Page 3 of 3 FirstFirst 1 2 3
Results 71 to 103 of 103
Thread: Any Recommendations on Interior LED lighting?
  1. Member TurboGliMK4's Avatar
    Aug 26th, 2009
    08873 NJ
    MK6 CSG GTI : ) R.I.P 2004.5 BMP GLI
    07-26-2012 09:58 AM #71
    Quote Originally Posted by E CODE View Post
    Well... assuming she drives at night with the headlights on - they will be on. Any time your lights are on, the fottwells are too.
    Try jacking up the brightness via the MFI and see if that helps. Maybe they just aren't bright enough.
    you can make them really bright.
  2. Member JustinKYC.'s Avatar
    Jul 4th, 2010
    Calgary, AB
    2011 Volkswagen GTI
    07-26-2012 11:22 AM #72
    Quote Originally Posted by blackout2006 View Post
    she wants them on when she drives at night or when she turns the headlights on
    they should be on at night if you turn on the headlights. like E CODE said, you might have really dim LEDs so just go on MFI and raise the dimmer.
    2011 CW MK6 GTI
    APR Stage 1 / Koni Coilovers / 18x8.5 Miro 111 ET45 / R Tails / LEDs (Interior, Side Markers, Parking Lights, License Plate) / Euroswitch
    Ma Build Thread
  3. Junior Member
    Jul 31st, 2012
    San Antonio, TX
    RS '12 2D Golf
    08-03-2012 11:47 PM #73
    Looks like LED Wholesalers is out of the red LED. They have blue though
    http://www.ledwholesalers.com/store/...&productId=337
  4. Member rhodri45's Avatar
    Feb 19th, 2012
    Chucktown SC
    static mk6 GTI, variable mk3 GLX
    08-03-2012 11:49 PM #74
    Quote Originally Posted by t0eknee View Post
    do NOT get blue:
    1) it will NOT match the rest of your interior
    2) blue is rice
    3) it destroys your night vision
    4) ????
    5) blue is rice
    6) blue isn't really rice, the older models and the new Golf R uses blue in the gage cluster however, it is quite ugly imo.
    I've seen hookers with less gap.
    Click here for lulz. ~
    mk6. | Instagram @rhodri45 | Chucktown Dubs.
    Aug 13th, 2010
    06 jetta tdi / 2012 cw 4dr golf tdi
    08-04-2012 02:55 AM #75
    hopefully going to try and get away with not starting a new thread....
    Couple picture requests.
    1 back of footwell light housing.
    2 either wiring diagram for footwell light harness or a picture of the harness itself.
    Might possibly be looking into mounting two aditional red foot well lights under the back of the front seats for the rear. ( rice? sure call it what you want but rugrats drop crazy stuff and when your arms are full and want to see a little better i think it will be a nice little add on.)
    Thanks for any help guys/gals.
    I'm assuming that a few of your birth certificates were accompanied with an apology letter from the condom factory.
  6. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    08-04-2012 08:59 AM #76
    Here is the light with the metal shroud removed:
    The harness is literally just two wires in a small spring clip.
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  7. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    2012 Golf/1988 Cabby
    08-07-2012 03:48 PM #77
    Hey Guys,
    Does the Stock GTI include both Front and Rear footwells? Thinking of doing a Retrofit.
    Thanks
    -Mike
    Will Vag for Beer.
  8. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    08-07-2012 07:12 PM #78
    Quote Originally Posted by phish32786 View Post
    Hey Guys,
    Thanks
    -Mike
    No - only front.
  9. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-07-2012 07:41 PM #79
    Thanks E CODE
    Will Vag for Beer.
  10. Member
    May 8th, 2010
    Canberra, ACT, AU
    2012 Golf GTI
    08-10-2012 10:44 PM #80
    Quote Originally Posted by Tiggyjiggy View Post
    I just ordered these:
    http://store.ijdmtoy.com/Volkswagen-...-p/vw-df10.htm
    Will let you know what they're like.
    Do not get this kit if you don't have a US spec car, it will not fit , the front light panel is different.
    This:
    Will not fit into this:
    Despite the website saying it will fit "2009-2012 Volkswagen MK6 Golf or GTi". Hopefully I get a refund, will keep you in the loop.
  11. Member Smoky_Llama's Avatar
    Nov 21st, 2005
    Bellevue, Nebraska
    12' GTI, 10' Specialized Hardrock
    08-11-2012 02:22 AM #81
    Do not get this kit, it will not fit a MK6 GTI, the front light panel I think must be made for a MK5.
    This:
    That's a different console than we get in the u.s.
    Need Vag-Com in Eastern Nebraska and Western Iowa? Send me a PM.
    Quote Originally Posted by Arin@APR View Post
    We don't run a business where we inspect damaged ECU's, completely destroy them, and/or whatever you were saying about your penis.
    May 8th, 2010
    Canberra, ACT, AU
    2012 Golf GTI
    08-11-2012 04:34 AM #82
    Quote Originally Posted by Smoky_Llama View Post
    Well that would be why it doesn't fit then
  13. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-11-2012 02:45 PM #83
    Installed mine today, they look great, got mine from LED Wholesalers.
    In other news I ordered a couple extra T10 whites for the footwells, the retrofit kit hasn't come in yet, so popped them in the License Plate. Threw the Bulb error, VAGCOM'd it out with an Module 09, Byte 23, Bit 6 un-check. Profit.
    Will Vag for Beer.
  14. Member Smoky_Llama's Avatar
    Nov 21st, 2005
    Bellevue, Nebraska
    08-11-2012 05:00 PM #84
    Wow no errors? I didn't think that was possible, nice!
  15. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-11-2012 09:26 PM #85
    Alright some weirdness. So it finally got dark out and I noticed when I have the switch set to on when door open, the lights are all on, just really dim. If I switch to all off the bulbs do shut completely off. Anyone else see this.
    Will Vag for Beer.
  16. Junior Member
    Jul 31st, 2012
    San Antonio, TX
    RS '12 2D Golf
    08-11-2012 10:41 PM #86
    Maybe reseat them?
    I got mine on Friday and just tonight saw them at night. The soft white light they put out looks clean. Can't wait to get the license plate kit. My base Golf ended up not having footwell lights, so I got two extra LEDs. Oh well hehe
    And yeah. Don't do blue LOL
  17. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-12-2012 09:52 AM #87
    Well tried reseating them, found this on myfastgti
    The Vehicle Electrical System Controller J519 also can dim / turn on and off the ceiling light branch of the circuit without effecting the branch driving the glove box, visor mirror vanity lights and rear compartment light. A side effect of this ceiling branch control seems to be a small amount of current leakage in just that branch when the dome / map bulbs should be off. aka LED 'glow while off'. With the stock incandescents this current leakge is absorbed without glowing the filaments so it is not a concern. LEDs are more efficient and they will glow on the small current leakage. No harm, but can be a bit annoying. To eliminate the 'glow while off' , just one good error canceling LED can absorb the stray current and eliminate the annoyance. I put mine in the rear center dome position.
    Looks like I need just one of the error clearing type. No one else has see this?
    Will Vag for Beer.
  18. Member gravis86's Avatar
    Dec 25th, 2011
    Kirkland, WA
    2012 GTI CSG 6MT
    08-12-2012 01:33 PM #88
    Mine has the same thing. Let me know if the error cancelling LED works, and where you get it from if you try it.
    Have VCDS, will travel.
  19. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    08-12-2012 02:30 PM #89
    I've not looked - I'll see tomorrow...
  20. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-12-2012 03:42 PM #90
    Quote Originally Posted by gravis86 View Post
    Will do ordered them up should have them tomorrow or Tuesday maybe.
    Will Vag for Beer.
  21. Member phat7deuce's Avatar
    Mar 25th, 2012
    St. Petersburg, FL
    2012 VW Passat TDI SE with Sunroof (mine); 2012 Jetta Sportwagen TDI (wife's)
    08-12-2012 07:41 PM #91
    Let me know how it works out and where you ordered them from...curious how many LED's the error canceling ones you bought have, too. I did a quick search and only found ones that had 2 LED's.
    Just did this install with LED's from LED Wholesalers for both my 2012 Passat and my wife's 2012 JSW. The Passat was fine, but the SportWagen definitely has the issue. Your description from myfastgti seems to make sense, because I put the old filament bulb back in the center slot of the rear dome light and it seems to absorb the leakage, so the the 4 LED wedges fully turn off.
    Keep us posted...
    Current VWs: 2012 VW Passat TDI SE with Sunroof (mine); 2012 Jetta Sportwagen TDI (wife's)
    Past VWs: 2007 VW Passat Wolfsburg 2.0T; 2001 VW Passat GLX V6; 2000 VW Jetta GLX VR6
  22. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-15-2012 09:45 AM #92
    Footwell kit is in from Bold Sport. Looks like it's a winner, ordered last Weds. got it today so one week to get.
    Anyways, here are the lights themselves they look identical to the original OEM ones I pulled out from other areas.
    The lights with the wiring harness.
    They used OEM light connectors you can see the Audi/VW symbol. Other than that its just one ground "O" to something under the dash and the one trigger wire to the CECM.
    I should have the LED's at my APT today so if my back is up to it (tossed it this weekend), I'll try and get them in tonight and do a little DIY action if people would like.
    Will Vag for Beer.
  23. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    08-15-2012 10:59 AM #93
    Do they have the metal shield around them as well? The Foot well and glovebox lights do on the GTI.
    Related note - I don't seem to have the residual light when my LED's are 'off' that has been reported above.
  24. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-15-2012 11:23 AM #94
    Yes they do have the rear shielding.
    Will Vag for Beer.
  25. Member anonymous911's Avatar
    Oct 19th, 2009
    West Chester, PA
    '10 GTI 4DR 6M
    08-15-2012 11:31 AM #95
  26. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-15-2012 11:34 AM #96
    They currently do not have red. I got those from superbrightleds.com along with the two CANBUS bulbs that I needed for the voltage leakage.
    Will Vag for Beer.
  27. Member phish32786's Avatar
    Nov 18th, 2011
    Detroit, MI
    08-15-2012 01:09 PM #97
    Alright, sorry for all the posts today, it was a good day for deliveries for this project.
    So I got the CANBUS bulbs in today as well. I can report that by installing one CANBUS bulb in the middle dome light spot it takes all the light leakage out of all five overheads (dome and map).
    For the footwells I am doing one of each bulb. One 6 SMD T10 bulb (red) for the passenger side, and another CANBUS (red) in the drivers side. Below is the CANBUS installed in the drivers footwell.
    And the 'normal' 6 SMD T10 in the passenger side
    And as any good IT guy should have a spare old computer he can use for a 12V power supply to test, here they are lit up.
    So my final shopping list ended up looking like this.
    Domes/Maps
    (4X) Six SMD T10 Bulbs in White (Link)
    (1X) 5 SMD T10 CANBUS Bulb in White (Can't Link Part # WLED-NW5-CBT @ superbrightleds.com)
    Glovebox
    (1X) Six SMD T10 Bulbs in White (Link)
    Trunk
    (1X) 42mm Six SMD Festoon in White(Link)
    Mirror/Visor
    (2X) 37mm Three SMD Festoon in White(Link)
    Footwells
    (1X) Six SMD T10 Bulb in Red ( Can't Link Part # WLED-RHP6-AC @ superbrightleds.com)
    (1X) 5 SMD T10 CANBUS Bulb in Red (Can't Link Part # WLED-R5-CBT @ superbrightleds.com)
    For those of you with newer 2012 Golfs/GTI's with newer CECM software, you can use
    License Plate
    (2X) Six SMD T10 Bulbs in White (Link)
    NOTE: You will need a VAGCOM to clear the error. Module 09, Byte 23, Bit 6 un-check. It's called Cold Bulb Check for License Plate Light(s) (or something like that).
    I'll post back during/after the install.
    Will Vag for Beer.
  28. Member phat7deuce's Avatar
    Mar 25th, 2012
    St. Petersburg, FL
    08-15-2012 09:20 PM #98
    Thanks for experimenting and sharing. Ordered my CANBUS bulb today for my wife's JSW.
    Really intrigued by the footwell lights, too. My Passat has the cut outs, but doesn't have them and I was kind of wishing for them...
  29. Junior Member
    Jun 6th, 2012
    San Francisco, CA
    08-20-2012 01:43 AM #99
    phish32786 or anyone who has done this mod:
    Pics of natural/cool white in the footwells? Pics of the footwells (white) with the stock red gauges/lighting?
  30. Semi-n00b Gregoriovv's Avatar
    Oct 10th, 2012
    2012 GTI Autobahn DSG
    11-24-2012 12:33 AM #100
    Quote Originally Posted by JustinKYC. View Post
    Anyone have an recommendations on Interior LED Lighting?
    I've just recently looked at iJDMtoy and ECStuning's Ziza LED lighting and I'm not sure which to get. The iJDMtoy ones look super bright and I couldnt find any pictures of it installed on a GTI.
    Help anyone? Thanks.
    In the end:
    Got the LED's from LEDwholsalers. These are the bulbs you need:
    (6) 6 SMT LED 194 T10 Wedge Base Bulbs in white (2 Front overhead, 3 Rear overhead, 1 glovebox)
    (2) 6 SMT LED 194 T10 Wedge Base Bulbs in red (if you want red footwell lighting)
    (2) 37mm High Power 3 SMT LED Festoon Bulbs (Visor)
    (1) 42mm High Power 6 SMT LED Festoon Bulb (Trunk)
    In total it costed me about $58 with shipping.
    End results:
    E CODE's:
    I'm pleased, very pleased. Thanks everyone for their input!
    Just ordered from Led whosale, thanks for all the part numbers needed for this conversion. I just hope all the bulbs are the same in my 2012 GTI!
  31. Member JustinKYC.'s Avatar
    Jul 4th, 2010
    Calgary, AB
    2011 Volkswagen GTI
    11-24-2012 02:38 AM #101
    Quote Originally Posted by Gregoriovv View Post
    They should be all the same. Good luck!
    2011 CW MK6 GTI
    Ma Build Thread
  32. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-24-2012 12:16 PM #102
    Mine is a 2012.
  33. 12-17-2012 11:02 PM #103
    Ok, we got some testing done with help from another forum member:
    We are waiting on more testing with our white LED and only selling the blue and red, pictured below is the actual blue and red LED that were tested by a forum member here, they match the interior clusters perfectly!
    As you can see in the picture our LED fill the entire footwell with evenly distributed light leaving no spot darker or mismatched, this even distribution of light gives our LED footwells a more professional feel that your car deserves.
    Order here at our low introductory rate:
    http://www.deAutoKey.com/product/14p...wagen-golf-mk6
    w:www.deAutoKey.com – Free Shipping Always – High quality LED/Vinyls/Keys
    f:www.Facebook.com/deAutoKey – Exclusive savings, discount codes and announcements for FB fans
    i:www.Instagram.com/deAutoKey – Tag us in a cool VW pic or our product – we will follow you!
