Results 1 to 9 of 9
Thread: QUESTION: Weber 45 DCOE carb FLOAT HEIGHT
  1. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    VW Caddy, VW THING & Audi A4 Quattro
    06-01-2012 08:48 PM #1
    Anyone know the correct PLASTIC float bowl height for Weber 45 DCOE carb or where to get the info ?
    I think my floats are flooding my carbs cause when i try to start it up if i touch the gas at all it kills all chances & when i do get it running i see a lot of fuel in my V-stacks almost dripping out. + can't get to idle
    Apr 27th, 2003
    oregon city, oregon
    79 dual carb rabbit ( the dark green one )
    06-02-2012 08:44 AM #2
    the measurements are 12mm when touching the needle and seat, and 26mm when hanging. you measure with the gasket in place
  3. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    06-02-2012 09:15 AM #3
    Quote Originally Posted by candm View Post
    THANKS
    new question. Since i never adjusted floats before what's this 26mm when hanging ?
    & where do i measure from & to ?
    Apr 27th, 2003
    oregon city, oregon
    06-02-2012 12:59 PM #4
    when you pull off the cover that the floats are atttached to, you measure from the cover (with the gasket in place ) to the bottom of your floats.
  5. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    06-02-2012 01:14 PM #5
    THANKS
    26mm hanging
    I take it the 12mm is when you adjust when holding the top vertical
    Apr 27th, 2003
    oregon city, oregon
    06-02-2012 09:58 PM #6
    actually, you want to hold it horizontally against your forehead and if you cannot touch it with your tongue, then, it needs to be adjusted.
  7. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    06-02-2012 10:42 PM #7
    like this ?
    good one. Thanks i'll get on this as soon as i find a MM ruler
  8. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    07-12-2012 03:42 PM #8
    OK so while Adam & I last month was trying to tune my carbs ( unsuccessfully ) we notice the 1 carb really spitting out fuel in the V-stacks. Figured it would be the floats need adjusting. So today i was doing so & noticed something missing yet again.
    GOOD one with all parts
    BAD one missing parts
    Needle Valve or lack of. ( part # 79503.200 )
    This might just be the reason for to much fuel LMFAO
    BTW if anyone has this part sitting around LET ME KNOW i'll buy it
  9. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    07-25-2012 11:54 AM #9
    new part in
    THIS should fix things
