i answered your question in the other thread where you asked it.
http://forums.vwvortex.com/showthrea...seal-poped-out
Edit: original poster got the pump out with advice in other thread. Read other thread.
I am trying to get the front transmission pump out of the trans from 2005 Passat. The transmission is a 5hp-19, I have the differential and cross drive shaft removed, I have the pan and valve body off, I have removed the tubes the go from the pump into the valve body, but I still cannot get the front pump to budge! I have pried pretty hard on it and even rigged up a slide hammer to try to get it to move....no luck. What am I missing? Please help!!!
www.KansasCityTdi.com
