I have seen a couple of other MK I TTs on the tracks over here in Germany. They race as touring cars mostly.
#1
Not much info, but stumbled on this. The pics don't show much at all, but I doubt it's actually a TT other than it's outward appearance. Interesting, nonetheless.
Clicky Pow
N/A, RWD, double front A arms, live rear axle. Odd creation.
#2
#3
1880lbs - I'd love to have that with my power![]()
As it were, I was pretty happy to see my car well under 3000lbsMy plan is to keep the TT when I move onto the next car, gut it and cage it, and make it a track whore...I wonder how light I could get it without sinking a ton of money into it!
Jeremy Brehm: Regina Wedding Photographer
'02 Audi TT 225 Build Thread - 2.0L - PTE6262 Daily @ 30PSI - 10.0:1CR - AEB @ 9000RPM - Maestro - RIP
'06 3.2Q A3 - Stay tuned!
#4
I'll take that motor![]()
#5
#6
Put it on a stand in my living room duh. It looks so cool haha
#7
http://forums.vwvortex.com/showthrea...t-done-I-guess
^^^Big Turbo build lots of pics^^^
Best shop for repair and custom workin ma
http://www.wentworthmotorsports.com/
#8
I'm Phat cause I'm force fed.
#10
Sex should be like a Civic; slow, obscene, and loud enough for the neighbors to hear.
#11
What is that motor based off of? It's not the 20V. Either way, that is not bad power for N/A at all.
#12
#13
#15
Brakes/rotors, 17lb wheels, cat-less/resonator-less exhaust (I weighed everything, and this actually drops a lot of weight), spare tire/tools, rear bumper ballast, one rear seat out at the time, about 50lbs of plastic crap and emissions devices, 17lb battery, aluminum charge air pipes, etc., etc. I've added a bit back in, with stuff like a larger turbo and intake manifold, but that's what it weighs with all fluids and an empty gas tank; with a full tank it would be around what your car is at.
With both rear seats out, some lighter front seats, and an AC delete there should be another 100lbs that can be saved. I'm not sure how daily driving a manual steering rack is, but I've thought about that as well. I'd really like to get a lot more off the front end!
#16
I removed
tools spares
All AC stuff
Radio speakers
Rear tow hook
Rear seats
One piece race seats
Fiber glass rear fake 3.2 spoiler
Power steering
11.5 battery
All plastic in engine bay
All emissions deletes
vvt delete
All door insulation
Race steering wheel
Fiber glass front bumper
New plastic a6 grill alot lighter than stock one
ctt aluminum front brace lighter than stock
Stock seat belts removed
Trim (tray)under passenger side
No cat no muffler
Remove 120amp alternator for 90amp don't know if that was any savings
Ie billet light weight alternator pully
Rear muffler heat shield
Removed ash tray
CD changer removed and some block of insulation that was in their also
Removed medical kit and owner Manuel's
Things to do rear weight balis remove carpet insulation
euro lower dash (no armor plating) on order from ecs
Heat shielding under the drive shaft
Remove glove box some how and make it so it don't look like crap
Passager air bag its the only one left lol
Stock Bose amp
If theirs any thing you did I didn't do let me know
So with all that it weight 3040
When I look at the door it says car weight 3770 ????that's kinda scary for a small car
#17
#18
Some pretty big omissions from your list:
- lighter wheels and tires (I saved over 50lbs there) - the added huge benefit of reducing rotating mass
- Ballast under rear bumper (if you have a 225 TT) - it's 35-40lbs.
- Lightweight calipers and two-piece rotors (more rotating mass here, but not very far out from the axis of rotation)
#19
#20
#21
#22
#23
#24
coupe's weight aroung 3200 lbs and roadsters weight around 3400 lbs
#25
#26
#27
Planing on using the a/c??? If not take out the a/c box that has the evaporator and heater core in it. Thats probably 50 lbs in it self. Also remove the complete a/c system from compressor to condensor and all the lines.
#28
#29
Yes, also you can remove the blower motor and everything else connected to the a/c system.
#30
