Nür Technik - HPA Motorsports Turbo Build
The Car:
(View from the Project Cam [Shop mounted GoPro])
2008 Audi TT
-3.2L VR6 Engine
-DSG Transmission
-Exterior color BLACK
-Haldex Controller
-HPA Dogbone Mount
-Dyno @ DBPerformance yielded 172awhp 184 ft/lb (DynoDynamics)
-Goal is 475bhp and 500 ft/lb
The build list:
HPA 20th Anniversary Turbo Kit
-Liquid cooled integrated short runner intake manifold
-After cooler package for integrated intake air to water intercooler
-Cast exhaust manifold, with external Oxygen sensors
-Hybrid GT35 Ball Bearing based turbo-w/integrated diverter and waste gate valve
-Stainless Steel Down Pipes (MK4 single 70mm, MK5 dual 55mm)
-Stainless Steel Turbo assembly Heatshield
-Custom wrapped Silicone piping with stainless steel clamps
-Head spacer plate to lower compression Head gaskets and Head Bolts
-500ml high flow fuel injectors
-4.0B return fuel system (MK5 only)
-Braided Stainless Steel Oil Feed Line
-Oil Return lines
-Performance ECU upgrade
Items that were upgraded from the 20th Anniversary Kit:
-High flow 100C Cat Cores
-Inline Fuel pump (Walbro)
-Race Grade Connecting rod bearings
-Large MAF
-750ml high flow fuel injectors
-88mm Full Custom Exhaust designed and manufactured at HPA Motorsports
-ARP Connecting Rod Bolts
Drivetrain Upgrades:
-HPA Stage 1 DSG Clutch Pack Upgrade 6:7 Disk Performance Clutch package
-HPA Stage 4 DSG Software
Additional upgrades:
-HPA 8 Piston Front Calipers paired with custom slotted RS6 (365mm) Rotors (Possibly getting Cryotreated at our neighbors (Frozen Rotors))
-Powdercoated rear OE Calipers (by Nur Technik) paired with 335mm Rear Rotors
-Osir Carbon Fiber Rear Valence with openings for the Quad tip exhaust
Here are the pics of said parts:
The build is scheduled to begin June 5th and have a tenative end date around June 18th depending on the swift work of HPA on the DSG components.
I will post GoPro images as well as some video along the way!
-David
Nur Technik, LLC
Performance Automotive Facility
11920 12th Avenue South
Burnsville MN 55337
952-322-7495
www.nurtechnik.com
service@nurtechnik.com
**Postcard in pics is 4x6 for scaling reference
The Car:
2008 Audi TT
-3.2L VR6 Engine
-DSG Transmission
-Haldex Controller
-HPA Dogbone Mount
The build list:
-Oil Return lines
-Large MAF
-David
Nur Technik, LLC
Burnsville MN 55337
952-322-7495
www.nurtechnik.com
