Results 1 to 8 of 8
Thread: DRL city lights w/ HID kit question!
  1. Member sault13's Avatar
    Sep 26th, 2005
    AZ
    1.8t GTi, 2.0tsi GTi
    06-08-2012 09:55 PM #1
    Basicly, i swapped my DRL's to the city lights on my 2003 GTI long time ago. Now looking to install HID kit, but remember readin a warning to disable the DRL's. My question is, since i swapped my drl's to the city lights do i still need to diable them to run the HID kit? And what possible problems if any am i about to get myself into. If need be, i'll switch everything back to stock. But hoping it wont get to that. Thanks
    Searched, but couldnt find answer i was looking for.
    Helix hid reps w/ 6k hids
  2. Member sault13's Avatar
    Sep 26th, 2005
    AZ
    06-10-2012 03:09 PM #2
    went ahead and installed the HID's but they dont seem to be as bright as i thought they would be. Would the DRL swap play into effect with that? DRL's being of lower watts or something. Would like to know if anyone has any info on this before i tear into the lights again.
  3. Member 2themax11's Avatar
    Dec 21st, 2011
    Brooklyn, NY
    2010 Tiguan SE w/ Leather, 2011 Nissan Maxima SV w/ Prem/Tech
    07-02-2012 03:37 PM #3
    Quote Originally Posted by sault13 View Post
    How did you make your city lights DRL? Was it something done w the VAG-COM? If so - could you guide me on what to enable/disable? Thanks!
    2010 Tiguan SE w/Leather
    Mods: RNS-510 Navi | RVC retrofit | 9w7 Bluetooth | 35% Tints | 2012 LED DRL Headlights | 19" Two-Tone Savannah Wheels | R-Line Door Sills | MK6 Steering Wheel | and more...
    My Build Thread: http://tinyurl.com/cqpa44w
  4. Member sault13's Avatar
    Sep 26th, 2005
    AZ
    07-03-2012 07:41 PM #4
    I swapped the pins in the headlight harness. I believe its pin 9 & 7.
    Will give more detail, when im able to take pictures. There once was a write up on how-to. try search, it may still be a diy with working pictures
  5. Member 2themax11's Avatar
    Dec 21st, 2011
    Brooklyn, NY
    07-03-2012 07:51 PM #5
    So wait you swapped the pin for city light with what? low beam? I got these new headlights on my tiguan and I want to make the LEDs the DRL (see image below). I'm not using the euro switch (wife hates it - smh).
    I def want to get this done asap - can you just confirm what exactly was swapped?
    Thanks man!
  6. Member sault13's Avatar
    Sep 26th, 2005
    AZ
    07-05-2012 05:46 PM #6
    This was done on my MKIV GTi. No idea which pins are which for the tiguan, but yes.
    How does the lights work on your tiguan? For the gti when i release the e-brake only the headlights come on(DRL). When i would turn on the headlight switch all other lights plus the city lights switched on. I swapped the low beam and city lights pins. so now with the release of e-brake only city lights come on (new DRL) etc.,
  7. Member 2themax11's Avatar
    Dec 21st, 2011
    Brooklyn, NY
    07-05-2012 06:35 PM #7
    Yes, the DRLs work the same way on my tig. Could you explain how you remove/swap the pins on the harness? I will research to make sure which pin is for what.
    Thanks for your help man!
  8. Member sault13's Avatar
    Sep 26th, 2005
    AZ
    07-10-2012 12:35 AM #8
    Remove the harness, and remove the retaining clip inside the harness with a small screw driver
    With a paper clip, or in my case a pair of tweezers, insert into the upper and lower gaps of the pin
    With the tweezers still in place gently but firmly pull on the back of the pin
    The first time i did this it was a pain in the @$$, so take your time. There are little clip on top and bottom of the pins, hints why the need for paperclip or tweeters to push the clip down in order to slide the pin out.
    Hope this helps
