Hi,
Need to know which relays i need to test for the windows and the starter motor. please help.
Also code is showing no power at terminal 30.
the starter and windows stopped working. It is wierd that when ever the starter wouldnt crank the windows wouldnt work. If i waitied till the windows worked then the starter would work. now both are out completely.
But at one point i disconnected the battery and took the starter out to test(tested fine, starting the car with a wire n switch between starter and pos terminal) when i reconnected the battery the front windows were down and were reciving power as i could here the motors running but wouldnt wind up as if the car already thought they were wound up.
so i removed the fuses for windows now no power is getting to them at all, even though i tested the fuses and are good and put the fuses back in and there is power going throught the fuses.
when i switch ignition on and press the break the light on the gear selector goes off so the car know the break is pressed. also the gear indicator on the dash is showing the currently selected gear, so the car know what gear it is in too which makes that car smarter than me cause it knows all kinds athings about itself that i dont.
