You could not give me an auction-rat sub $10k E39 M5 for all the blow in Cartegena. Which probably would have at some point been in the trunk of said M5.
  13. Member VadGTI's Avatar
    Feb 24th, 2000
    Hollywooooooood, CA
    05-31-2012 02:35 AM #13
    So the one bwk and I spotted was the GL63!
    Sent from my T-Mobile G2 using Tapatalk 2
    Fizzy - Team My Little Pony
  14. Member Gates311's Avatar
    Apr 23rd, 2008
    Minneapolis
    Evo Xs & Porsche
    05-31-2012 03:43 AM #14
    I've been into the GL's since they debuted years back, especially the G550's with the Sport package bits.. This is so awesome. Pointless, for sure. But so awesome, would be fun to show some friends around the city with. Or whatever, it's just sweet. 550hp stock, tune and pipes it'd make 650hp wheel .
  15. Member Gates311's Avatar
    Apr 23rd, 2008
    Minneapolis
    Evo Xs & Porsche
    05-31-2012 03:47 AM #15
    Also, looks well proportioned for being so big.
  16. Member Geechie_Suede's Avatar
    Jan 17th, 2009
    Grand Rapids, MI
    1990 Lexus LS400
    05-31-2012 08:24 AM #16
    So now the GLK is the only Merc without an AMG model?
    Previously Owned: 96 LR Disco SD/65 Corvair Monza/93 Corolla Wagon DX/89 LeSabre Limited/96 Camry LE99 Regal GS/95 Accord EX/98 CSVT
    Current:90 LS400
  17. Member HASSELHOF's Avatar
    Feb 2nd, 2005
    Long Island
    '13 Cadillac ATS 2.0T RWD,'13 Lexus RX350 AWD, '68 Chevy C10 SB Stepside, '69 MB 280sel
    05-31-2012 09:23 AM #17
    Quote Originally Posted by HideYoKids View Post
    Can I ask why? The G is going to have much worse road manners then the GL. Add that much more power, while fun, is even more rediculous. The GL would seem to be the better platform for an AMG variant. As an aside, my father-in-law choose to purchase a GL over both the ML and G due to its more comfortable and smoother ride. That longer wheelbase does help.
    so it goes... ಠ_ಠ
  18. Member hugoaswho's Avatar
    Sep 24th, 2006
    PLanet Zurcon 114453 Alpha
    2013 Candy White GLI Autobahn w/ Nav
    05-31-2012 09:40 AM #18
    Ahhh...the New Jersey Housewife/ Trophy Wife truck of choice
    Saw one on the way to work today...must have been a MB employee...
    PSN |AKS29|
    The fly cannot be driven away by getting angry at it.
  19. Member
    Mar 25th, 2009
    Fairfax, VA
    04 M3, 99 A4 2.8
    05-31-2012 09:44 AM #19
    I love me some SUVs with GTFO powah. But like most of the others I'll just add this to the list of massive overkill SUVs I'll never own.
  20. 05-31-2012 09:52 AM #20
    Yup, this is my wife's next car but the bluetec version
  21. Member ambit's Avatar
    Feb 2nd, 2004
    Royal Oak, MI
    05 CLK55 AMG, 04 VFR 800
    05-31-2012 09:54 AM #21
    Quote Originally Posted by Geechie_Suede View Post
    well technically the new G-class & SL-class AMG's aren't out yet. And the R-class doesn't have one (anymore).
    Otherwise yes, not counting MB heavy trucks segment.
  22. Member Accidental L8 apex's Avatar
    Sep 26th, 2008
    Podunk, Ohio
    my torque laughs in your "man pedal's" general direction
    05-31-2012 10:06 AM #22
    I know, I too can't believe more people don't buy these, strip them out for weight and track the bejeesus out of them. Hauling families around. How passe'.
    A list of mods, all cars ever owned and something cribbed from a book, song and/or movie were all just here. Sorry you missed out on my unique, snowflake-like individuality.
  23. Senior Member Fritz27's Avatar
    Mar 8th, 2003
    Gulf Coast, FL
    05-31-2012 10:15 AM #23
    Quote Originally Posted by Accidental L8 apex View Post
    It does seem strange that the target market for a 7-passenger SUV is people with families.
    PSN: PhilipGTI
    Get lost santa
  24. Member windycityvdub's Avatar
    Jan 21st, 2008
    Nashville, TN
    2012 MINI Cooper S, 1986 BMW 528e BABE Rally Beater
    05-31-2012 10:19 AM #24
    I drove a last gen ML63 yesterday. Did not like.
    As far as the GL, hopefully they fixed the reliability of the Airmatic suspension. I see SO many GLs with blown struts/shocks/bags/everything.
  25. Member caddy addict's Avatar
    Mar 2nd, 2002
    Princeton Texas
    66 Galaxie XL vert, 2010 ML350, 2011 TDI DSG Jetta, 89 Jeep Comanche, 87 4Runner Turbo, 98 Dodge V10
    05-31-2012 11:34 AM #25
    We have our first ML63's coming in and they are in the 110-120k Range depending on options...
  26. Member TangoRed's Avatar
    Sep 7th, 2005
    Cincinnati, OH
    2010 BMW 528i
    05-31-2012 12:23 PM #26
    Quote Originally Posted by IridiumB6 View Post
    As opposed to?
    Did I say it was weird that they were being driven by moms and dads with families in tow, or that it was a bad thing? Most 22 year old males I know don't take a strong liking to family mobiles. That was all I was saying. Jesus TCL.
  27. Member Accidental L8 apex's Avatar
    Sep 26th, 2008
    Podunk, Ohio
    05-31-2012 12:45 PM #27
    And I'm to assume you're 22 now? Or take the time to read everyone's profile, hope they added their age and then base my posts on that research? You pointed out the obvious and we took that as you teeing-one-up for us to knock a few out over, no biggie.
  28. 05-31-2012 01:02 PM #28
    What is the pricing on these things?
    I want a 7 passenger hi po sled...
  29. Member 71DubBugBug's Avatar
    Dec 3rd, 2006
    Chicago
    91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
    05-31-2012 01:16 PM #29
    the gl550 wasnt fast enough for rich soccer moms?
    These have the turbos integrated into the exhaust manifolds?
    wonder how much those will be to replace
  30. Member torquepower85's Avatar
    Aug 17th, 2010
    2007 focus SE, 65 vette sting ray, 00' S class
    05-31-2012 01:17 PM #30
    i like the coupe amg better but that's not really on topic now is it...
  31. Member masa8888's Avatar
    May 5th, 2003
    Reston VA
    2013 Audi S4 2013 VW Jetta TDI
    05-31-2012 01:20 PM #31
    Quote Originally Posted by WhatBlueVW View Post
    Not cheap. The new G550 starts out at $85,000. The S550 starts at $94,000 vs. the S63 which starts at $139,000. If the G63 follows the same formula, it will be around $125k
  32. Member TigerinColorado's Avatar
    Jul 16th, 2007
    Hilton parking lot.
    Hertz Gold + Rewards
    06-01-2012 02:24 PM #32
    Welcome to Benz.
    Not gonna lie, it looks better than the outgoing model (unlike the ML).
    Quote Originally Posted by Kyle C
    The world runs on marketing, and in the case of winter tires Subaru has proven beyond a reasonable doubt that any round, rubber-ish object that holds a bit of air and passes as a tire will get you through the snow just fine, but only if it is attached to a vehicle with AWD/4WD.
