VWVortex.com - 100mm cv axle swap problem
    Results 1 to 13 of 13
    Thread: 100mm cv axle swap problem
    1. Junior Member
      Oct 22nd, 2011
      Beaverton OR
      carbed with a 288 84 rabbit GTI, Dakota
      06-11-2012 02:35 AM #1
      so i swaped tranny in my 84 rabbit to a 9a with a 80 shim kit (so far so good) the cv axles how ever rub on the inside of the wheel baring carriers so can i just grind the CV axle for clearance i heard i would be able to just wanted to dubble cheak befor i hack stuff up
      Nov 19th, 2011
      Canada land
      81 rabbit L 16v , 81 caddy diesel
      06-11-2012 02:44 AM #2
      Yep thats what I did
    3. Junior Member
      Oct 22nd, 2011
      Beaverton OR
      06-11-2012 02:52 AM #3
      [QUOTE=canexrabbit;77761835]Yep thats what I did[/
      cool thanks, do i need to grind off alot of is it just a hair
    4. Member
      Nov 19th, 2011
      Canada land
      06-11-2012 02:55 AM #4
      When I did mine I took off maby a 1/8 th or a hair more
    5. Member broke..'s Avatar
      Sep 10th, 2010
      seattle-ish
      77 rabbit 2door (16v swap in progress) 95 jetta aba 5speed daily
      06-11-2012 07:48 AM #5
      i didn't take much off at all when i did mine, 1 or 2mm should do it
      A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. - Douglas Adams
    6. Member kevlar_vw's Avatar
      Jan 5th, 2005
      Johnson, VT
      mk1 Jetta, mkv rabbit
      06-11-2012 11:17 AM #6
      or buy knuckles from a 16v rocco, or late cabriolet
      www.wolfsgart.com
      B5 Passat part out - PM me
      My VW is a hybrid, it runs on hopes AND dreams...
      Nov 19th, 2011
      Canada land
      06-11-2012 11:21 PM #7
      I was just guessing
    8. 06-11-2012 11:35 PM #8
      Quote Originally Posted by ABAinA1 View Post
      85 and later cabriolet or rocco.
      there's a dimple on the inside of the knuckle just before the strut mounting points that signify it as a 100mm axle setup
    9. Junior Member
      Oct 22nd, 2011
      Beaverton OR
      06-12-2012 03:53 PM #9
      Grinded it works great
    10. 06-14-2012 04:11 PM #10
      What is a knukle? Do somebody have a pic?
      Regards
    11. 06-14-2012 08:04 PM #11
      Spelled "knuckle".
      Refers to the item that holds the wheel bearings, the hub, and the attachments for the front strut, lower control arm, and outer tie rod.
      "Spindle" is also used interchangeably, but that might be better used to refer to the rear device that holds the rear wheels and bearings.
    12. Member kevlar_vw's Avatar
      Jan 5th, 2005
      Johnson, VT
      06-15-2012 10:16 AM #12
      mine, 1 blasted, 1 ready to blast...they've since been POR15'd, and new bearings/hubs
      www.wolfsgart.com
    13. Member fredybender's Avatar
      Nov 17th, 2008
      Montreal Canada
      81 Rocco,80 widebody Rocco track bitch, 81 Rocco, 80 Callaway Rocco, 84 Jetta coupe, 1987 BMW E30
      06-18-2012 01:50 PM #13
      How I did mine...
      Early W/C NLA and performance parts: www.tech-53.com
