Results 1 to 8 of 8
Thread: Big lost with my ITB set-up 16v... only change made was the air intake was a 50mm before :(
  1. Member marc124444's Avatar
    Jan 17th, 2009
    Montreal
    Golf 1991 16v Track only :)
    06-01-2012 02:42 PM #1
    Close thread
  2. Member marc124444's Avatar
    Jan 17th, 2009
    Montreal
    06-01-2012 06:30 PM #2
    Compression tested 210-220-220-215
  3. Member marc124444's Avatar
    Jan 17th, 2009
    Montreal
    06-02-2012 11:53 AM #3
    Delails about the set-up
    9a block
    1.8l 16v port & polish head
    Autotech sport cam
    Top Line of the dyno first set-up was 151 hp, great torque same head, cam, megasquirt, 30 lbs injectors with 50mm intake
    2 Lower lines hp & torque big lost everywere
    Custom itb from gsx 48mm, same head, injectors, 1.8t fuel rail, 6.5'' runner from an oem 16v Lower intake
    Same dyno, same tuner
    Sep 27th, 2010
    Quebec, Canada
    92 GTI 16v
    06-02-2012 12:53 PM #4
    Quote Originally Posted by marc124444 View Post
    9a block
    Autotech sport cam
    in my opinion its your cams that are limiting you , need something more agressive to have a better powerband with ITBs also, from whats ive seen customs itb from bike never do really amazing numbers ..
  5. 06-02-2012 02:43 PM #5
    Are you sure it's properly tuned ?
    I just started tuning my 1,8 16v with the same ITB's , not jet dynotuned, but I'm sure torque does not fall so quickly after 5500 rpm...
    will you post your msq ?
  6. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    84 VW Rabbit GTI, 84 VW Jetta Coupe
    06-03-2012 11:52 AM #6
    9a block
    Autotech sport cam
    Those are pretty good numbers with the 50mm intake and the mods listed.
  7. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 tdi
    06-05-2012 05:46 PM #7
    i think that thing looks due for some more wicked cams...
  8. 06-09-2012 07:38 PM #8
    Do you have an A/F plot? If you didn't do any tuning after the change, you could be too lean or too rich now, hurting your numbers.
    With the 50mm TB, were you running MAF, MAP, or Alpha-N tuning? Unless you've got a strong MAP signal, Alpha-N is the way to go on ITBs, which means a complete re-tune.
