Results 1 to 15 of 15
Thread: Reverse slips into 1st?!?
  1. Junior Member
    May 23rd, 2012
    Sacramento, CA
    91 Jetta GLI, 82 RX7 GSL
    05-31-2012 02:34 PM #1
    So I just had to replace my driver's side CV axle and now my stick naturally sits off to the right, and when I put it in reverse it pops up and is in 1st? Did my transmission shift? How do I fix this!!!!
  2. Junior Member
    May 23rd, 2012
    Sacramento, CA
    05-31-2012 02:36 PM #2
    Btw, It's a 1991 Jetta GLI (16V 5-speed)
  3. Member jettaracer1989's Avatar
    Jan 8th, 2009
    CT
    Now a proud Subaru owner, I will be back with an aircooled vw!
    05-31-2012 02:41 PM #3
    Sounds like you either need to re align the shifter, or the little plastic reverse lockout plate broke which is quite possible pull the shift boot off and take a look
    Mk4 shift knob, boot and trim ring into your mk3/mk2 DIY:
    http://forums.vwvortex.com/showthrea...ng-to-your-mk3
  4. Junior Member
    May 9th, 2005
    Milwaukee WI
    05-31-2012 03:06 PM #4
    Quote Originally Posted by KSE93 View Post
    I question what procedure you used to replace the axle.
  5. Member jkautz48's Avatar
    Aug 17th, 2011
    PNW WA
    1985 GTI
    05-31-2012 03:57 PM #5
    My guess is the lockout plate broke. When I bought my car, the lockout plate was mashed and I had the same problem.
  6. Member 88Jetta350's Avatar
    May 4th, 2007
    Kaiserslautern, Germany
    1986 Golf Syncro, 1996 Passat VR6, 2012 Up!
    05-31-2012 06:19 PM #6
    If it's the reverse lockout, it's an easy fix....even easier than aligning your shifter.
    *Remove shifter boot
    *Break off what's left of old lockout plastic
    *Use a hacksaw to cut the heads off the rivets
    *Punch old rivets out
    *Rivet new lockout in place (make sure you use a rivet that JUST fits into the holes in the shifter box, or else it will not be tight enough to hold it in place.)
    Piece of cake.
    [88Jetta350]
    '86 Golf Syncro -'96 Passat VR6 - '12 Up!
    ***VWSyncro.co.uk - The #1 resource for VW Syncro cars & vans***
  7. Member jkautz48's Avatar
    Aug 17th, 2011
    PNW WA
    1985 GTI
    05-31-2012 06:58 PM #7
    Quote Originally Posted by 88Jetta350 View Post
    Piece of cake.
  8. Junior Member
    May 23rd, 2012
    Sacramento, CA
    05-31-2012 10:08 PM #8
    Ok, the R lockout plastic's kinda messed up, but it never even hit Reverse? I push the shifter all the way over until the metal hits the plastic of the lockout and then up and it's first How do I re-align the shifter? New to all this so thanks for your patience, Reverse was working before
  9. Member R-Dubya's Avatar
    Jun 23rd, 2011
    '86 Mustang GT
    05-31-2012 10:13 PM #9
    You either need to re-align your shifter, or something is messed up in your linkage.
  10. Member jettaracer1989's Avatar
    Jan 8th, 2009
    CT
    05-31-2012 10:40 PM #10
    Yeah my car is doing the same thing, gotta really mess with it to get it to go into reverse.. The screw for adjusting mine was loose so I think it has something to do with that and it just needs to be aligned
  11. Member
    Dec 17th, 2004
    Colorado Springs
    06-01-2012 02:17 AM #11
    Are you pressing down on the shifter to get into reverse? The whole shifter needs to be pressed down, like a button, for it to go past the reverse lockout.
  12. Member R-Dubya's Avatar
    Jun 23rd, 2011
    '86 Mustang GT
    06-01-2012 02:58 AM #12
    Quote Originally Posted by Tripicana View Post
    I don't see why so many people are getting confused trying to identify the problem he's having. He clearly states twice that he is putting the car into reverse as he did before, pushing down on the shifter to clear the reverse lockout plate. It's his car, I'm sure he knows how to put the thing in reverse.
    The problem he's having is that he puts the car into reverse, and instead of engaging reverse the trans is in first, and the shifter pops back up as if he put it into first as well.
  13. 06-01-2012 03:17 AM #13
    [img]http://www.*************/6d.jpg[/img]
  14. Member Hombre3000's Avatar
    Jan 11th, 2010
    Bay Area, CA
    1990 Golf GL 2-door
    06-01-2012 12:59 PM #14
    The shift rod clamp is what you need to adjust (if you only have to align your linkage):
    No matter what, it's time you got under the car and read some stuff (Bentley, or this, for example).
  15. Junior Member
    May 23rd, 2012
    Sacramento, CA
    06-01-2012 01:49 PM #15
    Thanks guys, i'm reading that link now, but now I can't get my car into 5th either, guess I can't complain too much, read a $400 car :p
