Page 1 of 19 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 649
Thread: The clutch/transmission troubles thread.
  1. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-05-2012 04:10 PM #1
    Folks,
    This thread is to keep track of people who have run into a issue where the stock clutch disc was defective typically resulting in the material cracking and causing shifting issues that may also affect the transmission necessitating replacement.
    What I'd like to do is for everyone that has run into this issue to post the week or month their car was manufactured. For people who didn't order their cars and track their cars the best you can get is the production month. To find the production month for your car, look for the manufactured by Volkswagen Germany sticker on your drivers side door jamb. It'll look like this:
    The build month will be in the upper right corner, in this example, the build month is November 2011 denoted by the 11/11.
    If you ordered your car and had access or were given updates, the actual production week will be the date you want.
    The purpose of this is to see if we can narrow down a date range pattern where these cars fall into. I'm sure VWoA is also tracking this but, it's good information to have here I think.
    I've not had any problems with mine yet. I'm at 3k miles and my build week was 11/14/2011. I'm also APR Stage 2+ as of 6/4/11 and Stage 1+ as of 150 miles on the car.
  2. Member Gyntry's Avatar
    Nov 17th, 2009
    EauC, Wisconsin
    '12 Golf R
    06-05-2012 04:18 PM #2
    Sub'd!
    ClearWaterDubs Web -- CWD on Vortex
    2012 CW 4Dr Golf R - | APR Stage 2+ (93) | APR HPFP | Scorpion TBE | DXD Stg2 Endur Clutch | EVOMS V-Flow | BSH PCV Fix | Diesel Geek SS | HPA Dogbone |
    | NewSouth Boost Gauge | H&R FSB | H&R Sport Springs | Bistein Sport Rear Struts | LED Tails | Misc "Moar Better" Mods |
  3. Member VeeDubDriver's Avatar
    Oct 1st, 2001
    Boynton Beach, FL
    '12 Golf R Rising Blue / '11 Infiniti G25
    06-05-2012 05:25 PM #3
    Should be a sticky.
  4. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-05-2012 05:52 PM #4
    Got enough stickies already Don't want to clutter it up.
  5. Member Siliconrane's Avatar
    May 19th, 2009
    Camp Bullis, TX (San Antonio)
    2012 Golf R - Black
    06-05-2012 05:53 PM #5
    2012 Golf R - Black WETDUB
    HPA Softwares, APR HPFP, Scorpion TBE, Forge Twintake, HPA Mount, APR Flap Delete, Dieselgeek SS, RNS-510, 9w7 Bluetooth, JL 10w6 W/ Stealthbox, JL XD600/1, JL Cleansweep, P3cars.com Boost Gauge, Backup Cam, Color Matched Side Markers w/ bulb delete, LED Everything.
    (Build Thread)
  6. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-05-2012 06:08 PM #6
    I think you were one of the ones that was tracking your car, what was your production week?
  7. Member Siliconrane's Avatar
    May 19th, 2009
    2012 Golf R - Black
    06-05-2012 06:16 PM #7
    Quote Originally Posted by iThread View Post
    I no longer have that information. I am sorry. If I remember correctly, some time in late september / early October. It was one of the first ones built if I remember correctly.
    (Build Thread)
  8. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-05-2012 06:26 PM #8
    Quote Originally Posted by Siliconrane View Post
    No worries. But, the first builds happened in November which lines up with your door sticker.
  9. 06-06-2012 04:21 PM #9
    Mine is 1/12.
    I've got the grinds on high-RPM high-boost shifts, difficult to impossible gear selection on 2-3, 3-2, and less so 1-2 at higher RPM and the clutch pedal feels horrible; there is a lot of vibration and roughness.
    I have 3,300 KM on the car, no mods (I'm waiting until this settles), and one dealer visit where they, of course, said 'THERES NO PROBLEM!' however the shop foreman/manager/whatever did call me the next day and ask me to bring it in so he could investigate. Hmm.
  10. Semi-n00b
    Aug 30th, 2009
    OKC
    2012 Golf R, '86 323i S52
    06-06-2012 04:55 PM #10
    Production date on my car is 2012-01-12.
    My transmission / clutch trouble: http://forums.vwvortex.com/showthrea...y-Work-Already
  11. Member
    May 23rd, 2011
    Montreal
    06-06-2012 05:33 PM #11
    thanks. sub'd! seeing my dealer next week. experiencing some clutch and/or transmission problems with my R (only 3500 km...)
  12. Member _leo_'s Avatar
    May 21st, 2005
    Vaughan, ontario
    06-06-2012 08:38 PM #12
    by issues do you mean shifting into 3rd while at WOT and not beign able to hit the gate? if so i've been bashing my head against my steering wheel because i keep "missing" it. maybe this is a similar issue that others are having
  13. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-07-2012 01:12 AM #13
    Quote Originally Posted by _leo_ View Post
    That could be one manifestation of the problem. I say that based on other peoples threads. Best to keep a eye on it for now and not jump to conclusions though. Read through some of the threads linked here and see if the problem reproduces for you in the same way.
  14. 06-07-2012 06:32 AM #14
    Subscribed to this thread....
  15. Member droopy1592's Avatar
    Nov 13th, 2002
    Atlanta/Raleigh
    2012 RB Golf R
    06-07-2012 08:04 AM #15
    What is the main symptom?
    In many ways then this car is like herpes. Great fun catching it but not so much fun living with it every day. - Jeremy Clarkson
  16. Member Siliconrane's Avatar
    May 19th, 2009
    2012 Golf R - Black
    06-07-2012 12:09 PM #16
    Quote Originally Posted by droopy1592 View Post
    There are a couple of issues at play. If your clutch cracks - then it drags all the time - causing excessive wear on your synchronizers. It gets progressively more difficult to shift the heavier the load on the car. Driving normally will not readily reproduce any problems. More specifically, high rpm shifts will cause the transmission to lock you out because the synchronizers are unable to do their job due to clutch drag. Trust me . . . if you have driven clutch for any number of years . . . you will know something is VERY wrong.
    (Build Thread)
  17. Member GASMAN664's Avatar
    Apr 9th, 2011
    '04 R32 '12 Golf R
    06-07-2012 12:24 PM #17
    Yeah well all the stickies but one currently are ads...how about we actually sticky something useful to people like this issue or the build thread index or a DIY.
  18. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-07-2012 01:31 PM #18
    Quote Originally Posted by GASMAN664 View Post
    Actually I'd like to replace the delivery thread with a FAQ thread that contains links to the build thread index and the various DIY threads but, I've not had a chance to get to it and won't for a bit. But, if someone wants to step up.....
  19. Member GASMAN664's Avatar
    Apr 9th, 2011
    '04 R32 '12 Golf R
    06-07-2012 03:11 PM #19
  20. Member RBGolfR's Avatar
    Apr 3rd, 2012
    Everywhere
    RB Golf R , MKV GTI
    06-07-2012 03:17 PM #20
    Sub'd
  21. 06-07-2012 03:19 PM #21
    I'll pull all the links together for ya tonight after work
  22. Member Time for a GTI's Avatar
    Apr 25th, 2006
    MA
    '12 Golf R
    06-07-2012 03:22 PM #22
    Good idea. Really hope I don't need it though.
    FS: Golf R OEM HPFP
    Scotch. It's time.
    if i got my ass kicked every time I went to a particular bar, i'd own it, and ruin anything in my path.
  23. Member
    Sep 4th, 2011
    North Bethesda, MD USA
    2000 VW Golf (Sold) | 2002 VW GTI (Sold) | 2007 VW GTI (traded) | 2012 VW Golf R
    06-07-2012 06:58 PM #23
    Quote Originally Posted by Time for a GTI View Post
    When did your car come off the production line? Just curious
  24. Member Time for a GTI's Avatar
    Apr 25th, 2006
    MA
    '12 Golf R
    06-07-2012 07:25 PM #24
    Quote Originally Posted by JosephHatfield View Post
    02/12
    FS: Golf R OEM HPFP
    Scotch. It's time.
  25. Member
    Apr 9th, 2012
    Fort Irwin, California
    12 CSG R
    06-08-2012 02:27 AM #25
    Pro date 1/12 and car is going in on the 25th for diagnostic/hopefully warrantied service. My brakes are squeaking also
    APR Stage II+, APR HPFP, APR FMIC, 42DD Catless DP, BFI Catch can, Carbonio intake, Forge BPV, BSH Mounts, ECS Tuning aesthetic pieces, Hill assist terminated, Soundaktor be gone.
  26. Junior Member
    Sep 22nd, 2008
    2012 Golf R, CSG, 4dr
    06-08-2012 02:22 PM #26
    I'll update this post with my build info as soon as I get my car back.
    Build date: 1/12
    Delivery: 3/12
    Canadian Golf R
    To date:
    - Had a new transmission swapped in after experience significant vibrations
    - Currently having a new clutch pedal assembly installed after experiencing a strange pop/click from the pedal, after the initial "free play/travel" at the top. Apparently the piece that the pedal pushes into the master cylinder does not fit properly into the pedal - perhaps someone grabbed the wrong part when putting my car together.
    Service assures me that my clutch is currently OK...
    UPDATE: I got my car back a couple weeks ago, and the clutch pedal assembly had been replaced (not sure how much or just a part of it). Popping/clicking is gone, and the pedal feels a lot more "normal." There is still a little vibration in the pedal, but very little - I think it's the "normal" level of vibration? No work was done on my clutch, was assured it's still good. Will see when I go in for my first service in about a month to get them to confirm everything.
    One thing I do still notice is the excessive clutch noise. If I let the revs drop and jump off the clutch, there's definitely clatter/clicking sounds from the transmission/clutch area. If I feather off, there is no sound. I've read that this seems to be the norm for our cars, but just wanted to document it here anyway. I typically feather off the clutch when shifting, so it's not an issue anyway.
  27. Member Whisp's Avatar
    Dec 24th, 2004
    Fort Lauderdale,FL
    05' GLI, 12' GOLF R
    06-08-2012 02:26 PM #27
    02/12
    mine is the same, havent felt any problems yet and hope to not, clutch and tranny feels about the same as the O2M in my GLI before i did a clutch and shifter upgrade
  28. Member peruski's Avatar
    Mar 28th, 2006
    SE MI
    Golf R
    06-08-2012 02:29 PM #28
    Gah ! Mine is 12/11 production date. Now I am paranoid.
  29. Member
    Dec 2nd, 2011
    Burlington, NC
    2012 Golf R RB 2D L
    06-08-2012 02:33 PM #29
    Wow... there's quite a few here who have had trouble. I thought it was only 2 or 3 cars, maybe 4.
    I'm at 2,400 miles and haven't encountered any problems. I've had a couple of wonky shifts but it was probably my fault. Will keep an eye on it. Early November production for me (took delivery on the same day as Siliconrane).
  30. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-08-2012 02:35 PM #30
    Figured I should also include this:
  31. Member VeeDubDriver's Avatar
    Oct 1st, 2001
    Boynton Beach, FL
    06-08-2012 02:38 PM #31
    Seeing how this is drive-train related, I am wondering if those affected should file a report with the NHTSA, just so they can have a record of the issue and perhaps keep VW honest on this?
    https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
  32. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-08-2012 02:41 PM #32
    Quote Originally Posted by VeeDubDriver View Post
    I don't think anyone here has ad VWoA being dishonest about this. Everyone with the problem has been repaired without much hassle it seems.
  33. Member
    Dec 2nd, 2011
    Burlington, NC
    2012 Golf R RB 2D L
    06-08-2012 02:54 PM #33
    Has anyone had dealers giving them the cold shoulder due to mods though? My local VW dealer is a tiny little place and I have a feeling if I roll in there with a warranty issue that could theoretically cost them thousands of dollars they're going to show me the door.
  34. Global Moderator iThread's Avatar
    Sep 27th, 2005
    06-08-2012 02:56 PM #34
    Quote Originally Posted by jsausley View Post
    Nope, it's not happened to anyone on this forum so far.
  35. Member Siliconrane's Avatar
    May 19th, 2009
    2012 Golf R - Black
    06-08-2012 05:59 PM #35
    The dealerships don't loose any money. Vwoa reimburses them for all warranty work. They have to get it approved by them before they lay a wrench on your car.
    Honesty gets you a long way with the dealerships.
    (Build Thread)
