VWVortex.com - Fault code 15604 - ROD - Unknown Error Code
    Results 1 to 17 of 17
    Thread: Fault code 15604 - ROD - Unknown Error Code
    1. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      Several Citroens, Ibiza ST (6J8)
      05-31-2012 06:29 AM #1
      I have an Ibiza 6J ST, MY2011. Last evening the glow plug light started to flash while drive about 100 km/h on CC. The car was stopped and the engine turned off. When the engine was started again the light didn't flash anymore.
      This morning I hooked up the car to VCDS and this error showed up, even with aggressive-mode turned off. I went to the dealer who checked the engine with their VAS software. It did not recognize the code either!!! The only thing they could do was clearing the error-log.
      We're going on holiday with the car this Saturday. Has anyone seen this error before? Can I expect trouble with the car or can I sleep without worries?
      Autoscan:
      Code:
      Thursday,31,May,2012,11:06:49:47062
       VCDS Version: Release 11.11.3 (x64)
       Data version: 20120401
       Chassis Type: 6R0
       Scan: 01 03 08 09 10 15 17 19 25 2E 44 4B 56 61 77
       VIN: VSSZZZ6JZxxxxxxxx
       01-Engine -- Status: Malfunction 0010
       04-Steering Angle -- Status: OK 0000
       08-Auto HVAC -- Status: OK 0000
       09-Cent. Elect. -- Status: OK 0000
       10-Park/Steer Assist -- Status: OK 0000
       15-Airbags -- Status: OK 0000
       19-CAN Gateway -- Status: OK 0000
       2E-Media Player 3 -- Status: OK 0000
       4B-Multifunc. Module -- Status: OK 0000
       56-Radio -- Status: OK 0000
       61-Battery Regul. -- Status: OK 0000
       77-Telephone -- Status: OK 0000
       Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
          Part No SW: 03P 906 021 AA    HW: 03P 906 021 AA
          Component: R3 1.2 DCM3.7 H03 7638
          Revision: 12004001    Serial number:
          Coding: 00114014032401080000
          Shop #: WSC 99999 1023 2097151
          ASAM Dataset: EV_ECM12TDI03103P906021AA 001003
          ROD: EV_ECM12TDI03103P906021AA.rod
          VCID: 67D7480C9E76F51
       1 Fault Found:
                 - F4 [008]
                 Intermittent - Confirmed - Tested Since Memory Clear
                    Freeze Frame:
                           Fault Status: 00000001
                           Fault Priority: 2
                           Fault Frequency: 2
                           Mileage: 0 km
       Readiness: 0000 0000
       Address 03: ABS Brakes (J104)       Labels: 6J0-907-37x-ESP.clb
          Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
          Component: ESP8.2i front H05 0001
          Revision: --------
          Coding: 110224DB817000B9882D24E681D200521300
          Shop #: WSC 04941 000 00000
          VCID: 8609E588353C8C9
       No fault code found.
       Address 08: Auto HVAC (J255)       Labels: Redir Fail!
          Part No SW: 6J0 820 043 B    HW: 6J0 820 043 B
          Component: Climatronic   H07 0505
          Revision: S0000000
          VCID: 234F1C1C22CED91
       Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
          Part No SW: 6R0 937 088 B    HW: 6R0 937 088
          Component: BCM PQ25 Re4  H46 0321
          Revision: BU046001    Serial number: 0328 190100843
          Coding: 23880BE8C8610100013005F07E8B8EC8FF8060FF7E882049200000000000
          Shop #: WSC 17603 211 91242
          VCID: 3D7BCA64A46A8F1
          Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
          Component: RLS 040710 05  54  0403
          Coding: 17302D
          Subsystem 2 - Part No SW: 6R0 959 801 N    HW: 6R0 959 801 N  Labels: 6R0-959-801.CLB
          Component: J386__TSG_FT  003 3110
          Coding: 420000
          Subsystem 3 - Part No SW: 6R0 959 802 Q    HW: 6R0 959 802 Q
          Component: J387__TSG_BT  003 3110
          Coding: 420000
          Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
          Component: J388__TSG_HL  002 3121
          Coding: 000000
          Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
          Component: J389__TSG_HR  002 3121
          Coding: 000000
       Address 10: Park/Steer Assist (J446)       Labels: 6J0-919-475.clb
          Part No SW: 6J0 919 475 B    HW: 6J0 919 475 B
          Component: PARKHILFE 4K  H07 0008
          Revision: --------    Serial number: 80331018609453
          Coding: 000007
          Shop #: WSC 06402 785 00200
          ASAM Dataset: EV_SE250ParkiAssis2 S01006
          ROD: EV_SE250ParkiAssis2.rod
          VCID: 356BD244945A571
       Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
          Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
          Component: VW10AirbagA09 H09 0020
          Revision: --------    Serial number: 003GX0046DD2
          Coding: 003039
          Shop #: WSC 06401 785 00200
          ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
          ROD: EV_AirbaVW10BPAVW250_SE25.rod
          VCID: 4A9191B8EDA4289
          Crash sensor for side airbag; driver side:
          Serial number: 3495RRB404V6RJQI6HG2
          Crash sensor for side airbag; passenger side:
          Serial number: 3505RRB40556T8MI0GO0
       Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
          Part No SW: 6J0 920 802 J    HW: 6J0 920 802 J
          Component: KOMBI         H05 0404
          Serial number: 00000000000000
          Coding: 510A00
          Shop #: WSC 99999 123 12345
          ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
          ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
          VCID: 2F67E02C76066D1
       Address 19: CAN Gateway        Labels: 6R0-907-530-V1.clb
          Part No SW: 6R0 907 530 B    HW: 1K0 907 951
          Component: J533  Gateway   H28 0020
          Revision:   H28       Serial number: 040710F1001448
          Coding: 7D235F00080000003202
          VCID: 3261E958AD34409
       Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
          Part No SW: 5K0 953 234     HW: 5K0 953 234
          Component: IMMO          H05 0404
          Serial number:
          Coding: 000000
          Shop #: WSC 00000 000 00000
          ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
          VCID: EAD1B1380D64489
       Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
          Part No SW: 6J0 035 342 C    HW: 6J0 035 342 C
          Component: SG EXT.PLAYER H13 0111
          Revision: A1001003    Serial number: 7668329616
          Coding: 020000
          Shop #: WSC 64564 324 38760
          VCID: 244D1F0027C0DE9
       Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
          Part No: 6R0 423 156 B
          Component: LenkhilfeTRW        V277
          Coding: 11211
          Shop #: WSC 06402
          VCID: 2F67E02CEA066D1
       Address 4B: Multifunc. Module        Labels: None
          Part No: 6J0 959 441 A
          Component: MF-Modul       0007 0001
          Coding: 0000002
          Shop #: WSC 17603 003 00000
          VCID: 3163E654A8327B1
       Address 56: Radio (J503)       Labels: 6J0-035-153.clb
          Part No SW: 6J1 035 153 F    HW: 6J1 035 153 F
          Component: Radio         H10 0107
          Revision: R0000000    Serial number: SEZAZ1K1108232
          Coding: 0005040002
          VCID: 28550B305BE83A9
       Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
          Part No SW: 6R0 907 534     HW: 1K0 907 951
          Component: Batt.regelung H28 0020
          Coding: 0303185A
          VCID: F4EDAF4057A08E9
          Component: J367-BDM  H07 0125
       Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
          Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
          Component: TELEFON       H05 0440
          Revision: 1B001001    Serial number: 00007668349480
          Coding: 0800000001010110
          ASAM Dataset: UHVNA A01007
          ROD: UHVNA_SE25.rod
          VCID: 3261E9586534409
       3 Faults Found:
       9457169 - Positive output audio channel for speech/telephone
                 B104E 11 [000] - Short to Ground
                 Intermittent - Not Confirmed - Tested Since Memory Clear
                    Freeze Frame:
                           Fault Status: 00000000
                           Fault Priority: 0
                           Fault Frequency: 20
                           Reset counter: 0
                           Mileage: 22 km
                           Date: 2000.00.00
                           Time: 00:00:00
       13636608 - Control Module Incorrectly Coded
                 U1014 00 [000] - -
                    Freeze Frame:
                           Fault Priority: 0
                           Fault Frequency: 20
                           Reset counter: 0
                           Mileage: 22 km
                           Date: 2000.00.00
                           Time: 00:00:00
       0022 - Radio
                 U1066 00 [000] - No Communication
                    Freeze Frame:
                           Fault Priority: 0
                           Fault Frequency: 20
                           Reset counter: 0
                           Mileage: 22 km
                           Date: 2000.00.00
                           Time: 00:00:00
       End   ---------------------------------------------------------------------
    2. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      07-04-2012 11:12 AM #2
      Just an update for those who wonder:
      I've driven 3000km since the error occurred and the problem has not returned (yet). Nor does the car seem to drive any different. The ride to and from France (about 900km in one stretch, 10 hour drive...) went smooth as well.
      So the error can probably be safely ignored
    3. Junior Member Keithuk's Avatar
      Nov 17th, 2009
      Stoke on Trent, England
      2010 Golf GTD (170)
      07-04-2012 08:29 PM #3
      I've never seen a 15604 error code before either.
      Golf GTD (170) 2010, 5 Door, Shadow Blue, Flat Tyre Indicator, Service Plan, Basic Protection Pack + VCDS.
    4. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      07-05-2012 09:37 AM #4
      Then I don't feel so bad about VCDS not knowing what it means.
      What you have to understand with these newer ECUs that use the UDS/ODX protocols is that the "raw" fault code coming from the ECU cannot be interpreted without looking it up in an ECU-specific "dictionary" first, and if the ECU manufacturer doesn't include it in the dictionary they give to VW for that ECU, no scan tool will be able to tell you what it means.
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    5. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      07-05-2012 04:06 PM #5
      @Uwe: don't get me wrong. It wasn't meant as criticism on VCDS. Just tried to inform readers as complete as possible and hoped someone had seen the error before and knew where it came from.
    6. 09-29-2012 03:55 PM #6
      Hey, I have a 2011 6J Ibiza ST too, same fault code has come up for me, did you ever find out what it might be?
      How many km on average would you get from a full tank of fuel?
      Cheers,
      flipdee
    7. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      10-01-2012 03:12 PM #7
      Still no idea what it was. The car has performed without error since...
      On average it consumes 1 liter for every 24,something kilometers.
    8. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      10-22-2012 04:19 PM #8
      Today the glow plug light started to flash again, just when I turned into the street where I live. The displayed said 'STOP ERROR' (blinking to and only for a short time). Parked the car, shutdown the engine, removed the key, waited a few seconds and started the engine again. Flashing light was gone.
      Just hooked it up to VCDS, same error... Guess I'll visit the dealer sometime this week. Maybe their database has had an update. (Didn't clear the code).
      To be continued...
    9. 10-23-2012 07:39 AM #9
      Hi, This Start Stop Error also happened to me, I believe the ECU doesn't allow the start stop system to operate under certain fault conditions, I think it only happened when I had the engine check light on for me.
      *Edit* - The more I think about it, it was actually the flashing coil light that caused the error message.
      Along with the unknown error code (which as you can see occured twice)
      - F4 [008]
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 2
      Mileage: 0 km
      I also had the following.
      16396 - EGR Valve (N18)
      P0403 00 [175] - Malfunction
      MIL ON - Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Priority: 4
      Fault Frequency: 24
      Mileage: 69062 km
      16395 - EGR Valve (N18)
      Freeze Frame:
      Fault Priority: 3
      Fault Frequency: 21
      Mileage: 69070 km
      The EGR valve was replaced by my Seat Dealer, however they seemed to ignore the following fault, which has not happened again for me since the EGR valve replacement, also I haven't had any further coil or check lights since.
      15886 - Fuel Injector #3 (N32)
      P0269 00 [008] - Contribution/Balance Fault
      Freeze Frame:
      Fault Priority: 4
      Fault Frequency: 2
      Mileage: 69721 km
      I do however have a concern that I am not getting the fuel economy that I would like.
      I have roof bars attached an a small set of ladders on them most of the time, I also have a reasonably full boot continuously as I use my car for work and carry my tools around.
      I had asked my dealer if there was a software update for my ecu but they weren't terribly helpful, only to say that if there was one it would be listed in a recall notice for my VIN, which there supposedly wasn't.
      I believe the software version is 7639, I think I have seen revisions in the 8XXX on other forums for the same engine, both Seat and VW cars.
      I thought maybe an update could help fuel economy, but I might just have to do some further tests with an empty car to see what the difference is without the weight/air drag.
      Part No SW: 03P 906 021 AB HW: 03P 906 021 AA
      Component: R3 1.2 DCM3.7 H04 7639
      Coding: 00114014032501080000
      ASAM Dataset: EV_ECM12TDI03103P906021AB 001003
      ROD: EV_ECM12TDI03103P906021AB.rod
      VCID: 68D5887D935D0F58895
      I hope your dealer is able to fix your problem.
      Regards,
      flipdee
    10. 10-23-2012 02:26 PM #10
      Ok, So I spoke too soon.
      The unknown fault has happened again, literally minutes after I posted here the coil light started flashing and when checked with vcds I got:
      - F4 [063]
      Confirmed - Not Tested Since Memory Clear
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 2
      Mileage: 0 km
      Unfortunately my dealer can't take a look at the car until Thursday, and when restarting the car the coil lights gone out.
      I haven't check but I suspect "limp mode" is still active from the original scan with the light on.
      BAHH!
      Such a pain!
    11. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      10-23-2012 04:43 PM #11
      Well at least with the 1639x and 15886 error you know what's wrong
      Odd the 15604 occurred just after you posted, does your car read you forum posts
      It was not so much as a 'Start/Stop' error but more that the display said 'STOP ERROR'. My engine did not go into limp-mode though and it ran fine again today.
      Tomorrow I'll pay my dealer a visit, keep you posted.
    12. 10-24-2012 06:26 AM #12
      Hmmm,
      Thats starting to make me wonder what was actually shown on my display.
      I could've sworn it said "Start Stop Error".
      I had attempted to set cruise control just as I noticed the coil light start to flash, this could have been totally coincidental.
      I don't hold too much hope in my dealer resolving this as I believe this unknown error had also occurred within several weeks of my purchase of the new car.
      When checked at that time they told me it was a "Body control unit/module" and couldn't really tell me what was wrong so other than clean a few connectors and hope for the best didn't do much.
      cheers.
    13. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      10-24-2012 01:52 PM #13
      The dealer has sent the error code to the importer (is that a valid English phrase?). Maybe they know something their VAS-system doesn't.
      The dealers mechanics guess is that it's a software glitch and that the ECU sw should probably be updated. (which takes about an hour...) It still has the original sw, version 7638. Rev 9512 was available this February.
      Quote Originally Posted by flipdee View Post
      The Ibi is quiet sensitive to head wind, the ladders on top probably don't do the fuel consumption any good.
    14. 10-25-2012 03:37 PM #14
      Got my car back tonight from the dealer.
      I pretty much asked for the software update and thankfully they obliged.
      Component: R3 1.2 DCM3.7 H04 9522
      ASAM Dataset: EV_ECM12TDI03103P906021AB 001014
      Version 9522 - Sounds pretty new if 9512 was from Feb.
      Lets hope it fixes the unknown fault.
      What I find interesting is the software update didn't reset anything, trip computer or my long adaption adjustment increasing lane change indication from 3 flashes to 4.
      Hopefully it might help the fuel economy too, just about to fill up tomorrow morning so we'll see.
      It's a pity there isn't a change log for software updates.
      Do you have Roof Bars on your Ibiza?
      Cheers,
      flipdee
    15. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      10-25-2012 04:45 PM #15
      One of the sw updates fixes cold engine noise by injecting a bit more fuel. (pre-inject?) So in theory it would use more fuel
      I guess the engine has to get used to your driving style again so you can't say anything about fuel consumption the first, say 1500km.
      The settings you mention aren't in the Engine BCM so they should stick.
      And no, I don't have Roof bars.
      Tire pressure has some influence as well. Front tires at 2.9 or 3.0 PSI, rear at 2.8/2.9 (depending on the load).
      Word from the importer was a sw update for me aswell. Hope it fixes this. (Get back on this in a year or so )
    16. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      10-31-2012 08:31 AM #16
      Today the ECU sw was update to 9521 (odd they didn't have 9522 available). Hope this helps.
      (wasn't free of charge BTW)
    17. Junior Member My1stIbi's Avatar
      Oct 15th, 2010
      The Netherlands
      09-29-2013 04:02 PM #17
      FYI
      I haven't had the 15604 error since the sw update. Full consumption was worse the first few months but got better since then. Engine runs more silent as a plus. Last visit at the pump it ran 25km/liter (58.8 mpg). Not bad IMHO.
