Results 1 to 33 of 33
Thread: TECHNICAL : How to size a fuel pump
  1. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 03:04 PM #1
    I thought I knew how to size a fuel pump but apparently I'm wrong. I've been having some troubles with my car and it's causing me to do lots of reading and I've fallen down the rabbit hole.
    Note: I'm using my car as the protagonist in this story. This is a technical article, not an article about my car. I just wanted to put in some real world numbers so the equations can be checked against known variables.
    Summary: My calculations tell me that my car, at 15 PSI, 50% Injector Duty Cycle of 830cc injectors, 3 bar FPR, and stock fuel pump should be going lean, but it's not. At that moment it's sitting around 11.75:1, which is very much NOT LEAN.
    The question that I'm imposing in this thread is what is wrong with my calculations. Empirical evidence proves to me that they're wrong.
    What are the right fuel sizing calculations?
    Ok, here's the story...right now I'm using an OEM mk4 fuel pump
    Maybe I should test out my fuel system and see.
    As it stands, at 50% IDC @ 15 PSI boost on my 830cc injectors that works out to 114 liters/hour at the pump....
    According to USRT I'm already overstressing the hell out of the OEM pump, which at this flow rate should max out at around 61 liters/hour!
    Code:
    Specs care of USRT....
    OEM Mk4 (non-R32/TT225) Intank Fuel Pump Flow Rate
    PSIG	Amps	Lbs/Hr	Gal/Hr	Ltr/Hr	Ltr/Min	CC/Min
    40	 8	 145	 24.17	 91.48	 1.52	 1524.72
    45	 8.4	 130	 21.67	 82.02	 1.37	 1366.99
    50	 8.7	 120	 20	 75.71	 1.26	 1261.83
    55	 8.9	 111	 18.5	 70.03	 1.17	 1167.2
    60	 9.3	 97	 16.17	 61.2	 1.02	 1019.98
    65	 9.4	 83	 13.83	 52.37	 0.87	 872.77
    70	 9.7	 71	 11.83	 44.8	 0.75	 746.58
    blank line
    blank line
    blank line
    blank line
    I'm currently using Delph 830 injectors and a 3 bar (43.5 PSI) fuel pressure regulator. These injectors flow 830cc / min @ 3 bar.
    According to vag com logs, when I'm boosting 15 PSI and am at around 6700 RPM my injectors are at a pulsewidth that calculates out to 50% duty cycle (pulse width / RPM * 1200)
    If you scale out injector flow to a new fuel pressure (due to the boost) you can see how much each injector is flowing for me at that time. The formula is: sqrt(new fuel pressure/ old fuel pressure) * old flow = new flow. For me that is:
    ((43.5+15)/43.5)^.5 * 830 = 962 cc/min
    Then multiply by the duty cycle to get the flow per injector so the equation for the flow per injector is (for 50% duty cycle):
    ((43.5+15)/43.5)^.5 * 830 * .5 = 481 cc/min
    So each injector is flowing 481 cc/min @ 59 PSI fuel pressure. Ok, cool.
    My old way of thinking was to size a fuel pump for a person you'd take the max flow of all 4 injectors at the max fuel pressure, add them all up, and your fuel pump needs to be able to keep up with that flow rate at that fuel pressure.
    However, as you can see from the specs of the mk4 fuel pump, there is NO WAY that it's keeping up with that line of thinking. I would need to flow 4 * 481cc @ 59 PSI fuel pressure = 1924 cc/min. The OEM fuel pump can only flow around 1020 cc/min at that fuel pressure.
    At the per injector viewpoint, the OEM pump still has plenty of head room left on it. But if you multiply by 4 injectors you get:
    1924 cc/min @ 50% duty cycle, which is well outside the OEM fuel pump's capability. I should be going WAYYY lean at that point in time...but I'm not. In fact, at 15 PSI and these injectors the OEM pump should be unable to flow above 30% duty cycle...which means I should be going lean at anything over 30% duty cycle, which for me is anything above around 3800 RPM (where I hit around 15 PSI boost).
    This leads me to believe that the way I thought you should size fuel pumps is wrong.
    Here's my hypothesis on how to size a fuel pump...
    When sizing a fuel system, how do you match up flow between the injectors and the fuel pump? My intuition tells me that you don't need the fuel pump to flow the full capacity of all 4 injectors, because there is pressure in the line and the fuel line acts as a sort of surge or buffer for the individual injector pulses. However, you can't think of the pump and injector as instantaeous devices either. So my intuition tells me you should:
    Flow of injector @ duty cycle @ pressure = ______
    Multiply that by a factor = ___ >100% ___
    Make sure your pump can flow at the answer to that equation.
    So in my case, if the factor is say, 60% then
    830 injector @ 50% duty cycle @ 15 psi boost = 481 cc/min * (1.6) = 769 cc/min
    So in my current scenario my fuel pump should be sized such that it can pump 769 cc/min @ 59 PSI, which is well within the capabilities of the OEM fuel pump.
    Is my thinking right?
    My Build
  2. Member Chickenman35's Avatar
    Jul 28th, 2006
    West Coast, Canada
    Varied and lots
    05-31-2012 03:27 PM #2
    Simple solution.
    1: Pickup phone.
    2: Call Scott at USRT and ask him about fuel pumps.
    3. Go buy the Walpro or Bosch pump that he recommends. ( I recon at least a Walpro 225GPH or a Bosch 044 )
  3. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 03:30 PM #3
    Quote Originally Posted by Chickenman35 View Post
    Simple solution.
    1: Pickup phone.
    lol.
    Yes, I know what will work. Yes, I know there are people with knowledge out there. I'm trying to further my own knowledge.
    I have a bosch '044 surge tank built by INA sitting in a box waiting to be installed.
    The issue isn't that I don't know what I should put in my setup. I want to know how to calculate fueling requirements in general. Not just for my setup.
    I'm using my setup as an example so we have real world numbers to put in the equations.
    My Build
  4. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 06:26 PM #4
    ^^ up ^^ for a some insight.
    My Build
  5. Member Shamrock's Avatar
    Aug 6th, 2004
    Harrisburg, PA
    05-31-2012 07:06 PM #5
    well thats your hypothesis.. why don't you do the experiment now... I remember someone had a video of how bad the bosch 440cc injectors were.. couldnt you just setup a pump and a little fuel hose with a fuel rail and measure it? get some graduated beakers and a stop watch?
  6. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 08:29 PM #6
    Quote Originally Posted by Shamrock View Post
    I could... I was hoping the answer to this would already be known
    Id like to know how interested people are in this answer before I got too deep in
    My Build
  7. Member 04 GLI Luva's Avatar
    May 29th, 2007
    Miami
    05-31-2012 08:35 PM #7
    There's a reason why we have return lines
    Hell I know there's gotta be at least 1 person thats prolly only making 400 yet has IE's dual 044 setup lol
    MK4 Double Pumper
    Corn fed...BT...girl's car
    FS: WOTbox $100 shipped
  8. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    1989 16v, F250 Diesel, 2001 TT
    05-31-2012 08:47 PM #8
    Quote Originally Posted by 04 GLI Luva View Post
    E85 takes alot more fuel
    HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
    HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
    Looking for Custom Tuning, Shoot me a PM ! ME7.X !
  9. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 08:49 PM #9
    Quote Originally Posted by ejg3855 View Post
    I read 30% more is a good round figure for e85
    My Build
  10. Member 04 GLI Luva's Avatar
    May 29th, 2007
    Miami
    05-31-2012 08:56 PM #10
    If theyre on e85 i hope theyre making more then 400 lol
    30% is correct +/-3%
    MK4 Double Pumper
  11. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    05-31-2012 09:06 PM #11
    the lack of consistency in E85 sucks, it ranges from 65% to 90%+ at times.
  12. 05-31-2012 09:12 PM #12
    Wally 255, or bosch 044. And + a surge tank and ull be set. Then i believe ull be fine man, if u want a wally, ill sell u mine, i desperately need to upgrade! but this should be a good write up for people in the same situation.
    Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
  13. 05-31-2012 09:38 PM #13
    I have the stock in-tank pump with an IE surge tank and Bosch 044. At 25psi or higher, my A/F is around 13:1. I will do a log and see what my IDC but shouldn't that support my setup?
  14. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 09:41 PM #14
    Quote Originally Posted by K20017 View Post
    I'm quite confident that you are 100% good. However, if you want to log blocks 001-031 we can always take a look. As people have already pointed out, for 90% of the BT guys on the 1.8t platform, OEM feeding surge tank + Bosch '044 will always fit the bill.
    However, in this thread I'm trying to quantify things a bit more instead of just saying, that'll do it.
    My Build
  15. 05-31-2012 09:52 PM #15
    Ok I will. Anything below 25psi, I am around 11.5-12.0. My tune isn't perfect either
    And for your pump size quest, I am assuming you are negating fuel line sizes?
  16. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 10:10 PM #17
    Quote Originally Posted by Atomic Ed View Post
    Thank you. That will be one piece of information I can use. PS...you can find many more graphs like that in my Fueling FAQ
    My Build
  17. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-31-2012 10:11 PM #18
    Not negating fuel line sizing...That's on my radar too...but I am trying to keep the number of variables to tackle at once under control.
    My Build
  18. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-01-2012 11:34 AM #19
    Bunp
    My Build
  19. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-01-2012 04:34 PM #20
    Playing around with some google spreadsheets. Plotted a few flow rates for some common pumps...
    Which I now see isn't shown in tapatalk
    My Build
  20. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-01-2012 08:19 PM #21
    ^^ bump
    My Build
  21. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-01-2012 10:14 PM #22
    Does anyone have a graph of the pulses for all 4 injectors?
    I have a feeling this can be solved if I knew injector overlap.
    My Build
  22. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-01-2012 10:36 PM #23
    Quote Originally Posted by groggory View Post
    I need to learn about cams and timing advance:-). Solution coming soon
    My Build
  23. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-02-2012 06:54 AM #24
    Two things that you havent mentioned:
    - Battery voltage, the higher it is the more your pump flows. Depending on how it was flowed in te data you have provided (12v, 13v, 14v, etc) you might have some headroom
    - Fuel pressure, the stock pump output drops hard with rising pressure. 3bar fpr plus 1bar boost will tax things less then even a stock turbo 1.5bar, and you have a ton more flow vs using a 4bar base pressure.
    -Paul
  24. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-02-2012 02:11 PM #25
    Quote Originally Posted by need_a_VR6 View Post
    The pump data I've provided is at 13.5v
    Fyi
    My Build
  25. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-02-2012 02:20 PM #26
    Any idea on your actual voltage?
    -Paul
  26. Member toby lawrence's Avatar
    Dec 11th, 2011
    Boston
    mk4 sled
    06-02-2012 03:54 PM #27
    I was originally going to comment on this but my brain was too foggy to wrap my mind around it.
    Order a DSO Quad or something and you can measure all four signals. Based on the definition of duty cycle, I'd say your existing calculations are right... but like you, I'm also confused how they could be since you're obviously not running out of fuel as hard as your calculations would infer.
    There's also the issue of open and close time on the injectors which will skew the real results compared to theoretical results. I think the simplest way to do it would be:
    - get a fuel pump
    - get a fuel pressure regulator
    - get a gas tank and tap it and put the fuel pump in it
    - set up the injector for the pressures you want it running at
    - get an Arduino and set it up to control the injector at the duty cycle you care about
    - get a graduated cylinder, and let 'er rip
    science: it's for real.
  27. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-02-2012 09:26 PM #28
    What voltage?
    My Build
  28. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-02-2012 09:31 PM #29
    Quote Originally Posted by toby lawrence View Post
    - get a fuel pump
    I was thinking of hooking my logic analyzer up to all 4 injectors and seeing what the timing looked like.
    Do a wot pull, start logging the injectors at the start of the pull, stop logging at the end. Vag com blocks 1,31,115 while I'm doing that. And put a voltage shunt on the fuel pump to get the fuel pump current.
    Then I'd need to use an arduino to give a fuel injector the signal and learn the open and close delays.
    I think all that together may give me the answers
    My Build
  29. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-02-2012 09:49 PM #30
    Voltage at the pump. Any idea on the hp you are at right now with your setup?
    -Paul
  30. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-03-2012 01:06 AM #31
    Nope and nope
    My Build
  31. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-04-2012 06:50 PM #32
    I just had a huge DUH! moment.
    I've been thinking that with increased boost you get increased injector flow due to your fuel pressure regulator being 1:1
    TOTALLY WRONG!!!
    I forgot that your FPR is a 1:1 rising rate regulator because the intake manifold is pushing up as hard as the gas is pushing down...due to the boost.
    So if you have a 3 bar FPR and are are boosting 2 bar you have...
    * 5 bar fuel pressure
    * 2 bar 'boost' (intake manifold pressure)
    * The fuel injector will continue flowing at 3 bar rate, as you would in open air. This is due to the idea of differential pressure.
    WOW!! I overlooked a huge concept.
    :-) More thinking to come and perhaps some conclusions after I put my thinking cap on some more
    My Build
  32. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    06-07-2012 01:11 PM #33
    My Build
