Results 1 to 13 of 13
Thread: Backup light error after LED install
    May 2nd, 2001
    NY or MA?
    1992 Cabriolet, 2004 W8 wagon 6MT, 2012 Golf R 4dr
    06-02-2012 09:53 PM #1
    Today I installed my LED tail lights (no fog) and changed byte 18 from 20 to 21. All seemed fine until I drove the car. Now I have a back up light error.
    When I checked the lights themselves the right light is white and the left light is red.
    WTF? Anyone else get this error? Are both your back up lights white? Bad QC at the factory?
  2. Member Alive By time's Avatar
    Feb 2nd, 2006
    North San Diego
    12' CW 4DR Golf [R] (SOLD) 13' RB 4DR Golf R
    06-02-2012 10:11 PM #2
    Quote Originally Posted by B5Speedo View Post
    sounds like you have a fog..
    Blue One
    May 2nd, 2001
    NY or MA?
    06-02-2012 10:14 PM #3
    Quote Originally Posted by Alive By time View Post
    I didn't order one.
  4. Member Alive By time's Avatar
    Feb 2nd, 2006
    North San Diego
    06-02-2012 10:15 PM #4
    they sent you the wrong set. its happened before.
    makes sense that codes for non fog tails would have an error on w/ fog tails.
    Blue One
    May 2nd, 2001
    NY or MA?
    06-02-2012 10:40 PM #5
    I just emailed BKS and hopefully they can sort this out.
  6. Member Alive By time's Avatar
    Feb 2nd, 2006
    North San Diego
    06-02-2012 10:42 PM #6
    yeah that's a bummer.. did your box come with a Yellow wire?
    Blue One
    May 2nd, 2001
    NY or MA?
    06-02-2012 11:42 PM #7
    Nope, just the 4 connecting wires.
  8. Member BrownBear's Avatar
    Feb 1st, 2012
    Chicago, IL
    '12 Golf R
    06-03-2012 10:08 AM #8
    I'm having all sorts of errors. I had my LED with rear fog on my GTI and it worked just fine. When I used 04 in the coding it had the front passenger LEDs off and the driver side rear fog constantly on when driving.
    So that everyone isn't confused or any other people like myself...can someone write what we do to get our rear fog working?
    Do we wire it like I did with my GTI following the DIY thread on here?
    Then once installed, how do we code it?
    Dec 2nd, 2011
    Burlington, NC
    2012 Golf R RB 2D L
    06-03-2012 11:09 AM #9
    If you have rear fog you need the switch and two repair wires. Follow the Notes on LED Tail thread which was freshly bumped.
  10. Member
    Mar 24th, 2002
    '12 CSG .:R
    06-03-2012 11:30 AM #10
    also make sure the adaptor harness is wired correctly
    one of mine from ECS was wired reverse so one of my tail lights was yellow when lights were on, and blinked red when signaling...although it sounds like you have a fog version
  11. Junior Member macky's Avatar
    Mar 11th, 2012
    Central PA
    2012 Golf R, RB 4-door
    06-03-2012 12:34 PM #11
    Quote Originally Posted by jeff32 View Post
    Same here.
  12. Junior Member
    Sep 23rd, 2012
    2013/Golf R/4dr RB
    10-04-2012 12:39 AM #12
    Quote Originally Posted by macky View Post
    Same here.
    I'll add to this. Two of my harnesses were wired backwards and one was loose so it wasn't even making contact. Very sloppy work, especially for the price.
  13. Member Nuc1ear_Rabbit's Avatar
    Jun 11th, 2003
    Sacramento, CA
    '12 Golf R
    10-04-2012 12:40 AM #13
    I didn't order one.
    Ya you definitely have the fog version. I had to return my left inner light to ECS twice before I got a non-fog one. Good luck on getting it replaced, it was annoying waiting for the correct light
