Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 36 to 70 of 164
Thread: My first Scirocco Build thread 88 16v
  1. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    1988 16v Scirocco 2012 GTI 2003 allroad 1990 Jetta GLI
    06-23-2012 03:48 PM #36
    Nice day for enjoying my Scirocco
    What's next?
    The Corrado Brakes up front and mk4 caliper conversion in the back
    Race Header (thanks gatorhator!)
    H&R Sway Bars front and rear
    Photobucket
  2. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    06-25-2012 11:28 AM #37
    Quote Originally Posted by Sanityana View Post
    First off,
    Find some decent matching wheels
    Get the emergency brake working again
    Install new shifter bushing
    Just got my plate, title, and registration. It's a good day
    Thanks guys for all the replies and interest
    Ahh I remember the day when I got all mine too..although I'm pretty jealous that mine wasn't for a scirocco
    I'll be watching
    Subscribed
    faceoff
    Quote Originally Posted by the mad conductor View Post
    So my new girlfriend doesn't give Dome?
    Quote Originally Posted by 1.8Tquattro View Post
    You spelled ex-girlfriend wrong.
  3. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    06-25-2012 09:59 PM #38
    A little side project done tonight.
    Installed a beefed up primary ground wire, cleaned up my ground points, and installed new headlight bulbs.
    Things are much brighter now
  4. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    06-26-2012 03:04 PM #39
    Ordered drilled and slotted Corrado rotors for the front today. When I get them in I should have everything I need to upgrade to Corrado front brakes
    Waiting on my header to get here is killing me
    Photobucket
  5. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-02-2012 09:47 PM #40
    Header is here, hoping to get it on my car Wednesday
    Still waiting on the Corrado rotors and front brake hoses to get here, but maybe I can get that done this weekend if they make it here.
    Wish me luck with the header install, will post pics
  6. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-05-2012 10:14 PM #41
    Some boxes showed up today...
    Photobucket
    Hrm...what could be in them....
    Photobucket
    Looks like it's going to be a good weekend
    Here's a sneak peak of what's happening next week
    Photobucket
  7. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    07-06-2012 09:12 AM #42
    faceoff
  8. Member Thrasher's Avatar
    Jul 18th, 2003
    Maricopa, AZ
    1987 Scirocco 16v, 1987 Golf GL 4dr
    07-06-2012 12:08 PM #43
    I spy a header without a flex bellow... hope you plan on running one on the before the cat. Keep an eye on those rotors too, there have been many who've had bad luck with the drilled/slotted rotors for our cars. I'm a Zimmerman man myself... but pimpin' ain't easy (or cheap). Good luck and keep up the progress.
    Tornado Redneck - Team Infidel
    STOP PUTTING CORVETTE WHEELS ON VOLKSWAGENS
  9. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-06-2012 01:50 PM #44
    Zimmerman's would be nice, I agree
  10. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-07-2012 06:03 PM #45
    Slight setback. Went to test fit then install the new rotors, calipers etc. and I can confirm that upgrading 88 16v scirocco brakes to corrado brakes requires an adapter which I currently do not have to bolt the carriers to the spindles. I had been told it was a direct bolt on but it is not.
    Anybody have a pair of adapters for sale?
  11. Member
    Nov 3rd, 2009
    Surrey, B.C.
    2010 Audi A4, 2003 CBR 600RR, 1988 16V Scirocco
    07-07-2012 07:53 PM #46
    Momentummotor.com
  12. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-08-2012 09:40 AM #47
    Nice, but $105....OUCH
  13. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-09-2012 02:01 PM #48
    Thanks to some help from my friends the Header may make it on tonight, fingers crossed
  14. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-10-2012 01:23 PM #49
    Race Header is on
    Before
    Photobucket
    After
    Photobucket
  15. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-10-2012 01:48 PM #50
    As a side note does anyone know which aftermarket front sway bar has enough extra clearance to fit under a race header that is about 2+ inches lower then the stock down pipe?
    H&R? someone else?
  16. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-11-2012 10:34 PM #51
    My new high beams came in and I got them installed, small thing but if you'd driven around with the ones that came on the car you'd understand why it's a big deal for me
  17. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-14-2012 04:34 PM #52
    I wanted to put this here as well. In addition to all this I have the brake adapters I need on the way
    I'm still working out the best way to mount the spacer. Anyway here are some build pics and some test fit pictures.
    Feedback, Ideas, Jokes all welcome
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    On the ground, speed bumps may be a problem
    Photobucket
  18. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-16-2012 10:45 AM #53
    Honestly, this isn't getting anywhere. To run a sway bar with this header you need a sway bar designed to run with it.
    The factory sway bar can be made to fit with the header using a spacer, but it is not a proper fit and is way to close to the ground on a lowered car.
    It would be nice to see one of the aftermarket companies come out with a sway bar designed for this application.
    Until when/if they do, I will probably pick up a try y in the next month or so and swap headers.
  19. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-20-2012 09:22 AM #54
    Finally got a parcel shelf, now if I can just find some spiffy 4x6 speakers
    Photobucket
  20. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-22-2012 09:04 PM #55
    Today I finally installed the Corrado brakes.
    The adapters, hardware, and instructions from http://www.momentummotorparts.com we're top notch. I highly recommend there kit if you are thinking about doing this.
    Pics!
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
  21. Member Thrasher's Avatar
    Jul 18th, 2003
    Maricopa, AZ
    07-22-2012 09:36 PM #56
    It's pretty well noted that the factory sway bar will not work with the race header, you kinda stepped into that one. On the other hand, had you listened to old Thrash, you would have gotten the street header and been much happier.
    Secondly, corrado brakes on a ~2200 pound car are not only overkill, but the added unsprung weight isn't helping anything either. Looks cool, but you probably won't see much else on the side of performance unless you plan on hardcore tracking that thing, and if you do, those rotors probably won't last half a track day before heat-cracking.
    Looking good though, good progress.
  22. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-23-2012 09:24 AM #57
    Thanks Thrasher, I agree with you on the header and will probably wind up swapping it out for a Try Y in the next month or so. Chalk this one up to a learning experience
    If you don't mind passing opinion is the Techtonics TRY Y really worth the extra cost over Raceland? A friend of mine runs a shop here in town and says he hasn't see major issues with the Racelands and recommend I go with them and save the extra $250 for something else. Thoughts?
    On the brakes, I got the calipers along with my seabrings a while back and wanted to give them a try. I'm keeping all my original equipment in a nice neat box in case this goes badly. I agree they are overkill for this car, but in brakes I kind of like that.
    We'll see how it goes and if I don't like it or it feels unsafe/unstable they are coming right back off.
    I took the car for a nice and gentle test drive last night just to see how things would feel. On the positive side the gripping power is MUCH higher, but I've also picked up a little more pedal travel despite extensive bleeding.
    Keep in mind I kept things slow and took my time braking.
    It was late last night when I got in, but I plan to go back over everything and make sure it's tight, in proper alignment, etc. before I take another drive. Thankfully I have two other VW's to drive so I can take my time and be as through as I need to on the brake experiment.
  23. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    07-23-2012 09:43 AM #58
    I forgot to mention I'm thinking about picking this up in a few weeks to rebuild/build up over the winter.
    http://forums.vwvortex.com/showthrea...4#post78125544
    As always feedback appreciated
  24. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    08-25-2012 07:40 PM #59
    Added front and rear upper stress bars a couple weeks ago. Very noticeable improvement
    Photobucket
  25. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    08-28-2012 09:20 AM #60
    New Speedometer came in last night
    No more golden speedo....(Someone painted all the needles gold in the one my car came with)
    Before:
    Photobucket
    After:
    Photobucket
  26. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    09-02-2012 12:59 AM #61
    Finally got the MK4 brakes on the rear, looks super nice
    Before
    Scirocco 16v stock rear caliper
    After
    Scirocco 16v MK4 rear caliper
    Also for the first time since I got my Scirocco the emergency brake works
    Next weekend I'm picking up a complete 2.0 litre 9a to build over the winter and if all goes well a pair of NIB rear 16v tail lights.... Sick of the cracked 8v's
  27. Member rocco858488's Avatar
    Sep 14th, 2005
    Anderson, SC -n- Jacksong, GA
    85 rocco, 92 SLC
    09-06-2012 08:49 PM #62
    Ana, so glad to be contributing to this rocco! Looks beautiful! The squishy pedal is normal when upgrading to the corrado setup. Looking forward to meeting you on Saturday.
  28. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    09-09-2012 01:36 AM #63
    Today my winter 9A project came home. Thanks rocco858488
    Photobucket
    Photobucket
    It also came with some extra goodies:
    Upper + lower intake
    Complete wiring harness
    All boxes (even spares of some)
    Complete cis-e system including good boot
    exhaust manifold and down pipe
    various gaskets
    Hoping to get the oil drained and the pan off tomorrow
    Awesome day!
  29. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    09-20-2012 09:35 AM #64
    I just couldn't take the cracked 8v lenses anymore...
    Photobucket
    Photobucket
    Photobucket
    Thanks e-clown
  30. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    09-20-2012 10:02 AM #65
    Photobucket
    Photobucket
    Thanks e-clown
    Everything is looking nice.
    faceoff
  31. Member 85roccoZ400's Avatar
    Jan 27th, 2002
    Litchfield County, CT
    85 Scirocco 8VT; 2002 VR6 Jetta; 2005 C230 Sport
    09-20-2012 10:10 AM #66
    Coming along nice!
    "Everything is possible to the man who does not have to do it for himself"
  32. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    09-20-2012 02:17 PM #67
    Thanks guys
    After much deliberation I've decided to take care of a few more things on the car before I jump into the long term (read expensive 9A 2.0 or 2.1 litre NA monster engine project)
    In no particular order I'm planning to:
    Swap the headlights for Euro's
    Replace the radiator fan with the thin flex-a-lite unit
    Move battery to the trunk
    Why wait on the engine? I want the car and the current strong 1.8 to reap the benefits of better cooling, better weight distribution, and a less cluttered engine bay.
    The lights well...I have the brightest US spec lights I can get and am woefully under impressed even after painstaking cleaning of grounds and contacts.
    ...the Euro's look a lot better too
  33. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    09-26-2012 10:16 AM #68
    Just got these in last night
    Scirocco Euro Head Lights
    Hopefully I can pick up a project box for the relays today at Radio Shack and get them in the car tonight.
  34. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    09-26-2012 12:01 PM #69
    .....Carry on
    faceoff
  35. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    09-26-2012 08:39 PM #70
    Unfortunately I didn't get a chance to pick up a project box today, but here is everything all mocked up
    Photobucket
    Photobucket
    Photobucket
