Results 1 to 2 of 2
Thread: 2.0 ABA Cabriolet
  1. Junior Member MarkIVJetta2000's Avatar
    Jul 23rd, 2010
    Pennsylvania
    2000 MKIV Jetta GLS VR6 1988 Cabriolet
    06-10-2012 03:18 PM #1
    I plan on doing a 2.0 MK3 ABA motor swap into the bay of my 88 Cabriolet and want to put the entire motor into it. Later on down the road I want to turbo it too. I don't want to be messing with the fuel system and finding parts for the motor which is in pieces. I know I want to do a CE2 swap and would like some info on that. What harnesses do I need? How exactly do I accomplish this swap? I've read lots of threads and haven't quiet got a straight answer. Also want to know if I have to use the 8v tranny I have or if I can use the mk3 tranny. I'm just mostly concerned about the CE2 swap. Seems like I need to get a late mk2 CE2 wiring harness with the fusebox and the motor harness ECU and motor. That's all I have gotten out of reading. I don't want to run megasquirt. Any help is appreciated guys.
  2. Member tgibson's Avatar
    Sep 27th, 2010
    AZ / RI
    81 Caddy
    06-10-2012 06:56 PM #2
    You sir need to read through this thread:
    http://forums.vwvortex.com/showthrea...K1-info-thread
    BTW a full ce2 swap is the hardest most tedious way to do this swap.
