VWVortex.com - Vcds help please
    Results 1 to 24 of 24
    Thread: Vcds help please
    1. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      12' Jetta S, 95' Passat GLX, 93' Corrado SLC
      06-10-2012 10:37 PM #1
      Wednesday,13,June,2012,23:00:59:35971
      VCDS Version: Release 11.11.3
      Data version: 20120401
      Chassis Type: 6N0
      Scan: 01 03 08 09 15 17 19 25 56
      VIN: 3VW1K7AJ1CM332493
      01-Engine -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: Malfunction 0010
      19-CAN Gateway -- Status: OK 0000
      56-Radio -- Status: OK 0000
      Address 01: Engine (CBP) Labels: None
      Part No SW: 06G 906 055 R HW: 06G 906 055 B
      Component: 2.0L 85 KW 01 1102
      Revision: T5H06--- Serial number:
      Coding: 0001012
      Shop #: WSC 00066 000 00000
      VCID: 3851FCF14B48AA9
      No fault code found.
      Readiness: 0010 0101
      Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
      Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
      Component: ESP MK60EC1 H31 0121
      Revision: 00H31001
      Coding: B14B240C492508FC8D0F24ED921C1061A70000
      VCID: 7BDB23FDFAFE411
      Address 08: Auto HVAC Labels: 5C0-820-047.clb
      Part No SW: 5C0 820 047 AM HW: 5C0 820 047 AM
      Component: J301 Klimaanlage 0203
      Revision: 2001010S Serial number: 00000000594234
      VCID: 6BFB13BD4A9ED11
      Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
      Part No SW: 5C0 937 086 E HW: 5C0 937 086 A
      Component: BCM25 JLB M3 H67 0251
      Revision: B0067001 Serial number: 04351251110085
      Coding: 7B994B3808E9090000382000244884DC0042502E6000000030 0000000000
      Shop #: WSC 00066 123 12345
      VCID: 2E7DDAA9790C649
      Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
      Component: J386__TSG_FT 002 3464
      Coding: 820000
      Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
      Component: J387__TSG_BT 002 3464
      Coding: 820000
      Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
      Component: J388__TSG_HL 002 3464
      Coding: 800000
      Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
      Component: J389__TSG_HR 002 3464
      Coding: 800000
      1 Fault Found:
      01326 - Control Module for Multi-Function Steering Wheel (J453)
      004 - No Signal/Communication
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 48
      Mileage: 17700 km
      Time Indication: 0
      Date: 2007.14.30
      Time: 18:09:51
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
      Component: AirbagVW10G 013 0807
      Serial number: 003GTM01WP43
      Coding: 00003936
      ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
      ROD: EV_AirbaVW10SMEVW360_VW36.rod
      VCID: 3449C8C19F204E9
      Seat occupied recognition:
      Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
      Component: BF-Gewichtss. H10 0027
      Serial number: 6940000Y1100005W9P0/
      Coding: 303245
      Crash sensor for side airbag; driver side:
      Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Fahr.V H01 ----
      Serial number: 3572MSME27221242ZZZF
      Crash sensor for side airbag; passenger side:
      Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Beif.V H01 ----
      Serial number: 3582MSME3C637061ZZZW
      Crash sensor for side airbag; rear driver side:
      Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
      Component: S.Sens.Fahr.H H02 ----
      Serial number: 3516KSME4E175E12ZZZ.
      Crash sensor for side airbag; rear passenger side:
      Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
      Component: S.Sens.Beif.H H02 ----
      Serial number: 3526KSME05404011ZZZ5
      Crash sensor for front airbag; driver side:
      Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
      Component: F.Sens.Fahr H02 ----
      Serial number: 3556LSME6F0E1B12ZZZ1
      Crash sensor for front airbag; passenger side:
      Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
      Component: F.Sens.Beif H02 ----
      Serial number: 3566LSME1E401A12ZZZS
      1 Fault Found:
      9445973 - Seat occupied recognition control module
      B1022 55 [137] - Not configured
      MIL ON - Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Status: 00000001
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 53
      Mileage: 17802 km
      Date: 2008.14.00
      Time: 19:06:04
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5C6 920 951 HW: 5C6 920 951
      Component: KOMBI H04 0604
      Serial number: 00000000000000
      Coding: 170801
      Shop #: WSC 00066 123 00122
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
      ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
      VCID: E8F1ECB113687A9
      Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
      Part No SW: 6N0 909 901 HW: 5C0 937 086 A
      Component: GW-K-CAN TP20 H67 0251
      Revision: B0067001
      Coding: 102200
      VCID: F0C184D123B8B29
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H04 0604
      Serial number:
      Coding: 000000
      Shop #: WSC 00000 000 00000
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
      ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
      VCID: EAF596B90D64489
      Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
      Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
      Component: LOW NAR H02 0004
      Revision: -----03S Serial number: VWZ4Z6L3194043
      Coding: 05000400010006
      VCID: 236B3B9D22CED91
      End ---------------------------------------------------------------------
      R.I.P. Allen A.K.A. vr6inside98. 89'-11' I LOVE YOU MAN
      Tri state area. VAG-COM (VCDS) Scans/Mods available (HEX+CAN)/Suspension install available/Fender rolling available. Send me a PM for pricing!
      Instagram- @mr_toffee
    2. Member JSWTDI09's Avatar
      Feb 22nd, 2009
      Las Vegas, NV
      2009 VW Jetta TDI Sportwagen
      06-12-2012 01:27 AM #2
      Try reading the sticky at the top of the page, the one that says "Read this before posting! FAQ and Rules for the Vag-Com Forum"
      You must post a full autoscan to get help here. That way we will know what control modules are in your car and how they are coded. We will then be much better equipped to help you. Just the fault code doesn't help us very much. We would like to help, but we don't know enough yet.
      Have Fun!
      Don
      2009 Jetta SportWagen TDI
      Candy White/Anthracite Build date: 01/16/09; Buy date: 02/09/09
      Coveted Three Pedal Version, Big hole in roof
      Dieselgeek Shortshifter & Panzer Plate (my favorite & my smartest mods)
      2microntech Pure Flow and Contain Flow CR fuel system modifications
    3. Forum Sponsor jef@rosstech's Avatar
      Jul 19th, 2010
      In the south, but not the "barefoot and toothless" south.
      2004 VWs
      06-12-2012 09:15 AM #3
      The problem, as I see it, is you are not a real Ross Tech customer, but rather some clone user and expect us to help out.
      When you step up to the plate and purchase a real Ross Tech interface from us, then we will help out as best we can... but if you are going to use a clone, then call China up and ask them for help.
      Jef blah blah blah
      http://www.ross-tech.com
      071, 070, 034, 036, 046, 077
    4. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-12-2012 07:52 PM #4
      Ok Jef@rosstech my other buddy is loaning me his legit Ross tech cable. So in a few hours I will post up a real scan and proof of the cable being real. Sorry for the inconvience didnt mean any harm as im a noob to this stuff!
      -Mike
    5. 06-12-2012 08:01 PM #5
      I will be in later to help if you post today to authenticate.
      Let me know Mike.
    6. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-12-2012 09:28 PM #6
      Quote Originally Posted by Jack@European Parts View Post
      Let me know Mike.
      Ok I appreciate it man.
      -Mike
    7. 06-12-2012 09:34 PM #7
      NP Mike
      I'm from LI originally. Hows traffic lately?
    8. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-12-2012 09:54 PM #8
      NP Mike
      ahh traffic over her is usually stop and go stop and go in rush hour after rush hour its normal. Lol
    9. 06-12-2012 10:04 PM #9
      Its all cool.
      Please let me know when you get a real cable sir.
    10. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-12-2012 10:11 PM #10
      Its all cool.
      I think my friend should be around tomorrow after noon. we will be in touch!
    11. 06-12-2012 10:16 PM #11
      I'll be ready!
    12. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-12-2012 10:21 PM #12
      I'll be ready!
      Thnx
    13. 06-12-2012 10:26 PM #13
      10-4 Copy that!
    14. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-13-2012 07:20 PM #14
      Scan is up
    15. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-13-2012 07:33 PM #15
    16. 06-13-2012 10:51 PM #16
      OK
      Have you performed a broadcast or auto/erase for all modules for DTC's?
      Seat recognition could be a bad wire or dirty connection under seat.
      Same goes for steering wheel module.
      Specific questions?
    17. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-13-2012 11:41 PM #17
      OK
      Specific questions?
      I'll go try that out now. As for the steering wheel code I kno what it is. Its b/c I have multi function wheel active under VCDS when I dont actually have a multi function wheel.
    18. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-14-2012 12:36 AM #18
      Ok so i did all of this and still no success! To make your life easier just follow my cursor in the pic to know exactly what i did!
      START
      I did an auto scan, by the end i dont have the option to delete DTC's
      END
    19. 06-14-2012 10:47 AM #19
      THIS POST MOVED/VACATED BY JACK TO PROTECT CONTENT FALLING INTO THE GAPING HOLE OF THE VORTEX
    20. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-14-2012 12:20 PM #20
      0x09-02-05
      0x15-02-05
      Im at work right now but if this means to go into each controller individually and hit fault codes and erase them that way. I have done that plenty of times and both codes just pop back ok.
    21. 06-14-2012 01:11 PM #21
    22. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-14-2012 01:32 PM #22
      Well then you should ref my prior post .
      Check the wiring before/verify Then ADP attempt.
      A prerequisite isn't met.
      so I should check out the pin out on the seat for the airbag plug correct?
    23. 06-14-2012 01:50 PM #23
    24. Member EuRoGTI86's Avatar
      Sep 27th, 2008
      LongIsland, NY
      06-14-2012 08:12 PM #24
      NEW SCAN!
      Thursday,14,June,2012,20:06:44:35971
      Chassis Type: 6N0
      08-Auto HVAC -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      Coding: 0001012
      Revision: 00H31001
      Address 08: Auto HVAC Labels: 1K0-820-047.lbl
      Part No: 1K0 820 047 GS
      Component: Climatic PQ35 120 0606
      VCID: 7BDB23FD3AFE411
      4 Faults Found:
      01297 - Sensor for Vent Temperature; Footwell (G192)
      010 - Open or Short to Plus
      01296 - Sensor for Vent Temperature; Center (G191)
      01271 - Positioning Motor for Temperature Flap (V68)
      000 - -
      01317 - Control Module in Instrument Cluster (J285)
      Coding: 7A994B3808E90B0000382000244884DC0042502E6000000030 0000000000
      Coding: 820000
      Coding: 820000
      Coding: 800000
      Coding: 800000
      1 Fault Found:
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 58
      Mileage: 17901 km
      Time Indication: 0
      Date: 2008.14.02
      Time: 19:33:51
      Coding: 00003936
      Coding: 303245
      Coding: 170801
      Revision: B0067001
      Coding: 102200
      Serial number:
      Coding: 000000
