Results 1 to 5 of 5
Thread: vrt sputtering problem!
    Jul 6th, 2010
    rockland,ny
    89 jetta gli 16v/90 jetta coupe vr-t
    06-02-2012 10:25 AM #1
    so i just finished my vrt build and its got a sputtering problem under hard accel and wont realy make it past 4-5k.
    it makes 19pounds of vacuum at idle and holds steady 8psi of boost.
    during the build my dumb*ss self touched the maf sensor while swapping housings and cracked the sensor a bit. this was the first place i thought of so i unplugged it and the car seems to sputter alot less and will actually rev all the way thru the power range but still doesent run 100%. there are short times where it runs really good but then sputters again. does this mean the maf is bad?
    any thoughts would be greatly appreciated!
    Jul 6th, 2010
    rockland,ny
    06-02-2012 03:44 PM #2
  3. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    89 jetta carat, 90 gti vrt
    06-02-2012 11:14 PM #3
    sounds to me like a crank position sensor ive gone through my fair share.
    67mm - vrt
    mad slow
  4. Member
    Jul 6th, 2010
    rockland,ny
    06-03-2012 05:52 PM #4
    the car ran great befor the turbo tho
  5. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    06-03-2012 07:45 PM #5
    step 1. replace broken parts.
    there is no point in wasting time trying to track down 1004 possible issues, when you are already aware of one that is actually there.
