Please post the whole auto-scan.
#1
Guys,
My standard Mk5 Gti misses and stutters when cold up to 2500rpm until it reaches operating temp of 90 on the gauge.
I get the following codes:
4 Faults Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 8
Mileage: 146143 km
Time Indication: 0
Date: 2000.00.00
Time: 18:11:15
Freeze Frame:
RPM: 834 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 94.0°C
Temperature: 39.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 146413 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Temperature: 42.0°C
Voltage: 12.319 V
000280 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 146413 km
Time Indication: 0
Date: 2000.00.00
Time: 16:10:44
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 12.192 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
This problem has been going on for awhile. I have disconnected the battery at one point so I can understand why ive got some of the codes, but the two which I believe are causing the issues are P0441 and P0118.
I suspect the coolant temp sensor has failed confusing the computer when cold and making it run rough until its warmed up but i wasnt sure if the P0441 fault would only have an effect when cold. Is it possibe these two are unrelated but are both issues?
Any help would be great.
Car has 148k on it.
Thanks
#2
1998 GTI 2.0
1993 Jeep ZJ 4.0
World Automotive
#3
Monday,04,June,2012,19:00:07:47231
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WVWZZZ1KZ8U019918 Mileage: 147860km/91875miles
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GN3N77UN
Coding: 0403004318070160
Shop #: WSC 00046 412 00000
VCID: 3449C19D57204E9
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 146143 km
Time Indication: 0
Date: 2000.00.00
Time: 18:11:15
Freeze Frame:
RPM: 834 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 94.0°C
Temperature: 39.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 146413 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 12.319 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 146413 km
Time Indication: 0
Date: 2000.00.00
Time: 16:10:44
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
VCID: 73CB028112AE091
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CQ HW: 1K0 907 044 CQ
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78D135AD0BC86A9
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007972829
Coding: E58D8F2700041500471400001400000000087F075C00010000 0000000000
VCID: 71C7088968B23B1
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 240108 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 211207 046 0204
Coding: 00208933
Shop #: WSC 00046
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1KMMH2
Coding: 0012624
VCID: 3D5FE4B9646A8F1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0100
Coding: 0002022
VCID: 8127D849D812AB1
Part No: XXXXXXXXXXX
Component: E0221 002 0010
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 874 HW: 1K6 920 874
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GN3N77UN
Coding: 0003103
Shop #: WSC 40084 959 999999
VCID: F0C18D8DE3B8B29
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B300865
Coding: E9807F061002020003
VCID: 3041CD8DA338729
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 3851F5AD4B48AA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 364DFB95415C5C9
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 832BD241C20EB91
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
1 Fault Found:
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 1K6 035 456 B HW: 1K6 035 456 B
Component: 08K Audioverst. 0006
Revision: 00004000 Serial number: 00000008127678
VCID: 2B7BDAE18A1E111
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 3957F0A97042B31
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 3C0 035 195 B HW: 3C0 035 195 B
Component: Radio PM6 012 0018
Revision: 00012000 Serial number: VWZ5Z7G1127938
Coding: 0010011
Shop #: WSC 00046 000 00000
VCID: 1F633E31CEA6FD1
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 147866 km
Time Indication: 0
Date: 2000.00.00
Time: 17:32:30
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 00046 412 1012544
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 006 1301
Coding: 0000144
End ---------------------------------------------------------------------
Weird thing is ive reset all these fault codes, drove the car today, still rain poorly, but the faults havent come up again.
Also, i had a CEL come on about a week ago, it was on for about 2 days and then just went away by itself. I didnt have the VAGCOM then so couldnt check what it was.,
#4
Check the battery and alternator. Check for vacuum leaks. Verify temp sensor operation.
Run the readiness script after clearing faults. Does anything return? Do all readiness monitors set?
1998 GTI 2.0
1993 Jeep ZJ 4.0
World Automotive
#5
Grounds, ignition switch or module for it.
Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
#6
As in just check battery and alternator with Ross tech or do it manually with a multimeter ?
How do I run the readiness scriPts sorry?
#7
What grounds should I check? Is there a common ground location?
Ignition switch? As in it may be worn Out? Poor contact etc?
When you refer to module what do you mean sorry?
#8
Check battery and alternator with proper testing equipment.
To run script, clear codes, then 01-ENGINE, READINESS. Then SET READINESS. Follow instructions exactly.
Ignition switch can be monitored in measuring blocks. Wiring diagrams and ground locations can be found in the service manual.
EDIT: I'm with Jack. I missed the faults in 16, skimmed down the scan too fast. Verify ignition switch and grounds.
1998 GTI 2.0
1993 Jeep ZJ 4.0
World Automotive
#9
What would be the reason for my set readiness option to be grayed out and not accessible?
#10
Time to buy a repair manual and read the wiring diagrams for information.
#12
Thanks for everyones help.
Just wondering why are wiring fault would be worse when cold/not in boost?
Will grab the repair manual though and start searching.
I was trying to find the number for the ignition switch in the measuring blocks, but couldnt seem to come across it, anyone know off the top of their head?
#14
Just out of interest. These are the faults which have reappeared after this mornings cold start.
Thursday,07,June,2012,18:43:56:47231
Chassis Type: 1K0
VIN: WVWZZZ1KZ8U019918 Mileage: 148360km/92186miles
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148240 km
Time Indication: 0
Date: 2000.00.00
Time: 06:44:53
Freeze Frame:
RPM: 836 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 22.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Revision: 00H11001
Coding: 0004738
Coding: 00049109
Shop #: WSC 00046
Coding: 00208933
Shop #: WSC 00046
Coding: 0012624
Coding: 0002022
5 Faults Found:
00576 - Terminal 15
Coding: 0003103
Coding: 0000692
1 Fault Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Coding: 0000692
Coding: 0010011
Coding: 0000144
Coding: 0000144
#15
Stuck or faulty N80
#16
Just took it for a drive running misfire measuring blocks. Cylinder 3 misfired under load and when cold but goes away when hitting boost. I'm
Going with faulty injector?
Will swap cool pack to another cylinder to check though.
Will still replace other valve while engine cover is off thiugh
#17
For Miss.
I bet bad coil pack or plug due to bad ground condition inducing coil pack switch failure.
For evap still N80
#18
Thanks jack. Now I think about it the mis was not near as koi enable after the 120 service when it it new plugs so coil pack it sounds like. Thanks for your help!![]()
#19
There is a TSB and updated electrical portion of your ignition switch part number 1K0 905 865 A.
There are also 2 TSB's for you P0440 fault. Most likely a bad n80 like previously stated. You can take it off and see if it holds vacuum and if theres carbon built up inside it. If it fails basic setting 71 you can clamp the line off in front of the n80 and re-run the test. If it passes N80 is faulty. You ECT freeze frame looks to be reading at -40 C unless im mistaken. That is most likely bad too. I've seen MAF wiring about 10 inches back inside the loom break and fray and the pins at the connector break, may be worth a peak. Heavy carbon on valves may be causing your cold idle issues as well![]()
2012 Jetta Tdi
H&R sport springs
15% tint
VW Technician
VAGCOM equipped, willing to help with it if in pacific NW area. Hit me up.
#20
Thanks for your help.
Whats the best place to find the TSB's? Are they part of the bentley service manuals (im just waiting for mine to arrive still) or just searc online?
The -40C reading when i had it disconnected to see if it was making any difference, thats what i suspect anyway as it hasnt returned since.
Its definitely cylinder 3 missing even after swapping around the coil pack to a different cylinder.
It is still slightly evident too when it has wamred up, but not near as bad.
I will replace the N80 valve etc, but i think the injector on cyliner 3 has packed it up.
The reason i believe this is that when the vehicle is running enrichment map when cold, that injector cant supply/over supplies, but when it does not need to run the car is rich to warm up, the injector doesnt struggle as much.....would this sound logical at all?
#21
RB or Erwin at VW-Audi direct.
#22
I just replaced the N80 valve today and the code still exists and now im not able to to set my readiness. Could the next valve under the inlet manifold be faulty also?
#23
As I said in the PM.
Grounds and wires to coil packs? Verify!
If an intake leak is present, large enough, it will also cause this symptom for the miss, and a serious deviation to cause the ADP limits of the evap test.
A miss from an injector or carbon can also cause this, as idle would be disrupted causing a weak vacuum.
Please also check the cylinder for a wash of rings due to fuel in oil contamination.
( compression check !) ?
Check the rocker arms cam lobes for damage under VC to verify all valves are opening for exhaust and intake.
#24
#25
Again:
#26
Thanks Jack, Will do.
I guess I'm struggling to understand why if it was mechanical it would stop at the exact same operating temperature everything, not a degree difference.
#27
10-4 also never rule out a possible collapsed/melted Catalyst.
Verify those grounds, cant stress more.
#28
When engine is warmed up pistons and rings and metals expand creating different effects in a car. Cold u might have low compression and when hot rings and pistons expanded you might have better compression same goes for all other metal moving parts in your engine. Oil pressure is high when cold and lower when hot.
2006 GTI MKV BT HTA 35r, Unitronic, Mahle, BSH, Eurojet, IE, AEM, Borla, ClutchMaster, APR, Draft42....For Sale PM me for details
#29
My symptoms with a weak coil pack were just the opposite- ran fine when cold but misfire at idle and under mid/high boost when warm. New coil packs fixed it for me.
#30
Thanks Jack, will do. Ill check over those grounds again to see if theres something i missed.
Thanks
#31
Did you figure out the problem mine is still doing the same I either have a chain tensioner problem or chain stretched, any other input, grounds are good and coil packs changed out from another car. Or exhaust cam adjuster could be bad. I have a slapping noise in the head sounds like a bad valve but that would not explain a random misfire on all cylinders
Sent from my HTC Sensation 4G using Tapatalk 2
