VWVortex.com - Checking and adding transmission fluid in 01 auto Jetta
    Results 1 to 6 of 6
    Thread: Checking and adding transmission fluid in 01 auto Jetta
    1. n00b
      Feb 20th, 2011
      Ohio
      2001 Jetta
      06-03-2012 12:22 PM #1
      I think i'm low on transmission fluid in my 01' automatic 2.0. Does anyone know how to check it? and what fluid to use? I bought a quart of Castrol import multi-vehicle automatic trans fluid. Curious if i'm on the right track. Thanks!
    2. Member 2SlowHeart's Avatar
      May 19th, 2009
      York, PA
      Scooty Puff Senior - The Doombringer
      06-03-2012 01:42 PM #2
      According to my local dealer, you need a VAG-COM to do it, along with some kind of funky technique.
      I never trust my dealer, and it's always steered me the right way.
      Edit: http://www.ehow.com/how_4813090_chec...uid-jetta.html
      There's an answer that seems pretty legit, haven't tried it myself. Oh, and I don't know for sure if that fluid is acceptable, check the VW standards listing.
      Quote Originally Posted by a sneaky panda View Post
      do you squat to pee? your not low, stop being a cry baby and go lower. i dont care where your from. i live in maine, dirt roads and im lower than you and dont have an issue. pull that skirt up and be a man
      Hellacheap.
      8v Society #267 DirtyGhettoKids
    3. 06-03-2012 09:43 PM #3
      Quote Originally Posted by alwayssunnylisa View Post
      As for OEM ATF fluied its the G 052 162 A2, compatible with DextronIII/Merkon.
      This is my 3rd post/reply here, not very familiar with forums to be honest. I would try to upload the procedure for you as pics.
      I do thing you can do it without the VAG, since you are only thinking of topping it off. See the 7th picture.
    4. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      2.0 twin turbo 9 speed jetta
      06-03-2012 09:59 PM #4
      sub'd
    5. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      06-03-2012 10:10 PM #5
      srsly
      the car is on an inclined driveway and up on jack stands in the front only
      04 Jetta Wagon 2.slow------>Family man now
    6. n00b
      Feb 20th, 2011
      Ohio
      2001 Jetta
      06-04-2012 12:15 AM #6
      Thanks for the help!
