VWVortex.com - control housing assembly & cam adjustment valves replacement, swap it all or just valves?
    Results 1 to 5 of 5
    Thread: control housing assembly & cam adjustment valves replacement, swap it all or just valves?
    1. Junior Member
      Aug 20th, 2007
      boulder,co
      75 scirocco
      06-10-2012 07:56 PM #1
      So Im replacing my blown up 24V with another 24v and noticed my cam control valve plug ends are broken /smashed on the new motor. Known in the bentley manual as " intake cam adjustment valve N205 & exhaust valve N318.
      they come off easy with 2 torxs screws each and have a slight keyed notch that matches a hole where they seat.
      Can I just swap the valves or do I need to swap the whole control assembly?
      any help would be much appreciated.
    2. 06-11-2012 02:08 PM #2
      N205 and N318 are service replacement parts. You can just change them, but make sure that there is no debris or foreign material to clog the oil passageways to affect the camshaft timing system. Clean oil
      and frequent oil changes are a must in my opinion to keep the adjustment system working correctly.
    3. Junior Member
      Aug 20th, 2007
      boulder,co
      75 scirocco
      06-11-2012 02:25 PM #3
      Thanks Peter.
      B
    4. n00b murph503's Avatar
      Apr 24th, 2010
      Portland, Oregon
      2002/Audi/S6 Avant
      10-09-2012 02:44 PM #4
      Could someone please tell me what part #9 is called? Thanks in advance
    5. Junior Member naijababy's Avatar
      Nov 14th, 2006
      miami, Fl
      02 GTI 24V VR6
      10-31-2012 12:42 AM #5
      cam sprocket I believe
