Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 76
Thread: The Utimate Parts Thread!!! NOS, NLA, OEM, OE, NIB, Performance, Aftermarket, Some used, TOTAL LIQUIDATION, Lowballers welcome!!!
  1. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    06-07-2012 04:20 PM #1
    I have been asked to clean out some old inventory at a local shop that no longer works on VW/Audi consistently. I haven't had a chance to cross reference part numbers for car specific items, but have been creating a database which is FAR from finished.
    All parts are listed with price, OBO. I will be organizing the list over the next few weeks to put up in the appropriate parts threads, but figured I'd start here to help the locals out first. If you would like to talk about purchase of the entire lot for a killer deal, pennies on the dollar, I will entertain that as well. All items are marked between 50-75% of what new would cost.
    If you have any questions about the PN's and fitment of your vehicle(s), please PM me and I will pull up ETKA.
    Here are some pics and the list so far, only about 15% completed. Enjoy
    Everything listed is NIB unless notated otherwise.
    Engine:
    Mann Air Filter 058.133.843 Fits: Audi Allroad (01.05), A4 18 4CYL (97.05), A6 V6 (98.04), A6 V6 BT (00.08), & S4 27 V6 BT (00.08) only
    Mann Air Filter 1H0.129.620 Fits: 73 Different VW models, Mostly MKIII & MKIV, $5 (2 available)
    Mann Air Filter C.3474 Fits: 133 Different VW models, $5 (3 available)
    Mann Air Filter C.34.109 Fits: 124 Different VW models, $5 (2 available)
    Bosch Air Filter 73456, Fits: Quite a few Audi, VW and BMW vehicles, $10
    Micro Star Oil Filter OC.51, $5 (4 available)
    Passat AC Dryer OEM 3A0.820.191 (94-97 4 cyl), $20
    Bosch Fuel Filter OEM 0.450.905.133, $5
    Bosch Fuel Filter OEM 0.450.905.401, $5
    Meistersatz Coolant Flange Kit, 037.198.144.J, $10
    OEM MAF Audi A6 06C.133.471.A, $95
    OEM Bosch MAF Housing 3”, 06A.906.461.A (2 available)
    OEM Diverter Valve, 06A.145.710.P
    OEM Wastegate Solenoid Valve, 028.906.283.F
    OEM Purge Valve, 1C0.906.517.A
    OEM Front Motor Mount AAA VR6 1H0.199.609.K
    OEM Rear Motor Mount (hydro) 535.199.262
    OEM Transmission Mount, 191.199.402.C
    OEM Motor Mount, MKI PS 893.199.381 (2 available w/brkt, 1 w/o)
    Febi Motor Mount, 171.199.214.D
    OEM Motor Mount, 171.188.214.G
    OEM Motor Mount, 175.399.151
    Hutchinson Front Motor Mount, 1H0.199.262.A/H
    OEM Bosch ISV, 0.280.140.512, (used)
    Febi Belt Tensioner, 028.109.243 (2 available)
    Ruville Timing Belt Tensioner, 026.109.243.L
    GMB Timing Belt Tensioner, 068.109.243
    OEM Tensioner 021.109.507.A (2 available)
    OE Timing Belt Tensioner, 058.109.243.E
    Bosch Injectors GB Reman “Ford” Orange Top, 0.280.150.943 (6 available)
    Elring Tension Gasket Kit, 058.198.217
    Elring Shaft Seal, 357.501.641
    OEM O-Ring, 038.121.119.B (2 available)
    OEM O-Ring, 010.323.533 (2 available)
    OEM O-Ring, 902.628.02
    OEM O-Ring, 010.409.549.B, (6 available)
    OEM O-Ring (metal), 020.311.391
    OE Seal Kit, 311.598.051.B
    Febi Seal, 068.198.821
    OE Seal, 010.321.371
    OEM Seal Cap, 020.409.289.B (6 available)
    Elring Seal, 357.501.641.B
    Elring Seal, 020.311.113.B
    OEM Seal, 443.955.465
    OEM O-Ring (metal), 020.311.391.D
    OEM O-Ring, 096.409.069.A
    OEM O-Ring, 010.409.529.C (2 available)
    OEM O-Ring, 035.121.119
    OEM O-Ring, N.901.368.02
    OEM O-Ring, Trans Cooler, 089.409.069 (2 available)
    OEM O-Ring Seal Kit, 020.498.055, (2 available)
    OEM O-Ring (brass), 020.409.231
    OEM O-Ring, 003.323.525.A
    OEM O-Ring (metal), 020.409.231
    OEM, O-Ring (metal), 020.311.391.C (4 available)
    OEM Flange Gasket, 021.115.446.A
    OEM Screen Gasket, 095.325.443.A
    OEM Gasket, 155.253.115
    OEM Gasket, 027.129.717 (2 available)
    OEM Gasket, 4B0-713-187.C
    Meistersatz 16v Valve Cover Gasket Set, 027-198.025
    Victor Reinz Head Gasket, 4 cyl (metal), 037.103.383.H
    OE Oil Pan Gasket, VR AAA, 021.103.609.B
    Elring Head Gasket, 4cyl (fiber), 049.103.383
    Elring Head Gasket, 4cyl Diesel (fiber), 068.103.383
    Elring Valve Cover Gasket, 058.198.025.A
    Elring Oil Pan Gasket, 044.103.609
    OE Valve Cover Gasket, 8v, 051.103.483.A (3 available)
    Victor Reinz Valve Cover Gasket, 078.198.025
    Elring Seal Kit, 113.198.031
    OEM Cap, 088.301.467.B
    Gemo Throttle Cable, Golf II 83+, 191.721.555 (2 available)
    Gemo Throttle Cable, 171.723.555
    Febi Oil Pump w/pickup, M-9361/M-9430 internet says Mercedes, but looks like ABA
    OEM Breather hose (plastic), 037.103.211 (2 available)
    Bosch Fuel Filter, 0.450.906.281
    Bosch Fuel Filter, 0.450.905.133
    OEM Oxygen Sensor, 021.906.265.AL
    Cooling:
    Wahler Thermostat, 075.121.113, (2 available)
    Wahler Thermostat, 056.121.113
    OEM Coolant Flange, 012.121.117.A, (used)
    OEM Coolant Flange w/seals, 012.121.117.A, (2 available)
    OEM Coolant Flange, 012.121.133.O, (used)
    OEM Coolant Flange, 068.121.133.AB
    OEM Coolant Flange, 06A.121.133.Q
    OEM Coolant Hose, 037.121.058.A
    Wahler Thermostat, 078.121.113
    Wahler Thermoswitch, 823.959.481
    Bosch Coolant Temp Sensor, 280.130.040
    OE Water Pump (metal impeller) V6 Audi/VW
    OE Water Pump Housing w/seal, ABA
    OE Water Pump (plastic impeller), ABA, 026.121.005.F (2 available)
    OE Radiator Hose, 305.121.101.2
    OEM Coolant Hose, 027.121.053
    OEM Coolant Hose, 171.121.121 (2 available)
    OEM Coolant Hose, 305.121.101
    OEM Crack Pipe, VR AAA, 021.121.085.E
    OEM Coolant Hose, 191.121.101
    Febi Coolant Bottle, 171.121.407.E
    Exhaust:
    OEM Exhaust Hanger, 191.253.147.A (9 available)
    Exhaust Hanger, 357.253.144.E, (3 available)
    Aftermarket 4 to1 Exhaust Header, unknown fitment
    XO2 Racing, V-Band Flange Seals, 2.5”, (2 available)
    OE Exhaust Seal, 028.129.589
    Suspension:
    Febi Wheel Hub (splined) 357.407.615, Fits: Most all VW/Audi 4 Lug Models, $15 (2 available)
    Meistersatz Wheel Bearing, 171.407.625.D
    Tegufa CV Axle Boot Kit 171.498.203, $5 (4 available)
    Tegufa CV Axle Boot Kit 191.498.201, $5 (3 available)
    Tegufa CV Axle Boot Kit 321.498.201, $5
    Tegufa CV Axle Boot Kit 321.498.203, $5 (4 available)
    GKN CV Axle Boot Kit, 191.498.104, $5
    Meistersatz CV Axle Boot Kit, 191.498.202, $5 (4 available)
    Meistersatz CV Axle Boot Kit, 191.498.201, $5 (5 available)
    Meistersatz CV Axle Boot Kit, 171.498.203, $5
    GKN CV Axle END Kit, 171.489.103, $10
    Meistersatz Axle Seal Repair Kit, 020.498.085.G
    Febi Ball Joint, 191.407.365
    Febi Ball Joint, 171.407.365 (2 available)
    Ocap Ball Joint, 855.407.366.A
    OEM Strut Bushing w/bearing & cap, 357.412.1329
    OEM Lower Control Arm Bushing (front) 357.407.182 (2 available)
    OEM Strut Bearing, 1J0.412.249 (2 available)
    OEM Bump Stop, 171.512.131.B (2 available)
    OEM Bump Stop, 770002 (2 available)
    OEM Strut Bushing, 1J0.412.331 (2 available)
    OEM Bump Stop, 191.412.303 (2 available)
    OE Boge Strut, 200.413.031 (2 available)
    OE Boge Strut, 171.513.033.N (2 available)
    OE Boge Strut, 200.412.031 (2 available)
    Body:
    Passat Door Latch Left Front OEM 357.837.015.G (Says 90-98), $30
    OEM Hella Door Handle w/lock cylinder & 2 keys, 61895 (2 available)
    OEM Hella Door Handle, no lock cylinder, 61898, (2 available)
    OEM Hella Door Handle, rear, PS (2 available), DS (2 available)
    OEM Gass Clamp, 535.867.540
    OEM Lock Cylinder w keys, 330.837.167.G
    OEM Door Lock/Handle Repair Kit, 357.898.084.A
    OEM Trunk Button w/2 keys, 357.827.571.G
    OEM Fuel Pump Casing for external pump w/filter bracket, 165.201.042.A
    A/C:
    Mann Cabin Filter CU.3955 Fits mostly all Audi’s, Passat’s and all 98.2001 VW models, $5 (2 available)
    Behr A/C Dryer, 1H0.820.191.A
    OEM A/C Dryer, 176.820.191
    OEM A/C Dryer, 357.820.191.D
    OEM A/C Dryer, 1J0.820.191.D (3 available)
    OEM Expansion Valve Cover, 1H0.820.692
    OEM Blower Motor Resistor, 191.959.263
    Ranco A/C Pressure Switch, 357.959.139.B (used)
    OEM A/C Pressure Switch, 1H0.959.139.B
    OEM HVAC Drain Hose w/grommet, 191.820.119.A
    OEM AC Bushing Kit, 059.998.263.A
    Interior:
    OEM Turn Stalk, 860.953.513.J.01C
    Autobahn Fog light Switch Kit,( MKI OE look), ZVW.123.276
    OEM Glove Box Door Lock Mechanism for MKIII, 1H1.857.131
    OEM Interior Door Pull, 1H0.839.019.B41
    West Coast Metric Window /Door Handle Buffer113.235.A-BK, (3 available)
    OEM Window Regulator Damper (set of 3), 535.837.417
    Febi Window Regulator (cable), 191.837.401.B
    Febi Window Regulator (cable), 191.837.402
    OEM Window Regulator (scissor), 155.837.461
    OEM Window Crank, 321.837.581 OEM Relay, 321.035.109
    OEM Window Switch, 191.959.561 (3 available)
    OEM Window Switch, 191.959.855 (9 available, 1 w/surround)
    OEM Hazard switch, 191.953.236
    OEM Defrost Switch, 175.959.621.A
    OEM Sunroof Switch, 357.959.855
    OEM Headlight Switch, 251.941.535
    OEM Headlight Switch, 1HM.941.531.R.01C
    OEM Brake Indicator (dash), 157.919.235, (9 available)
    OEM Dash Blank, 307.957.087.1
    OEM Bulb Holder, 357.919.243
    Braking:
    Febi Brake Shoe Kit (4 pcs) 1H0.698.525, Fits: Most VW/Audi models with rear drums 88+, $15
    Febi Brake Shoe Kit (4 pcs) 867.698.525, VW 180 mm rear brake shoe set for any rabbit, scirocco, cabriolet, fox golf or jetta from 79.88, $15
    Lucas Girling Caliper Rebuild Kit, 535.698.671
    OEM Brake Line (rubber) 307.201.218.3, $5
    OEM 20mm Master Cylinder 20mm (reman)
    OEM 23mm Master Cylinder
    Lucas 22mm Master Cylinder
    Febi Brake Slave Cylinder, NA-10 (2 available)
    OEM Brake Reservoir Cap, Varca 13 VPDF-00094
    OEM Rear Proportioning Valve/Pressure Regulator, 357.612.151
    OEM Rear Proportioning Valve/Pressure Regulator, 205G3 03.6500-0316.1 ACO
    Gemo Hand Break Cable, 191.609.721 (3 available)
    Steering:
    Febi Tie Rod End, 4B0.419.811.E
    Moog Tie Rod w/both end links, 357.422.804
    OEM Tie Rod, 191.422.803.A
    Febi Tie Rod w/both end links and boot, 171.419.804 or 175.419.804
    TRW Tie Rod w/both end links, 191.422.804
    Moog Tie Rod w/both end links, 357.422.403
    Febi Tie Rod w/both end links, 175.419.804
    Febi Steering Boot 175.422.831, 6K010.10 (2) $5
    OEM Steering Rack Boot, MKII Manual Rack, 191.419.831 (4 available)
    Electrical:
    OEM Fan Control Module, 1J0.919.506.K, $20
    OEM Fan Control Module, 357.919.506.A
    OEM Fan Control Module, 1H0.962.257.A
    OEM Fan Control Module, 1H0.919.506.A
    OEM VDO Door Lock Central Vacuum Pump, 443.862.257.A
    OEM Washer Pump, 1H6.955.651
    Gemo Speedo Cable, 171.957.805.B (2 available)
    OE Speedo Cable, 171.957.809.B
    Gemo Speedo Cable 171.957.803
    OEM Fuel/Coolant Gauge, 357.919.045.N
    Transmission:
    Meistersatz Auto Trans Filter Kit, 01M.398.009, $10
    Meistersatz Auto Trans Filter Kit,095.398.009.FE, $10
    OEM Throw-out Bearing, 510.0071.10, 06.C.07.B.A
    OE Final Drive Seal Kit, 020.498.085.G
    OEM Throw Out Bearing, 091.141.165.B
    Febi Shift Repair Kit, 191.798.116.A
    OEM Shift Linkage, 171.711.574
    OEM Shif Linkage, 171.711.593.D (2 available)
    OEM Shift Linkage, 191.711.574
    OEM Shift Linkage, 1H0.711.574
    Gemo Clutch Cable, 171.721.335 (2 available)
    Gemo Clutch Cable, 307.721.335
    Gemo Clutch Cable, 531.721.335
    OEM Diff Kit, 171.498.088.A
    Unsure A.T.M.:
    OEM Damping rubber, 171.721.308
    (CONV) Rabbit Conv./Golf Cabrio.1.5/1.6ltr.(JEG) Jetta1.5/1.6ltr.(SCI) Scirocco1.5/1.6ltr.
    OEM EG Auto Cup, 823.711.642.B
    OEM EG Auto Adjust Screw, 165.941.141.G
    IKS Cable, (unsure of usage), 305.609.721-6
    All MKIV parts are used
    MKIV R32: OEM headlights w/fogs, good condition, all tabs in tact, $200
    MKIV R32: Euro headlight switch (2), $20 ea BOTH SOLD
    MKIV R32: Rear strut tie bar, unsure of manufacture, $75
    MKIV R32: Clear sidemarkers, $30 SOLD
    MKIV R32: Clear side repeaters, $30
    MKIV R32: OEM whip antenna, $30 SOLD
    MKIV R32: OEM Grille's, Both sides, like new, $50
    MKIV R32: R32 front grille badge, $35
    MKIV R32: Cone filter intake w/MAF housing, $20 SOLD
    MKIV R32: Misc interior bits
    Set of Rc's in good condition w/decent rubber, $450 SOLD
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  2. Member dhudak818's Avatar
    Nov 10th, 2009
    BMP 20th / Silverstone 24v / Cabriolet
    06-07-2012 05:35 PM #2
    that stack of rotors...didnt see them listed. What vehicle are they for? Specs? Are they even available?
  3. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-07-2012 06:04 PM #3
    Quote Originally Posted by dhudak818 View Post
    Not sure on spec and din't have any PN's listed. I was going to try to measure them, but don't know if I can get accurate measurements with the available tools. They are 5 lug and the owner said they are for VW/Audi, but as I said, don't even know if they are 5x100 or 5x112, some of them didn't even have the spot for the set screw, but 2 are super nice, well 3 actually the small rear is nice as well, the other couple just have some surface rust. All 5xSomething and I will see if I can get over there tomorrow for some measurements
  4. Member
    Mar 21st, 2003
    Columbia, SC
    '10 WE, 96 JetTa, couple corrados & randoms
    06-07-2012 07:48 PM #4
    interested in rotors as well
  5. Member aligti's Avatar
    Dec 1st, 2002
    NoVA
    07 BMW 525i sport,03 Jetta 2.0,93 Corrado SLC(Sold)
    06-07-2012 08:21 PM #5
    would u have a chip for 93.5 Corrado VR6 w/o cams or w cams? also looking for 268 cams for the same car..let me know price shipped. thanks.
  6. Member the_toad's Avatar
    Sep 15th, 2005
    Mableton, GA
    2 '87 Audi 5000S', '99.5 VW Cabrio
    06-07-2012 08:46 PM #6
    I'm interested in that 266 cam, also are any of those chips for an obd2 ABA?
    NewBeetle.org | You just nostalgia'd
    "Funny memorable words go here, you'll never forget it"
  7. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-07-2012 09:24 PM #7
    Quote Originally Posted by 96VDubbin View Post
    Quote Originally Posted by aligti View Post
    Actually, I will be dismantling my roomates Corrado OBDII, he is currently running DRC 268's & a C2 tune, going Megasquirt 3 & longblock from Shimmel, parts will be available soon
    Quote Originally Posted by the_toad View Post
    Unfortunately the chipsets I have researched are OBDI and only one was for that motronic unit, 28 pin, cam is still available, but have had several PM's as I listed it in the MKIII & Engine classifieds
  8. Member aligti's Avatar
    Dec 1st, 2002
    NoVA
    06-07-2012 11:47 PM #8
    Quote Originally Posted by Sr. Karmann View Post
    Actually my Corrado is an OBDI w coil pack. would that cam still work w it? let me know when u have it available.
  9. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-08-2012 12:07 AM #9
    Cams will still work, I will let you know when we remove them
  10. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-10-2012 01:01 PM #10
    Just got a bunch of MKIV R32 parts dropped off yesterday, used but not long.
    Euro headlight switches
    OEM antenna mast
    some interior bits
    Clear sidemarkers
    Rear strut bar
    and some other stuff I'm sure I forgot
  11. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-11-2012 12:56 AM #11
    Adding this MKIV R32 parts:
    A friend asked me to post some of the stuff he had left over after he sold his R. Everything is OBO, if you have any questions, feel free to ask, pics up tomorrow.
    Misc interior bits
    There may be more, I will add tomorrow when I get pics up. If you think any of the prices are not on point, please let me know, thanks
  12. Member rudell640's Avatar
    Jul 4th, 2006
    Spring hill, fl
    03 TR VW Gti 1.8t
    06-11-2012 06:28 AM #12
    what kind of mkiv r32 interior bits do you have? I'm looking for the front center console shifter surround, and some aluminum trim.
  13. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-11-2012 10:06 AM #13
    Quote Originally Posted by rudell640 View Post
    I don't have the shifter surround and don't think I have any more aluminum bits (sold the lower center console one already) I do have a dead petal in good condition.
  14. Member R32Tony's Avatar
    Dec 23rd, 2004
    Ft Lauderdale Florida
    2004 R32 T-Red, (D-Blue RIP), 2002 Jetta 1.8t. 1951 Pontiac Chieftain, 2007 Triumph speed triple,
    06-12-2012 01:01 AM #14
    They are my left over parts. He also has the brand new Cupra R lips in the original plastic $100
  15. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-12-2012 01:27 AM #15
    PICS UP FOR R parts!
    Also an update on prices and additional parts
    OEM Lower Bumper Grille's, Both sides, like new, $50 set
    OEM R32 front grille badge, broken tab, $35
    OEM Misc interior bits, $5 ea
    OEM Dead pedal, $45
    OEM Mirrors, $20
    Cupra R Lip, NIB, $100
  16. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-13-2012 02:07 AM #16
    Edited the NOS parts list for everything I have minus the various belts (about 40), the brake rotors and a few miscellaneous parts. I will be organizing the list over the next few days. Thanks for looking and I appreciate the first round of sales
  17. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-16-2012 12:55 AM #17
    bump
  18. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-16-2012 02:28 AM #18
    List is organized somewhat
  19. Member VR6witHRE's Avatar
    Mar 27th, 2008
    NY,NJ,Miami FL
    1997 Go Ped
    06-16-2012 11:50 AM #19
    any mk2 parts?
  20. Member One_Off_Volk's Avatar
    Nov 30th, 2011
    L-Town, NH
    mk6 jetta, 1992 corrado r32 (in progress)
    06-16-2012 12:26 PM #20
    I need the OEM window regulator and dampers
  21. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-16-2012 02:07 PM #21
    Quote Originally Posted by VR6witHRE View Post
    any mk2 parts?
    Loads!!! I will be breaking the parts list up over the next week or so and placing in specific threads. If there are parts you have in question or somply need, shoot me a PM and I will cross reference #'s in ETKA
    Quote Originally Posted by StayFatlaceMK3 View Post
    The Scissor reg? and damper set of 3, correct?
  22. Member tw1st3dcory's Avatar
    Jul 19th, 2011
    Tampa, FL
    Mk4 VW GTI 1.8t
    06-17-2012 07:56 AM #22
    im interested in the mkiv r32 headlights. willing to ship to 33634? its Tampa, FL
  23. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-17-2012 10:02 AM #23
    Quote Originally Posted by tw1st3dcory View Post
    Sure, they are already boxed up
  24. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    06-27-2012 10:29 PM #24
    up
  25. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    07-04-2012 10:25 AM #25
    Hey Chad,
    can you list Corrado specific parts, G60 specific parts and MK1 Golf specific parts?
    Hit me up on FB later so we can talk
    Quote Originally Posted by dogger View Post
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  26. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-04-2012 11:41 AM #26
    Quote Originally Posted by RedYellowWhite View Post
    Hey Chad,
    It will take me a while to figure what is for what, I do have quite a few items that I know will work for both. I have been super busy with my new job, but try to put something together for you. I won't be able to get back to you today as we are celebrating our independence
  27. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    07-04-2012 02:25 PM #27
    No problem buddy
    I already googled a few P/Ns myself and found some interesting parts
    Happy 4th of July
    My MK1 build thread
    SpoonFedTuning
  28. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-04-2012 04:15 PM #28
    No problem buddy
    Happy 4th of July
    Ya man, there are tons of good parts that may not even be available anymore or simply expensive, I'll make you a killer deal
    Shoot me a message on FB and I'll see what we can get sorted for you.
    Thanks for the 4th wishes, you too .....................
  29. Member ShotgunFacelift's Avatar
    Feb 23rd, 2007
    Houston, TX 77019
    92 GTI ABA (sold), 09 Passat 2.0T, 91 535i/5
    07-09-2012 01:05 PM #29
    Ooh ooh, I need stuffs! I'll actually be down in Lauderdale this upcoming weekend to visit my mom, so that could help shipping if I can just pick the stuff up.
    Anyways, let me know if you have any of this stuff...
    - 89-92 E-brake cables for rear disc
    - Mk3 2.0 front brake rotors
    - Mk3 2.0 non-ABS master cylinder
    That's all I can think of for now but I'm sure there are a few more things I need. Let me know!
  30. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-09-2012 01:14 PM #30
    Quote Originally Posted by ShotgunFacelift View Post
    I believe I have the master and possibly the cables. I don't think I have the rotors for it, unless you have a nasty 5 lug swap
    I have a few folks I need to look into the parts bin for, so let me know if you see anything else you need and I will make sure it is set aside. I plan on going to the warehouse for about an hour on Saturday to pull parts. I can only access the warehouse on Saturday.
  31. Member ShotgunFacelift's Avatar
    Feb 23rd, 2007
    Houston, TX 77019
    07-09-2012 01:43 PM #31
    That's cool, rotors are pretty cheap anyway. What would you be looking to get for the MC and cables? I actually really only need one cable but will buy the pair if need be. I'll be down there from Friday night to Sunday afternoon so Saturday is perfect. lol
  32. Member aligti's Avatar
    Dec 1st, 2002
    NoVA
    07-09-2012 11:11 PM #32
    Any word on the cam from ur roomate's C? looking to do this soon and I'm getting all my parts together. let me know.
  33. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    07-10-2012 12:05 AM #33
    Cool man, he changed direction on the motor, no more shimmel long block cause he won't respond to emails, so he is going to send it to some guys on the west coast of FL for a rebuild. the management, all ignition components will be for sale in about a month
  34. 07-15-2012 02:23 PM #34
    You don't have a TT short shifter, do you?
    DoC Dubz 8v Society #420 (_fishbowl society_)™
    Quote Originally Posted by Chitownsfinest View Post
    Really.. Dude.. stupid fking rabbit trix are for kids.
  35. Member BeetleGpx's Avatar
    Oct 19th, 2004
    Anniston, AL
    Hilde: 85 Golf 8v
    07-15-2012 07:27 PM #35
    Still sorting the mess out? havent heard back from ya
    Yeah, it's an 8v. If I wanted a sporty car, I'd buy an R.
