Results 1 to 4 of 4
Thread: Alittle help with my Jetta Gl? :c
  1. Junior Member JETTAMK1's Avatar
    Sep 21st, 2011
    Arizona
    1984 Jetta Gl
    06-08-2012 12:26 PM #1
    So my gl is acting up, no fuel pressure, no spark. The problem was that the previous owner let the car sit in the rain and the window seal was cracked right above the fuse panel... Replaced the fuel pump relay, checked the fuses, bought a new fuel pump, new plugs, new plug wires. Can someone top by and check it out? It has to do with the connectors being corroded that go into the back of the fuse box, I think. I have cleaned them with wd40, still wont run. Engine turns over, everything else on the car works. Just no spark or fuel pressure:c
    You definitly need new muffler bearings...
  2. Member DrivesMeCrazy's Avatar
    Dec 29th, 2002
    Mexico
    2x Crap Boxes
    06-08-2012 01:22 PM #2
    If it's really the culprit I do not recommend wd40 on electric connectors. You want CRC contact cleaner or similar instead. wd40 leaves behind some nasty stuff after it dries up.
  3. Member prasina2's Avatar
    Apr 10th, 2003
    Phoenix, AZ
    1990 8V GTI
    06-08-2012 02:26 PM #3
    what engine and fuel system are you working with?
    did you really need to replace the parts you did, or are you just guessing?
    what actual troubleshooting have you done?
    are you getting power to the fuel pump?
    get on a2 resource, figure out what wiring system you have and then determine which corroded connectors may be affecting your dead systems.
    or...get a test light and start checking wires.
  4. 06-09-2012 07:00 PM #4
    best i would say is get a multimeter and start tracing from the battery. if your battery checks out then go to the fuseable links, check continuity going into an coming out of the fuse box.
    best of luck
