VWVortex.com - Mk2 tie rod DIY?
    Results 1 to 17 of 17
    Thread: Mk2 tie rod DIY?
    1. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      Now a proud Subaru owner, I will be back with an aircooled vw!
      05-31-2012 10:56 AM #1
      Anyone know of a DIY on replacing the complete tie rod on a car that has power steering? I've looked and looked and looked with no luck. I know there is some special tool I need
      Mk4 shift knob, boot and trim ring into your mk3/mk2 DIY:
      http://forums.vwvortex.com/showthrea...ng-to-your-mk3
    2. Member weejunGL's Avatar
      Feb 2nd, 2005
      Norwegen
      MKII 16vT Syncro
      05-31-2012 11:15 AM #2
      Quote Originally Posted by jettaracer1989 View Post
      no special tools needed, everything is described well in the bentley if you have it
      if not, i suggest you buyung it. there are loads of good info in that book, especially is the torque settings for various bolts etc etc
    3. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      Scirocco 16v, E34 540i, V50 T5 AWD
      05-31-2012 11:15 AM #3
      Shadetree version:
      Loosen subframe bolts & drop the subframe a couple inches.
      Pull back the rack boot & unbolt the tie rod from the rack.
      Unbolt the tie rod end (TRE) from the knuckle and use a clamp to pop it out. (A crow's head wrench or whatever they're called will help here.)
      Measure from the TRE to the surface that mates to the rack.
      Match that distance on the new tie rod & TRE.
      Installation is the reverse of removal.™
      Check alignment.
      The blues ain't nothin' but a good man feelin' bad.
      Tschüß Gilda, Hallo Birgit
    4. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      05-31-2012 11:50 AM #4
      Quote Originally Posted by CodeMan View Post
      Shadetree version:
      Check alignment.
      I plan on getting it lined up afterward, and I do appreciate the easy instructions but im trying to not drop the subframe haha thank you though
    5. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      05-31-2012 12:02 PM #5
      ... im trying to not drop the subframe haha thank you though
      I hear it can be done, but why make it harder on yourself?
    6. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      05-31-2012 12:13 PM #6
      to me dropping the subframe would be a pain, I dont feel like trying to line it back up
    7. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      05-31-2012 12:17 PM #7
      Do you have tiny hands like Dimitry?
    8. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      05-31-2012 02:25 PM #8
      haha no my hands are pretty big, and I understand what you mean but I think I found the right tool I need to just take it off without unbolting anything else really
    9. Junior Member
      May 9th, 2005
      Milwaukee WI
      05-31-2012 03:14 PM #9
      the right tool
      A tie rod fork.
    10. Member revolution_Jd3's Avatar
      Jan 12th, 2007
      Billings, MT
      emgay4 daily six bangin hard... stupid mk2 16v project ego stroke
      05-31-2012 03:56 PM #10
      dont use air gun on sub frame bolts
      WTB: NIB/NOS OEM 16v lip/chin spoiler, passenger side...... BIG MONEY NO WHAMMIES!!!!
    11. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      05-31-2012 04:59 PM #11
      Quote Originally Posted by mkast View Post
      A tie rod fork.
      Nope not the fork, I'm talking about the inner tie rod end that connects to the rack
    12. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      05-31-2012 05:20 PM #12
      Dropping my subframe served no purpose at all, still cant get a wrench in there to save my life
    13. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      05-31-2012 05:32 PM #13
      Whoops, it's called a crow's FOOT wrench, not head.
    14. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      05-31-2012 05:43 PM #14
      Edit this post: Realized what a crows foot wrench was, yeah wont work plus I dont have one I do appreciate you trying to help tho
    15. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      06-02-2012 12:46 PM #15
      Anyone have any other way of doing this? It's starting to piss me off that I cant get the friggin thing out
    16. Member
      Apr 21st, 2008
      SoCal
      Another Jetta...
      06-02-2012 02:01 PM #16
      Get the special tool per the bentley manual (also on Dan J Reed's page). It's basically a metal tube w/ a flat side and set screw at the end to lock onto the 22(21?)mm hex on the inner tie rod. Use a 1/2" breaker bar and it takes no more than 20min per side to change the whole thing. The tool is about $45 and 100% worth it.
    17. Member jettaracer1989's Avatar
      Jan 8th, 2009
      CT
      06-02-2012 03:01 PM #17
      Yeah thats what I was looking for but nowhere local had it, luckily one of my buddies happened to be up at his race shop today and when I called him was able to toss it in his car for me. Finally... now just tires, suspension and a new stock exhaust and ill be set
