VWVortex.com - FS: 2000 VW Jetta GLX (VR6 5speed) - AS IS - $1700
    Results 1 to 2 of 2
    Thread: FS: 2000 VW Jetta GLX (VR6 5speed) - AS IS - $1700
    1. 06-04-2012 08:04 PM #1
      2000 Jetta GLX 5spd manual 137K miles- Top of the line trim, leather, sun roof, heated power seats, heated power mirrors, 5disk CD changed etc...
      Price is $1700 cash only! I have clear title in hand and will write up a bill of sale.
      The good:
      Powerful VR6 engine
      5speed manual transmission
      Runs well
      Transmission changed less than a year ago. Current transmission has 90K miles on it.
      Clutch, pressure plate replaced at the same time (brand new 1yr ago)
      New Bilstein shocks front and rear
      New spark plugs, ignition wires, air filter, fuel filter.
      Full size spare on the back-passenger side but I do have the original alloy rim (with a flat tire on it)
      Professionally installed hitch & wiring for a small trailer.
      The bad:
      As you can see in the pictures it has paint damage (scratches all over)
      There are dents in front of, and on the passenger side door (hit a deer)
      Driver side front strut needs replacement or wheel alignment, ran over something on the road.
      It does leak a bit of coolant once in a while. I add about a cup of coolant every 3 weeks, nothing major.
      Check engine light is on. Checked the code and its the O2 sensor. Easy fix.
      Link to pictures: http://imgur.com/a/LCAJj#0
      Serious inquiries only
      Call Boris @ 215-917-5272
    « Back
