im pretty sure you can launch anywhere under where its set.
the procedure is the same
I rarely have a chance to use it.
#1
I have not tried launch control yet. Got flashed for 5400 rpm. Shawn VanNeer, who flashed it at vNd has an R with it and said it is waaay fun at the higher rpm. Anyway, I have not tried it yet. Is it the same as my old launch control: S or M mode, DSG warmed up, ESP off, hold brake, rev up and release brake? More specifically, can you launch at rpms lower than the max 5400? My HPA flash had to be at the pre-programmed rpm, any lower at it felt like it was slipping like crazy.
❚A VR6 AWD w/ lots of goodies
#2
#3
Yup, works the same. It's all about how you control the throttle off the line in preventing the clutch slipping. I found that I rev to 5000, release brake, wait for the front wheels to chirp, then I give full throttle. If I give full throttle before the chirp, it will slip the clutches.
I did a test the other day since putting the cams in and I got 4.3 0-60 and 2.0 60ft using pocketdyno...
Rigi Cola.
"The VR6 was an orchestra of well-tuned cylindrical delights." - jalopnik.com
#4
#5
Rigi Cola.
#7
With the increase in flywheel problems I'd be interested to know how often people use LC.....
I haven't tried mine yet, no reason has come up yet.
Finally got VCDS setup - now to learn all the nuances
Old Geezer addicted to cars, bikes, racing and my Grandkids and The Dragon
oldracer = used to race 911's and many other cars for 25 years, owned a race/fabrication shop for 11 years
UM Combo tune, lots of other things, PSS Michelins
#9
#10
I need to use LC one of these days and see how it does.
Douglas VW
Distributors for FFE Racing, GoAPR, CTSturbo, Integrated Engineering and HPA
Innovative Motorsports + UM
#12
I used the LC the second day I had the car. I just had to see what it was all about. LOL it was great. I had the wife and our 4 year old boy in the back seat. Ready, set, GO. Then the sound of 3 heads hitting seat rests in unison! LC for the world!![]()
ITS MINE!!!! ALL MINE!!!! HAHAHAHAHAAHAHAHAAAA
2008 R32 UG #4557
