Results 1 to 8 of 8
Thread: fuel delivery problem
  1. Junior Member
    Feb 26th, 2012
    falkville, AL USA
    2004 VW Phaeton, 1997 VW Jetta GLX VR6, 1997 Ford F150, 1962 Ford Falcon Ranchero
    06-04-2012 03:22 PM #1
    help. Stuck 398 miles from home. Car kept losing power, running out of fuel (even though I had a quarter tank). Stopped and filled it, but could only barely get to next exit. Step on gas- no go. Let off gas, car catch back up and run. Wife noticed definite new sound in back. Took her many miles and comments before it finally sunk in and I remembered the same groaning noise from a fuel pump going out on a cabrio. So, fuel pump bad. Am preparing to go out and jump terminals, as per bentley manual. That should tell if it is transfer pump or fuel pump. My main concern now is are the pumps under the rear seat or in the trunk?
    By the way, I made it to a motel (lucky enough one that accepts pets!)
    Jul 5th, 2008
    Strasbourg - France
    May 04 V8
    06-04-2012 03:32 PM #2
    Try cleaning your fuel filter first. If it is clogged, you won't get much fuel through it and the pumps will groan...
    P.
  3. Junior Member
    Feb 26th, 2012
    falkville, AL USA
    06-04-2012 05:16 PM #3
    where are they?
  4. Member
    Jul 5th, 2008
    Strasbourg - France
    May 04 V8
    06-04-2012 06:22 PM #4
    I don't know exactly, but I know that the fuel filter is easily accessible because (in order to avoid a fuel pump problem) I asked my dealer to change it during my last oil change and I was not charged any extra time, just the price of the fuel filter.
    This makes me think that it was just a matter of changing it (no disassembly was required).
    Good luck,
    P.
  5. Junior Member
    Feb 26th, 2012
    falkville, AL USA
    06-04-2012 07:43 PM #5
    searched this forum for fuel filter, came back with detailed instructions and location.
    By right rear wheel, under car. Will replace after a night of rest in the motel
  6. Junior Member
    Feb 26th, 2012
    falkville, AL USA
    06-05-2012 07:21 PM #6
    Changed fuel filter. Simple job. Fuel line clips were not as difficult as I thought they would be.
    Drove in parking lot- FULL POWER. Got on road and after about 20-30 miles thought I noticed diminishing power (loping engine) let off gas and drove easily trying to baby it home. The more I drove, the more evident and worsening condition of loping motor. As if running out of fuel. Finally died. Now 328 miles from home. Rollback truck coming tommorow to pick me the wife and the cat up. $800.00 Still fairly certain that I have fuel pump problems. Car will start, at first would run with soft gas pedal. Then got to where I had to completely let off gas so motor would not stall, then could softly accelerate and maybe get to 45 MPH. Then slower. Finally, will start and run for a second or two; but make sure the ac is off!
    Will know more after I get home and work on it.
    Just realized today that I have an affection for the car, and the costs so far have not ruined it. Note I said so far.
    Ray
    Jul 5th, 2008
    Strasbourg - France
    May 04 V8
    06-05-2012 08:15 PM #7
    Sorry it didn't work.
    P.
  8. 06-05-2012 09:21 PM #8
    Exact same symptoms I had. Fuel pump.... $800 for pump and labor. There are two fuel pumps. Mine only needed the one.
    Best if luck...
    Tully
