Simple solution.
1: Pickup phone.
2: Call Scott at USRT and ask him about fuel pumps.
3. Go buy the Walpro or Bosch pump that he recommends. ( I recon at least a Walpro 225GPH or a Bosch 044 )
I thought I knew how to size a fuel pump but apparently I'm wrong. I've been having some troubles with my car and it's causing me to do lots of reading and I've fallen down the rabbit hole.
Note: I'm using my car as the protagonist in this story. This is a technical article, not an article about my car. I just wanted to put in some real world numbers so the equations can be checked against known variables.
Summary: My calculations tell me that my car, at 15 PSI, 50% Injector Duty Cycle of 830cc injectors, 3 bar FPR, and stock fuel pump should be going lean, but it's not. At that moment it's sitting around 11.75:1, which is very much NOT LEAN.
The question that I'm imposing in this thread is what is wrong with my calculations. Empirical evidence proves to me that they're wrong.
What are the right fuel sizing calculations?
Ok, here's the story...right now I'm using an OEM mk4 fuel pump
Maybe I should test out my fuel system and see.
As it stands, at 50% IDC @ 15 PSI boost on my 830cc injectors that works out to 114 liters/hour at the pump....
According to USRT I'm already overstressing the hell out of the OEM pump, which at this flow rate should max out at around 61 liters/hour!
I'm currently using Delph 830 injectors and a 3 bar (43.5 PSI) fuel pressure regulator. These injectors flow 830cc / min @ 3 bar.Code:Specs care of USRT.... OEM Mk4 (non-R32/TT225) Intank Fuel Pump Flow Rate PSIG Amps Lbs/Hr Gal/Hr Ltr/Hr Ltr/Min CC/Min 40 8 145 24.17 91.48 1.52 1524.72 45 8.4 130 21.67 82.02 1.37 1366.99 50 8.7 120 20 75.71 1.26 1261.83 55 8.9 111 18.5 70.03 1.17 1167.2 60 9.3 97 16.17 61.2 1.02 1019.98 65 9.4 83 13.83 52.37 0.87 872.77 70 9.7 71 11.83 44.8 0.75 746.58 . .. ... .... blank line blank line blank line blank line
According to vag com logs, when I'm boosting 15 PSI and am at around 6700 RPM my injectors are at a pulsewidth that calculates out to 50% duty cycle (pulse width / RPM * 1200)
If you scale out injector flow to a new fuel pressure (due to the boost) you can see how much each injector is flowing for me at that time. The formula is: sqrt(new fuel pressure/ old fuel pressure) * old flow = new flow. For me that is:
((43.5+15)/43.5)^.5 * 830 = 962 cc/min
Then multiply by the duty cycle to get the flow per injector so the equation for the flow per injector is (for 50% duty cycle):
((43.5+15)/43.5)^.5 * 830 * .5 = 481 cc/min
So each injector is flowing 481 cc/min @ 59 PSI fuel pressure. Ok, cool.
My old way of thinking was to size a fuel pump for a person you'd take the max flow of all 4 injectors at the max fuel pressure, add them all up, and your fuel pump needs to be able to keep up with that flow rate at that fuel pressure.
However, as you can see from the specs of the mk4 fuel pump, there is NO WAY that it's keeping up with that line of thinking. I would need to flow 4 * 481cc @ 59 PSI fuel pressure = 1924 cc/min. The OEM fuel pump can only flow around 1020 cc/min at that fuel pressure.
At the per injector viewpoint, the OEM pump still has plenty of head room left on it. But if you multiply by 4 injectors you get:
1924 cc/min @ 50% duty cycle, which is well outside the OEM fuel pump's capability. I should be going WAYYY lean at that point in time...but I'm not. In fact, at 15 PSI and these injectors the OEM pump should be unable to flow above 30% duty cycle...which means I should be going lean at anything over 30% duty cycle, which for me is anything above around 3800 RPM (where I hit around 15 PSI boost).
This leads me to believe that the way I thought you should size fuel pumps is wrong.
Here's my hypothesis on how to size a fuel pump...
When sizing a fuel system, how do you match up flow between the injectors and the fuel pump? My intuition tells me that you don't need the fuel pump to flow the full capacity of all 4 injectors, because there is pressure in the line and the fuel line acts as a sort of surge or buffer for the individual injector pulses. However, you can't think of the pump and injector as instantaeous devices either. So my intuition tells me you should:
Flow of injector @ duty cycle @ pressure = ______
Multiply that by a factor = ___ >100% ___
Make sure your pump can flow at the answer to that equation.
So in my case, if the factor is say, 60% then
830 injector @ 50% duty cycle @ 15 psi boost = 481 cc/min * (1.6) = 769 cc/min
So in my current scenario my fuel pump should be sized such that it can pump 769 cc/min @ 59 PSI, which is well within the capabilities of the OEM fuel pump.
Is my thinking right?
My Build
Simple solution.
1: Pickup phone.
lol.
Yes, I know what will work. Yes, I know there are people with knowledge out there. I'm trying to further my own knowledge.
I have a bosch '044 surge tank built by INA sitting in a box waiting to be installed.
The issue isn't that I don't know what I should put in my setup. I want to know how to calculate fueling requirements in general. Not just for my setup.
I'm using my setup as an example so we have real world numbers to put in the equations.
My Build
^^ up ^^ for a some insight.
My Build
well thats your hypothesis.. why don't you do the experiment now... I remember someone had a video of how bad the bosch 440cc injectors were.. couldnt you just setup a pump and a little fuel hose with a fuel rail and measure it? get some graduated beakers and a stop watch?
My Build
There's a reason why we have return lines
Hell I know there's gotta be at least 1 person thats prolly only making 400 yet has IE's dual 044 setup lol
HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
Looking for Custom Tuning, Shoot me a PM ! ME7.X !
My Build
If theyre on e85 i hope theyre making more then 400 lol
30% is correct +/-3%
#11
the lack of consistency in E85 sucks, it ranges from 65% to 90%+ at times.
#12
Wally 255, or bosch 044. And + a surge tank and ull be set. Then i believe ull be fine man, if u want a wally, ill sell u mine, i desperately need to upgrade!but this should be a good write up for people in the same situation.
Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
#13
I have the stock in-tank pump with an IE surge tank and Bosch 044. At 25psi or higher, my A/F is around 13:1. I will do a log and see what my IDC but shouldn't that support my setup?
#14
I'm quite confident that you are 100% good. However, if you want to log blocks 001-031 we can always take a look. As people have already pointed out, for 90% of the BT guys on the 1.8t platform, OEM feeding surge tank + Bosch '044 will always fit the bill.
However, in this thread I'm trying to quantify things a bit more instead of just saying, that'll do it.
My Build
#15
Ok I will. Anything below 25psi, I am around 11.5-12.0. My tune isn't perfect either
And for your pump size quest, I am assuming you are negating fuel line sizes?
#16
This should help:
http://jayracing.com/images/products...e_A1000EFI.JPG
#17
My Build
#18
My Build
#19
Bunp
My Build
#20
Playing around with some google spreadsheets. Plotted a few flow rates for some common pumps...
Which I now see isn't shown in tapatalk
My Build
#21
^^ bump
My Build
#22
Does anyone have a graph of the pulses for all 4 injectors?
I have a feeling this can be solved if I knew injector overlap.
My Build
#23
My Build
#24
Two things that you havent mentioned:
- Battery voltage, the higher it is the more your pump flows. Depending on how it was flowed in te data you have provided (12v, 13v, 14v, etc) you might have some headroom
- Fuel pressure, the stock pump output drops hard with rising pressure. 3bar fpr plus 1bar boost will tax things less then even a stock turbo 1.5bar, and you have a ton more flow vs using a 4bar base pressure.
-Paul
#25
My Build
#26
Any idea on your actual voltage?
-Paul
#27
I was originally going to comment on this but my brain was too foggy to wrap my mind around it.
Order a DSO Quad or something and you can measure all four signals.Based on the definition of duty cycle, I'd say your existing calculations are right... but like you, I'm also confused how they could be since you're obviously not running out of fuel as hard as your calculations would infer.
There's also the issue of open and close time on the injectors which will skew the real results compared to theoretical results. I think the simplest way to do it would be:
- get a fuel pump
- get a fuel pressure regulator
- get a gas tank and tap it and put the fuel pump in it
- set up the injector for the pressures you want it running at
- get an Arduino and set it up to control the injector at the duty cycle you care about
- get a graduated cylinder, and let 'er rip
science: it's for real.
#28
My Build
#29
I was thinking of hooking my logic analyzer up to all 4 injectors and seeing what the timing looked like.
Do a wot pull, start logging the injectors at the start of the pull, stop logging at the end. Vag com blocks 1,31,115 while I'm doing that. And put a voltage shunt on the fuel pump to get the fuel pump current.
Then I'd need to use an arduino to give a fuel injector the signal and learn the open and close delays.
I think all that together may give me the answers
My Build
#30
Voltage at the pump. Any idea on the hp you are at right now with your setup?
-Paul
#31
My Build
#32
I just had a huge DUH! moment.
I've been thinking that with increased boost you get increased injector flow due to your fuel pressure regulator being 1:1
TOTALLY WRONG!!!
I forgot that your FPR is a 1:1 rising rate regulator because the intake manifold is pushing up as hard as the gas is pushing down...due to the boost.
So if you have a 3 bar FPR and are are boosting 2 bar you have...
* 5 bar fuel pressure
* 2 bar 'boost' (intake manifold pressure)
* The fuel injector will continue flowing at 3 bar rate, as you would in open air. This is due to the idea of differential pressure.
WOW!! I overlooked a huge concept.
:-) More thinking to come and perhaps some conclusions after I put my thinking cap on some more
My Build
#33
Ok, this may help some...
http://forums.vwvortex.com/showthread.php?1160233
and
http://www.stangnet.com/mustang-foru...rocess.736061/
My Build
