Results 1 to 14 of 14
Thread: Vibration Issue after replacing suspension components.
  1. 06-08-2012 10:37 AM #1
    My Jetta is lowered for several years with the Bilstein Pss9 without any issues. I replaced both axles with raxles, ball joints and VF engine mounts. All bolts are torque to specs.The car vibrates only when moving (no engine vibration whatsover when in idle or in-motion). Raised the front end with jacks and visually inspected the axles, wheels/tires and without the wheels when in motion up to 80mph (safety first) and no binding or vibration or interferance. Thus the car vibrates when the car is on the ground maybe binding issue?. Does the OEM mounts the same ht. as the VF? Do I need spacers to raise the engine or go back to the oem mounts? Do you guys have any ideas what is causing this?
    24V VR6sc with Tiptronic.
  2. Member foundubbedriver's Avatar
    Jan 10th, 2006
    tempe, az.
    mkiv gti - rip. mkiv .:r32.
    06-08-2012 11:02 AM #2
    what year is your jetta? sketchy guess but i would look at the lower control arm bushings, strut mount bushings and possiby the wheel bearings. i've been low(ered) for quite some time and these items do see premature wear causing the symptoms you described.. good luck
    instagram @jcdubb3r - exklusiv motorsports.
  3. Member Golf2quick0's Avatar
    Mar 27th, 2008
    Chandler, AZ
    2003 VW Golf GL (Mojave Beige)
    06-08-2012 12:39 PM #3
    Could your vibration issue be coming from the increased stiffness of the VF mounts over the OEM ones? How severe is the vibration?
    8v Deathsquad... Reppin' AZ.
    Quote Originally Posted by gtiguy12 View Post
    Who needs a GED when you have JDM?!?
  4. Member
    Jan 13th, 2011
    Gilbert, AZ
    90 Corrado
    06-08-2012 12:43 PM #4
    Quote Originally Posted by Golf2quick0 View Post
    x2, that is what i was thinking!
  5. Member Golf2quick0's Avatar
    Mar 27th, 2008
    Chandler, AZ
    06-08-2012 12:45 PM #5
    Quote Originally Posted by rokhopr313 View Post
    I remember when I replaced my bushings in my dogbone to stiffer ones. The increased vibration at idle is noticeably higher. Under power, it goes away entirely.
  6. 06-08-2012 01:51 PM #6
    The vibration is rotational so, vibrates starts of at low speed ~3mph and increases as speed increase. No vibration at idle. The vibration is severe on my opinion since it is too uncomfortable to drive. All bushing are in good shape. The vf motor mounts many be lower in height versus OE...causes the axle to bind? No clunking or clicking. No vibration when car is jacked up from start to ~80mph.
  7. Member phxpilotmkv's Avatar
    Sep 2nd, 2008
    Mesa
    06' GTI
    06-08-2012 03:58 PM #7
    I have the BSH motor/tranny mounts. There is significant vibration during low speed acceleration if it isn't a smooth transitional from stopped to moving, even enough to rattle everything in the car.
  8. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    98 GTI VR6 S/C, 98 GTI VR6, 02 2.0L 5 speed jetta wagon, Haro Mirra 540 Air
    06-08-2012 05:46 PM #8
    axles
  9. 06-08-2012 06:10 PM #9
    Quote Originally Posted by vortexpert. View Post
    axles
    You mean binding axles? Both are new?
  10. Member
    Oct 7th, 2003
    Gilbert
    06-08-2012 06:30 PM #10
    New doesnt mean good, Raxles have always been awesome for me. And marty has always been real easy to work with. Yank them out one by one and check their articulation.
  11. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    06-08-2012 06:35 PM #11
    Quote Originally Posted by 24VWVR6sc View Post
    well maybe, you describe a vibration under load (mounts) but rotaional (axles).
    swap the mounts out and see if it goes away.
    swap the mounts=no more vibration mounts are cause
    swap the mounts=vibration present swap axles
    i gues you can sway its something you just did since this started after putting the parts in the car.
  12. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    06-08-2012 06:35 PM #12
    Quote Originally Posted by BigBlockBug View Post
    we need to have a coversation
  13. Member
    Oct 7th, 2003
    Gilbert
    06-08-2012 06:54 PM #13
    I called, emailed, text'd... Im on him like glue but I'll get him man.
  14. Member vortexpert.'s Avatar
    Sep 27th, 2009
    Avondale AZ
    06-08-2012 08:27 PM #14
    ok. i love you.
    so do you work at vivd now?
